Old Mar 31, 2010, 09:39 PM
Tram is offline
Find More Posts by Tram
Fly it like you stole it..
Tram's Avatar
Florence, Al
Joined Oct 2000
Ok.. I'll try it stock and get with you..
Tram is offline Find More Posts by Tram
Old Apr 02, 2010, 05:32 PM
The Don is online now
Find More Posts by The Don
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
OK guys back to my building board. Sorry for the slow progress but I have had lots of motor fan balance combos sold the past week and customers come first! But I am all caught up now on orders so back to the build!
Don
The Don is online now Find More Posts by The Don
Old Apr 02, 2010, 10:59 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
I have my fan and motor combo all mounted then I started to measure the outlet and holy crap! The outlet diameter is 2" That is 140% FSA outlet! No wonder the F86 is the reported worst flying of the bunch. I am not sure what I want to do now. To make the outlet correct a nip and tuck would require 1.65" of material to be removed at the outlet. That is huge! No way that can be done on this model. I am almost considering putting a 60mm fan into it. There is a ton of foam that can be cut out easily to make the fan fit. Not sure what to do now.......
Old Apr 02, 2010, 11:47 PM
Tram is offline
Tram's Avatar
Florence, Al
Joined Oct 2000
Got to maiden mine today and while it's not a rocket ship, it seemed to fly very nicely.. I guess I aught to try one of the other ones to hear what all the hype is about.
Old Apr 03, 2010, 01:16 AM
Lardog is online now
Find More Posts by Lardog
ex-noob
Lardog's Avatar
Sammamish, WA, USA
Joined Jan 2010
So for us EDF noobs, what does that mean? FSA? Is the outlet too big or too small and what is the effect of either?
Lardog is online now Find More Posts by Lardog
Old Apr 03, 2010, 09:41 AM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
It means the outlet is way too big. The outlet is even on the big side of a 60mm fan.
Old Apr 03, 2010, 10:05 AM
smasher41 is offline
Find More Posts by smasher41
United States, GA, Snellville
Joined Nov 2005
Don, for a stock setup... would a nip and tuck of any amount help?
I got a beater f-86 at this point and would like to try it to see if it helps.
Also... is it normal for the area right after the fan unit to be so wide? I would think thats killing thrust also.
smasher41 is offline Find More Posts by smasher41
Old Apr 03, 2010, 11:33 AM
kamoch is offline
Find More Posts by kamoch
Stick 'em up!
kamoch's Avatar
USA, CA, La Mirada
Joined Feb 2005
Don, what about a thrust tube? I plan on installing one in my F-86, any suggestions for the exit diameter?
kamoch is offline Find More Posts by kamoch
Old Apr 03, 2010, 05:08 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
I am not sure why they have the expansion on the outlet. Makes no sense to me but I am doing a combination of nip and tuck and thrust tube. I took a few photos and will post shortly. For those using the cone layout program, I used 2.060" as the starting diameter and 1.476" as the exit diameter with a length of 7.50" then I will add a small centering ring much like I did on the SR-71 outlets.
Old Apr 03, 2010, 10:42 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Got some work on F-86 today. Here is what I did to solve the oversized outlet issue. I first did a "nip and tuck" by removing a wedge about 3/4" total width (3/8" on each side). Then I glued it together. This brought the outlet down to about 1.8" diameter which is what is needed for a 60mm fan! Next I made up a thrust tube and once the fan was installed, put the thrust tube in. Look at the last photo to see how tiny the correct exhaust looks even after the nip and tuck.
Old Apr 03, 2010, 11:50 PM
corsair nut is online now
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
cool don! you should nip and tuck the inlet too!
corsair nut is online now Find More Posts by corsair nut
Old Apr 04, 2010, 12:07 AM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
CN, I know you have run 100% and less on inlets but for most applications say 100 mph or less what is a good number? 120%
Don
Old Apr 04, 2010, 07:54 AM
alexandermh is offline
Find More Posts by alexandermh
alexandermh's Avatar
Fairborn, OH
Joined Nov 2009
Here are some more shots of the tube installation.
Don, I notice you installed the new fan and motor in the stock location. With reports of the F-86 being tail heavy, are you worried about getting the CG right or are you planning on heavier batteries solving that?
alexandermh is offline Find More Posts by alexandermh
Old Apr 04, 2010, 08:13 AM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
I am using a 4S 1800 lipo which is much heavier so we will see what happens.
Don
Build Log Wicked Powered Jpower F5-E The Don Don's RC 57 Nov 23, 2014 08:42 AM
Build Log Wicked Powered Banana Hobby Jpower 50mm AMX The Don Don's RC 199 Dec 19, 2012 08:19 PM
Build Log Wicked Powered Hobby Lobby F-86 Skyblazer The Don Don's RC 49 Mar 17, 2011 10:32 PM
