Old May 09, 2010, 03:28 AM
Lardog is online now
Find More Posts by Lardog
ex-noob
Lardog's Avatar
Sammamish, WA, USA
Joined Jan 2010
Wow! What a difference!
I resized the end of the thrust tube to around 1.5" and it flew like a totally different model. Hand launches are much easier and smoother and it climbs 100% better than it did before. It is now enjoyable to fly.
Amazing how a little change can have such a large impact.
Lardog is online now Find More Posts by Lardog
Old May 10, 2010, 02:16 AM
Moonbeam is offline
Find More Posts by Moonbeam
352nd FG Association
Moonbeam's Avatar
United States, GA, Decatur
Joined Mar 2004
Originally Posted by Lardog View Post
Flew it again this morning, all went well. Again, the speed generally seems pretty good, however, there seems to be a fairly substantial lack of thrust. It doesn't climb particularly well and has a difficult time even trying to do a loop. This is my first EDF, so I am not experienced enough to know. Is this typical or normal for an EDF or one with a smallish 50mm fan? Compared to my prop planes, the difference is significant and very noticeable.
I am running 2200mAh packs, both 25 and 30C. I am wondering if going down to an 1800 to save some weight would help. From the specs though, we're looking at under 1 oz difference between the two, so I'm not sure whether this would provide a noticeable improvment or not.
Thoughts?
Larry
Hey Lardog,
You have pics of your set up?
Moonbeam is offline Find More Posts by Moonbeam
Old May 10, 2010, 01:13 PM
ex-noob
Lardog's Avatar
Sammamish, WA, USA
Joined Jan 2010
Originally Posted by Moonbeam View Post
Hey Lardog,
I don't at this time, but I can take some. What are you specifically interested in seeing?
Old May 18, 2010, 01:17 PM
typhoonmaster is offline
Find More Posts by typhoonmaster
Rain or shine, wind or calm
Palatine
Joined Jul 2007
Don: I didnt see this thread yet. I already ordered some 3s1300 20c packs for this plane and the wemo/5.4k combo. Are these batteries going to be sufficient? Also I am going to have to add a ton of weight to the front in order to achieve a better CG?
Would I be better off buying some 1500 or 1800 packs?
typhoonmaster is offline Find More Posts by typhoonmaster
Old May 18, 2010, 01:51 PM
ex-noob
Lardog's Avatar
Sammamish, WA, USA
Joined Jan 2010
A 1300 20C pack will be pushing it. The motor/fan will draw close to the packs rated capacity. Conventional wisdom says most packs are over rated. I would suggest a 30C in that size.
Yes, you will need to add weight in the nose. Either that or move the motor & fan forward from its original position. With a 2200 pack, I still had to add 1.5 oz. Overall, the plane was just too heavy. I didn't fly it with a smaller, lighter pack, so that might make a difference, but overall, I was underwhelmed.
Old May 18, 2010, 02:14 PM
Palatine
Joined Jul 2007
unfortuntate news.
Old May 18, 2010, 03:41 PM
The Don is online now
Find More Posts by The Don
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Honestly my suggestion is not to modify the F86 instead get one of the other 50mm jets. This F86 is just not worth the mods in my opinion as it needs a lot of nose weight and even with the extra power of 4S it is nothing special. The F16 is the best 50mm model so far with the Wemo 5400 combo. if you have the F86 fly it stock for what it is and put the wicked wemo in one of the other jets and save yourself the aggravation. That is my honest opinion on this plane.
The Don is online now Find More Posts by The Don
Old May 19, 2010, 02:15 AM
Moonbeam is offline
Moonbeam's Avatar
Joined Mar 2004
Well, that answered my question. I was thinking of making the airframe I have now into a pusher prop, and get a new one to do the Wicked Wemo mod. But if it ain't worth the trouble......
I just really like the F-86.
Old May 19, 2010, 10:22 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
I am contemplating putting a different fan unit into it like a 60 mm fan and moving it forward to help with the CG.
Don
Old May 21, 2010, 11:11 PM
bulldog2 is offline
Find More Posts by bulldog2
Kuala Lumpur ,Malaysia
Joined Nov 2008
Don,
g ahead with the 60 mm conversion, you won't regret it...
im using windrider 60mm and HC 4800kv and man she hauls and Im using 2200 2c 3s to balance back the plane wih drop tanks!!
bulldog2 is offline Find More Posts by bulldog2
Old May 21, 2010, 11:14 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
I bet with a 60 mm and 3S with less watts it will go faster. Now I am debating a new airframe or hacking up the current one.
Don
Old May 22, 2010, 12:30 AM
ex-noob
Lardog's Avatar
Sammamish, WA, USA
Joined Jan 2010
I thought you sold you previous one?
Bulldog,
Did you put a 60mm fan in one of these? Care to share some info on how you fit it in?
Larry
Old May 22, 2010, 06:02 AM
bulldog2 is offline
Joined Nov 2008
Ill ost some pictures in the normal thread...
Old May 23, 2010, 08:43 AM
Palatine
Joined Jul 2007
Originally Posted by bulldog2 View Post
Don,
So, windrider...have you found that the CG point is where Don specified?
Old May 23, 2010, 08:49 AM
Palatine
Joined Jul 2007
Don
Don, I am debating using my airframe. if you want another one, I can ship it to you from chicago.
Build Log Wicked Powered Jpower F5-E The Don Don's RC 57 Nov 23, 2014 08:42 AM
Build Log Wicked Powered Banana Hobby Jpower 50mm AMX The Don Don's RC 199 Dec 19, 2012 08:19 PM
Build Log Wicked Powered Hobby Lobby F-86 Skyblazer The Don Don's RC 49 Mar 17, 2011 10:32 PM
