Old Feb 27, 2013, 10:19 AM
Saxguy1000 is offline
Find More Posts by Saxguy1000
Rockin' & Flyin'
Saxguy1000's Avatar
Virginia Beach
Joined Dec 2009
Originally Posted by bhoov128 View Post
I think you just rudder the same direction you're using ailerons and the roll-coupling makes it roll quite a bit quicker but I'm not sure. Awaiting UNGN's response
I'll have to try this on the sim, but UNGN usually explains well.
Saxguy1000 is offline Find More Posts by Saxguy1000
Old Feb 27, 2013, 12:56 PM
bhoov128 is online now
Find More Posts by bhoov128
Genesis 50:20
bhoov128's Avatar
United States, FL, Davenport
Joined May 2012
Yes, agreed. I'm still trying to get used to using up-then-down timing on the elevator during a roll on a slower rolling plane so that it comes out heading straight instead of 45 degrees nose down.
bhoov128 is online now Find More Posts by bhoov128
Old Mar 06, 2013, 06:56 AM
helibard is offline
Find More Posts by helibard
CRASH, FIX, REPEAT
helibard's Avatar
United States, KY, Bardstown
Joined Apr 2010
Practice, Practice, Practice, lol
helibard is offline Find More Posts by helibard
Old Mar 06, 2013, 01:02 PM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
That is correct. Rudder in the same direction as Ailerons help "Snap" the roll, similar to the way it rudder rolls a Champ.
UNGN is offline Find More Posts by UNGN
Old Mar 06, 2013, 02:01 PM
SilentPilot is online now
Find More Posts by SilentPilot
BMFA 190658
SilentPilot's Avatar
United Kingdom, Yeadon
Joined Mar 2007
SilentPilot is online now Find More Posts by SilentPilot
Old Mar 06, 2013, 06:12 PM
JLT_GTI is offline
Find More Posts by JLT_GTI
JLT_GTI's Avatar
Spain, Principado de Asturias, Oviedo
Joined Jun 2010
UNGN - You are always teaching me stuff. How do you apply rudder to speed up a roll? That's new to me.
when you have a wing with dihedral, the rudder will actually induce roll in the plane.. it will bank the plane in the direction.... thats what allows dihedral planes to turn so nicelly (tought not much fast or 3Dish) with rudder and what allows the Champ to not need ailerons at all .. the Champ actually can make snap rolls with rudder and elevator only.
In a plane like the T28 where you have dihedral, rudder and ailerons, the rudder will induce roll wich sumed to the ailerons will increase the roll amount a lot.. it wont be obiously a flat clean roll .. more like a small barrel-roll
This applies to all dihedral planes..and is an old and effective trick on planes like the EasyStar family.. the AXN Floater for example.. it has a slow aileron roll rate.. but if you combine both ailerons and rudder it will spin way way faster
JLT_GTI is offline Find More Posts by JLT_GTI
Old Mar 07, 2013, 04:48 AM
Rockin' & Flyin'
Saxguy1000's Avatar
Virginia Beach
Joined Dec 2009
Thanks UNGN! That is great info I've not gotten anywhere else! I had no idea I could attempt a roll on the Champ. As soon as the wind slows down from around 54mph, I'll try this out!
Old Mar 07, 2013, 09:36 AM
JLT_GTI is offline
JLT_GTI's Avatar
Joined Jun 2010
More like a barrel roll but yes.. it will roll..
actually the Champ is quite aerobatic if you are energetic enought with the sticks and throws... i use the Champ to ilustrate people that 3 chanel planes with no ailerons can be fun too (not all.. i also own a 2m glider with no ailerons wich uses dihedral and i wouldnt try a roll on that , but again thats the plane i use now for FPV)
Old Mar 10, 2013, 06:29 AM
GBLynden is offline
Find More Posts by GBLynden
I am GBLynden
GBLynden's Avatar
United States, WA, Lynden
Joined Mar 2011
Hey guys! After two years of flying this beautiful little plane, which includes a trip up over 1,000, it still puts a smile of my face every time I fly it
Hobbyzone Champ in church parking lot on windy day (3 min 11 sec)
GBLynden is offline Find More Posts by GBLynden
Old Mar 10, 2013, 07:10 AM
Laneritc is offline
Find More Posts by Laneritc
1st to the scene of the crash
Laneritc's Avatar
United States, GA, Dalton
Joined Jul 2012
Nice video, I'd love to maiden my Champ if the wind would ever quit blowing here.
Laneritc is offline Find More Posts by Laneritc
Old Mar 10, 2013, 07:11 AM
hare is offline
Find More Posts by hare
Like a Tortoise
hare's Avatar
Joined Jan 2013
that is the truth. hook line and champ
hare is offline Find More Posts by hare
Old Mar 10, 2013, 07:36 AM
kodak_jack is offline
Find More Posts by kodak_jack
kodak_jack's Avatar
Hilton (Rochester), NY
Joined Mar 2008
I also have the Velcro letting ho problem. I just got a P-51 and the previous owner likes to use toothpicks a lot. They push into the fuse easy enough and then you can stretch a small rubber band over the battery to keep it in place. That plane is also intended to use the same battery we use, but he used these:
Nano Tech batteries $2.99 http://www.hobbyking.com/hobbyking/s..._Mini_CP_.html
It requires you to change the plug. Then again, the plug is a royal PITA at times and that would allow you to go to micro Deans connectors. They're easier to deal with and give positive contact.
kodak_jack is offline Find More Posts by kodak_jack
Old Mar 10, 2013, 11:23 AM
Chap1012 is online now
Find More Posts by Chap1012
Epilepsy Awareness
Chap1012's Avatar
United States, MA, Malden
Joined Mar 2008
If you Guys are having a problem keeping your batteries from flying off, I did this mod a member turned me on to. Remove the cheap velcro from battery hold and replace the whole cavity with fuzz velcro. Add hooked velcro to some shrink wrap. The shrink wrap pictured fits beautiful. You can now slip these off and onto other batts Very easy and it works great.
Mike.
Chap1012 is online now Find More Posts by Chap1012
Old Mar 10, 2013, 11:45 AM
hare is offline
Like a Tortoise
hare's Avatar
Joined Jan 2013
Day light savings time, lighter later, sweet. just as it was light in the Am its dark again Lol soon it will level out. now to get the champ flying.....
Old Mar 10, 2013, 09:57 PM
bradymartin is offline
Find More Posts by bradymartin
Joined Jan 2013
i just lost it.
7:00pm or so, still light out. i was bored, had a few drinks. stupidly i decided to fly it in my driveway, trees, power lines etc.
no wind at all, trimmed it and at 2 minutes it went below tree lines in front of my house, i couldnt see it. lost it im kinda pissed at myself. not because i flew it from my driveway, i was doing great, but because i forgot about those two trees.
i jogged a few blocks could not find it.
so now im wondering if i should buy another one. i have the tx, 5 batteries now instead of 6, extra prop, front wheels. or if i should move on to the micro t-28 or so.
it was a stupid mistake damn lost the champ
bradymartin is offline Find More Posts by bradymartin
Discussion What plane is this? Debolt Livewire Champ-w/short video reacher10 The Builders Workshop 48 Mar 29, 2011 03:20 PM
Discussion Super Champ Restoration x-craft Off-road Cars 48 May 25, 2010 07:48 PM
For Sale Champ (1/8th scale, electric) Maggie Han Aircraft - Electric - Airplanes (FS/W) 12 Mar 19, 2010 08:31 PM
For Sale 2x Ni-Mh batts will fit PKZ or HBZ planes gazza1 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Sep 07, 2009 09:46 AM
Question digital camera for hbz extreme bluescoobydoo Aerial Photography 0 Jul 31, 2005 11:25 AM
