San Diego, CA
Joined Dec 2006
See his thread at http://www.rcgroups.com/forums/showthread.php?t=1514024 for more info. My Champ floats fine on them, but I found out the hard way that you actually have to treat it like a seaplane when taxiing. I managed to beach the plane (with no intention of doing so) on a small island in the small pond I tried to fly from, and wound up wading out to the island to rescue it. Not the fault of the floats at all, it was the fault of a clumsy and unprepared pilot who shall remain nameless. Some day I'll get my head out and try hand-launching it over land, as you did. My guess is, it will fly fine, especially on Champ IIIa with its brushless 7.5g motor, Spektrum AR6400LBL microbrick and two 160mAh 1s Champ batteries. Hint: When taxiing, keep the motor running ABOVE idle speed if you want to steer. When mind was idling, I had no directional control at all. But when I throttled up, I did. Seaplane pilots probably know that from the beginning, but some of us have difficulty learning unless whacked in the face with a 2x4 (or unless we have to wade around in a really cold pond with kids laughing at us). |
McCarthy, Alaska
Joined Jun 2004
Only able to fly one day before things froze up here, but my experience pretty much mirrored yours, little acorn. I actually used to fly float planes so have some experience along the lines. But still ended up not having very good directional control at taxi speed. Next spring I plan to experiment with a water rudder. Likely fastened to the air rudder, and set so that it only is in the water while the plane is sitting tail low, and comes clear when on step. Often full size float planes have not only water rudders for taxi control (you pull them up when taking off or landing) but additional vertical fin area to offset the floats being up front, causing lack of directional stability when airborne. Lots of fun
Joel |
Latest blog entry: Eflite UMX Sbach 3D on 3s - 2300Kv/5043...
TexBird,
The Champ elevator gets narrower where it intersects with the rudder. With the outer "shell" this foam has, there can be a crease or crack that's not visible to the casual glance. Look closely, and move the elevator. This may be the source of the imbalance, with the control horn side moving the furthest. A dab of foam safe ca, or strategically placed packing tape can stiffen things up. Enjoy the Champ, we all love it. Questions? Ask away. Hope this helps.
Aeronca |
Joined Oct 2006
Just te thought that counts, that pays for it all. tanks anyways it is a 2.4 brushed not fm or mhz. I will most likely trade off the DX4E, which is a wrong move, as Tx's sre the one's that last. over the plane. |
![]() Aeronca |
Joined Aug 2011
Check this out!
Hey everybody! Check this out!!! Made it myself!
![]() ![]() ![]() http://www.wonderhowto.com/how-to-ma...plane-0131331/ |
| Thread Tools | |
| Discussion What plane is this? Debolt Livewire Champ-w/short video | reacher10 | The Builders Workshop | 48 | Mar 29, 2011 03:20 PM |
| Discussion Super Champ Restoration | x-craft | Off-road Cars | 48 | May 25, 2010 07:48 PM |
| For Sale Champ (1/8th scale, electric) | Maggie Han | Aircraft - Electric - Airplanes (FS/W) | 12 | Mar 19, 2010 08:31 PM |
| For Sale 2x Ni-Mh batts will fit PKZ or HBZ planes | gazza1 | Aircraft - Electric - Batteries & Chargers (FS/W) | 0 | Sep 07, 2009 09:46 AM |
| Question digital camera for hbz extreme | bluescoobydoo | Aerial Photography | 0 | Jul 31, 2005 11:25 AM |
