Old May 24, 2010, 10:00 AM
bulldog2 is offline
Find More Posts by bulldog2
Kuala Lumpur ,Malaysia
Joined Nov 2008
I used the standad COG from the manual...........
BTW way DOn I got news of the next 2 release....................
boy another 60mm potential upgrade kekekeke!!
bulldog2 is offline Find More Posts by bulldog2
Old May 26, 2010, 09:42 PM
The Don is offline
Find More Posts by The Don
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
I just got my shipment in of the new Wicked 6000KV motor for the Wemotec Micro Fan, here is the test data:
"Wicked Wemo Extremo" 6000KV motor: 350 watts 57,500 rpm on 3S
This will be a great upgrade to make your 50mm EDF jets scoot on 3S lipo!
The Don is offline Find More Posts by The Don
Old Jun 02, 2010, 09:10 PM
typhoonmaster is offline
Find More Posts by typhoonmaster
Rain or shine, wind or calm
Palatine
Joined Jul 2007
Ok...despite the problems with the model...I am going forward with the build and think I have an easy solution for moving the EDF unit forward. With the EDF unit moved forward, I believe Don's suggested CG can be achieved without adding weight to the nose.
I will post pictures!
typhoonmaster is offline Find More Posts by typhoonmaster
Old Jun 04, 2010, 12:01 PM
Palatine
Joined Jul 2007
Maiden went well. I was using a 1800Mah 3s 25c pack from Hobbypartz.com. WOT and a firm underhand toss and away she went. Aileron control is sensitive and needs to be tuned down.
I had the fan balanced by Don, so it is super smooth. As far as perfomance is concerned, I would guess it is in the low-70mph range.
It has enough power to do large loops, but I would guess it is less than 1:1 thrust/weight ratio.
Landing was a non-event. She slowed nicely and and maintained control at lower speeds. Overall, I am happy. Possibly interested in the Extremo, but need $$$
Old Jun 04, 2010, 03:39 PM
The Don is offline
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Glad it flew well, so you have which setup in it? The 5400 and Wemo fan?
Old Jun 04, 2010, 10:32 PM
Palatine
Joined Jul 2007
Indeed 5.4k plus wemo. Here are some pics of the mod and tip-tuck job. Basically, the mod is moving the fan foward and then using a water bottle as a mock intake ring.
Uploaded with ImageShack.us
Old Jun 05, 2010, 07:39 AM
The Don is offline
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
I like the pop bottle idea that seems to work quite well! So are you running the forward CG like I have? Also did you adjust the tail incidence or just move the CG forward?
Don
Old Jun 05, 2010, 08:07 AM
Palatine
Joined Jul 2007
Thanks. it works quite well for some applications. The CG is about midway between your recommended position and the stock CG point. I believe moving it forward to your suggested point would make it handle better.
I left the tail fins at their stock position. I will try to snag a video of it. I just wish I knew the 6.0k version was coming out.
have you tried the 6.0 in your 60mm fan with the 3 blade???
Old Jun 14, 2010, 01:53 AM
Moonbeam is offline
Find More Posts by Moonbeam
352nd FG Association
Moonbeam's Avatar
United States, GA, Decatur
Joined Mar 2004
Originally Posted by The Don View Post
Got some work on F-86 today. Here is what I did to solve the oversized outlet issue. I first did a "nip and tuck" by removing a wedge about 3/4" total width (3/8" on each side). Then I glued it together. This brought the outlet down to about 1.8" diameter which is what is needed for a 60mm fan! Next I made up a thrust tube and once the fan was installed, put the thrust tube in. Look at the last photo to see how tiny the correct exhaust looks even after the nip and tuck.
I put a thrust tube in mine with the exhaust diameter being 1 1/8" and she was even slower! (was somewhere around 60% FSA)
One of the guys at the field did the "nip-tuck" by cutting 5mm on each side of the seam for a total of 10mm. His was very fast!
I'm just not sure how far forward to make the cut.
Moonbeam is offline Find More Posts by Moonbeam
Old Jun 14, 2010, 01:17 PM
cmd is offline
cmd
Find More Posts by cmd
cmd
cmd's Avatar
Niceville, FL
60% FSA is too small. You probably don't want to go lower than 75% FSA. 75% to 85% is a nice rule of thumb. Smaller side yields more top end speed if there is sufficient thrust to overcome drag, larger side gives more thrust, but less top end speed.
cmd is offline Find More Posts by cmd
Old Oct 24, 2010, 05:34 AM
billbo1970 is offline
Find More Posts by billbo1970
Fellow Enthusiast
billbo1970's Avatar
Long Island, NY
Joined Jun 2007
I give up.... For those who have this plane good luck!....Well the remaiden was a HUGE success.
Don, You've heavily modified this plane, even changed the airflow dynamics of it. There's a reason why engineers use CAD & create airflow predictions with models. A small change can have dramatic results.
I am wondering if somehow during the "nip and tuck" I bent the rear of the fuselage up a few degrees.
It's impossible that you DIDN'T. Excising material from the bottom has caused an upward angle. I bet this is causing the airflow to hit the horiz. stab differently than the stock design.
________________
I'm not a very talented ASCII artist, but you get the idea
I would love to see a stock one fly, I bet it is nose up all the time.
Actually it's not at all, it flies nice & level. You're upward angle at the bottom rear of the fuse is causing an airflow change, that & not having the drop-tanks is probably making yours nose-up.
Originally Posted by Lardog
I imagine the specified CG was determined with the tanks on. Wouldn't have figured they had that much of an effect though.
The effect on CG is negligible. The effect on the airflow under the wing is DRAMATIC. The stock design probably relies on the tanks disturbing airflow under the wing. Drag at this point will help the plane fly level.
It doesn't climb particularly well and has a difficult time even trying to do a loop.
The stock design climbs VERY well, and does loops with ease. I've also seen the stock plane just re-fitted with a stronger EDF motor & no other changes made. Flies the same as stock, just faster.
Bill
billbo1970 is offline Find More Posts by billbo1970
Old Mar 15, 2011, 10:27 PM
HELLCAT632 is offline
Find More Posts by HELLCAT632
I KNOW WHAT IM DOING !!!!!!!
HELLCAT632's Avatar
United States, CA, Ontario
Joined Jan 2009
hey don im new to your thread and p.m.ed you about the thrust tube ! i looked and could not find the pdf did you post one on another thread or page ?
HELLCAT632 is offline Find More Posts by HELLCAT632
Old Mar 15, 2011, 10:28 PM
HELLCAT632's Avatar
Joined Jan 2009
my bad thank you for your time don!!!!
Old Aug 06, 2011, 01:40 PM
Razors edge 29 is online now
Find More Posts by Razors edge 29
QuAd FaNaTiC
Razors edge 29's Avatar
Canada
Joined Aug 2009
Thanks for all great info don.
Razors edge 29 is online now Find More Posts by Razors edge 29
Old Aug 06, 2011, 10:34 PM
QuAd FaNaTiC
Canada
Joined Aug 2009
Would doing this step (narrowing exhaust without t tube) help the stock unit?
Build Log Wicked Powered Jpower F5-E The Don Don's RC 57 Nov 23, 2014 08:42 AM
Build Log Wicked Powered Banana Hobby Jpower 50mm AMX The Don Don's RC 199 Dec 19, 2012 08:19 PM
Build Log Wicked Powered Hobby Lobby F-86 Skyblazer The Don Don's RC 49 Mar 17, 2011 10:32 PM
