Old Apr 04, 2010, 09:26 AM
The Don is offline
Find More Posts by The Don
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Putting the servos in. I cut some foam out so the aileron servo sat lower in the wing. Also did a quick CG check, looks like it will be very close to recommended spot so if any nose weight is needed it will be minimal. .
The Don is offline Find More Posts by The Don
Old Apr 04, 2010, 10:48 AM
awayne is offline
Find More Posts by awayne
awayne's Avatar
Pacifica,CA
Joined Oct 2006
Hey Don,
I've never tried the nip and tuck method before. I'm thinking about trying it to my f-86. I just have a couple of questions I was hoping you can answer for me so that I can understand how to accomplish this successfully. Do you cut all the way through to the end of the hatch opening? Also, what type of glue did you use to glue it back together? Is 5min epoxy strong enough for this kind of foam? I gotta say I really enjoy flying this jet with my wemo/razor combo. It's very stable and relaxed. I have an extra 4800 and wemo combo sitting on my bench. I'm planning on going with 2 7.4V 1000mah in series.
Thanks!
awayne is offline Find More Posts by awayne
turbodriven is offline
Find More Posts by turbodriven
100mph club member
turbodriven's Avatar
NW O-town
Joined Jun 2005
Originally Posted by The Don View Post
Got some work on F-86 today. Here is what I did to solve the oversized outlet issue. I first did a "nip and tuck" by removing a wedge about 3/4" total width (3/8" on each side). Then I glued it together. This brought the outlet down to about 1.8" diameter which is what is needed for a 60mm fan! Next I made up a thrust tube and once the fan was installed, put the thrust tube in. Look at the last photo to see how tiny the correct exhaust looks even after the nip and tuck.
Do you think this "nip & tuck/thrust tube" mod will benefit a stock setup as well? Not really looking for a screamer but any free power enhancements are always a bonus.
turbodriven is offline Find More Posts by turbodriven
Old Apr 04, 2010, 11:39 AM
cch1978 is offline
Find More Posts by cch1978
Joined Apr 2008
never mind
cch1978 is offline Find More Posts by cch1978
Old Apr 04, 2010, 05:50 PM
Lardog is online now
Find More Posts by Lardog
ex-noob
Lardog's Avatar
Sammamish, WA, USA
Joined Jan 2010
Quick question...
If using a thrust tube, why do the nip & tuck also? Is it just for looks?
Lardog is online now Find More Posts by Lardog
Old Apr 04, 2010, 06:00 PM
The Don is offline
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
To help reduce wake drag and also to see if it was possible to nip and tuck even more but decided to stop there.
Old Apr 04, 2010, 10:02 PM
corsair nut is online now
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
i wouldnt go over 110%on anything. if its something real slow, say 40-60mph...MAYBE 120. MAYBE. anything past 70, 100 is enough.
corsair nut is online now Find More Posts by corsair nut
Old Apr 04, 2010, 10:04 PM
tehachapi, CA
Joined Jan 2006
yeah, youll see a imprivement even on a stock setup. these companies kill me.
Old Apr 05, 2010, 01:52 PM
cmd is offline
cmd
Find More Posts by cmd
cmd
cmd's Avatar
Niceville, FL
Don,
What did you use to secure the exhaust tube at the exhaust end? Do you brace it to be centered in the exhaust nozzle area?
cmd is offline Find More Posts by cmd
Old Apr 05, 2010, 07:48 PM
The Don is offline
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Originally Posted by cmd View Post
Don,
Right now nothing as when it is taped to the fan it can not be moved. I have it all the way down to help add downthrust so the extra power will keep it from climbing. I may need to adjust it but have to flight test first.
Don
Old Apr 05, 2010, 08:32 PM
cmd is offline
cmd
cmd
cmd's Avatar
Niceville, FL
Don
Thanks. I'm keeping a log of tips on the individual 50mm airplanes to reference as they enter the stable.
Old Apr 05, 2010, 10:01 PM
tehachapi, CA
Joined Jan 2006
for the life of me im wondering why they didnt just use 2 real small servo's instead of one right in the middle..hanging out. :O sheesh
Old Apr 05, 2010, 10:13 PM
BigGuyJT is offline
Find More Posts by BigGuyJT
BigGuyJT's Avatar
Fresno, California
Joined Mar 2007
http://www.rcgroups.com/forums/showp...postcount=1977
this guy did a nice lil mod to make his look better.
BigGuyJT is offline Find More Posts by BigGuyJT
Old Apr 05, 2010, 11:16 PM
zaskarkid is offline
Find More Posts by zaskarkid
what it do everybody?
zaskarkid's Avatar
a swamp naturally
Joined Mar 2008
Is 16oz auw 3oz too heavy?
zaskarkid is offline Find More Posts by zaskarkid
Build Log Wicked Powered Jpower F5-E The Don Don's RC 57 Nov 23, 2014 08:42 AM
Build Log Wicked Powered Banana Hobby Jpower 50mm AMX The Don Don's RC 199 Dec 19, 2012 08:19 PM
Build Log Wicked Powered Hobby Lobby F-86 Skyblazer The Don Don's RC 49 Mar 17, 2011 10:32 PM
