Old Apr 17, 2012, 02:41 AM
ITS ME DAVID is offline
Find More Posts by ITS ME DAVID
ITS ME DAVID's Avatar
Joined Apr 2011
thanks yea i was hoping that i can just float it onto the grass and not hurt anything thanks..
ITS ME DAVID is offline Find More Posts by ITS ME DAVID
Old Apr 17, 2012, 04:08 AM
fishycomics is offline
Find More Posts by fishycomics
Joined Oct 2006
Originally Posted by ITS ME DAVID View Post
Thanks for the info can the champ lad on grass like a glider can or will it break easily I want to fly it at the Rosebowl that's why.
get Lagerwheels, or advance to the Electrifly Flylite
fishycomics is offline Find More Posts by fishycomics
Reply With Quote  (Disabled)
Old Apr 17, 2012, 07:56 AM
GooberSB is online now
Find More Posts by GooberSB
An Ordinary User
United States, VA, Fluvanna
Joined Jan 2011
Originally Posted by quitcherbitchen View Post
Yeah, I thought so. But how many cycles will the new batteries last? On my bigger planes that use 1350-2200mah the batteries are a year old and cycled probably 50 times. Should I be worried? I have a pretty decent Common Sense charger for those. I read that even these little battery chargers charge at too high a rate.
Yes, the 160mah batteries should be charged at .16A (or less) but the little charger that comes with the Champ charges at .3A So sometimes I use a HK pigtail with my good charger that lets me parallel charge up to 6 of the batteries at the rate of around .16A per battery. Sometimes I only have 2 batteries on it charging at .3A but it's better for them I think.
BTW, MyRCMart has some interesting adapters that will balance charge either 2 or 3 UM batteries, which is even better than parallel charging.. I bought some but have not used them yet.
GooberSB is online now Find More Posts by GooberSB
Old Apr 17, 2012, 05:33 PM
ccsj is offline
Find More Posts by ccsj
snokefpv
United States, CA, San Jose
Joined Mar 2012
^ dang that thing is fast.
Hey guys I'm new to airplanes been using the little 3-4ch heli and want a micro 3ch rtf and seen this champ and read atleast 30-40 pages but I'm debating on this airplane the champ vs the cox skycruiser ? Anyone tried both yet. http://www.towerhobbies.com/products/cox/coxa6503.html
I have both Cox sky cruiser and HBZ Champ. I got my first plane (sky cruiser) 5 months ago and Champ 2 months ago, so I'm some what new to flying RC plane and here's my beginer's opinion.
I find that the EPO foam used on the SC is stronger and I didn't sustain much damage than the somewhat fragile Champ (espeically the tail). Although Champ is flewn at slower speed most time so crashes on the champ seem to be less severe. I used extra duty packing tape to tape the entire SC and have not sustained any damage since. It was able to carry the extra weight and take on the wind and fly quite fast. No problem climbing either.
The Champ electronics are much more robust. SC brick gets quite hot and many of us (in SC or Nine Eagles sky runner thread) have had some problem with the servo not being responsive when over heated which leads to losing control and crash. I never experience this with the Champ. SC also tends to nose dip during lauch (even when COG was set correctly). IMO, for the first plane for beginer, I would recommed the Champ over the SC. It flies slower, and a much more stable platform. Both planes can be upgraded but there are a lot more support and ideas (from this forum) to optimize your Champ than SC.
SC set up - just tape with extra duty packing tape on the entire fuselage, 350mA 2S battery, a quater under the nose to get COG right - there is not much space left for larger batt unless you move the brick, etc.
Champ set up - tape entire tail with packing tape, dime and nickel under the nose, P51 motor, 5043 prop, waiting for my 190mA miniaviation batt to arrive.
ccsj is offline Find More Posts by ccsj
Old Apr 18, 2012, 10:01 PM
TjW is offline
TjW
Find More Posts by TjW
TjW
USA, CA, Riverside
Joined Mar 2006
Meh. Bite the bullet and spend the forty bucks or so to buy five MiniAviation 190s
or Hyperion cells. You'll never look back. To be honest, I don't have the 190s. I have the earlier 180s from quite awhile back, and they're still great batteries.
TjW is offline Find More Posts by TjW
Old Apr 18, 2012, 11:49 PM
stevenator128 is offline
Find More Posts by stevenator128
Joined Apr 2012
I'm sorry if I was supposed to start a new thread to ask this but I thought this thread would be a good place to ask. My Champ just refuses to fly straight or even. No matter how much I trim either the elevator or rudder and even with proper throttle modulation, she won't stay steady! She constantly pulls to the right ever so slightly and rather than flying at a constant elevation it does a weird dolphin bob through the air, up and down, up and down. It does this whether I am at full throttle or just gliding and no matter which direction I trim the elevator. Can anyone offer advice?
stevenator128 is offline Find More Posts by stevenator128
Old Apr 19, 2012, 02:28 AM
mudcow007 is offline
Find More Posts by mudcow007
Liverpool, UK
Joined Jul 2006
check the CoG (center of gravity) i "think" its suppose to be 28mm from the leading edge of the main wing
if the CoG is off the plane will either be nose heavy an will want dive all the time or tail heavy where it will want to climb
also check your tail hasnt been damaged an is totally straight, where the servos connect to the control surfaces there are small metal "hoops" that you can adjust to make changes to the elevator/ tail
happy flying!
mudcow007 is offline Find More Posts by mudcow007
Old Apr 19, 2012, 04:14 AM
Joined Oct 2006
added info tlo Mudd's comment...
the tail rudder ifall trim is centered, and metal hook bent. and you checked for 90 degrees. you got a crack on the rudder's foam.
option to replace rudder. or repair with a plastic container, cutting a bigger retagular or square slipping over rudder hurns, glueing . or adding just glue.
the dolphan dance is your CD. add weight of any sort. like a coin dime, nickle, quater, till you get it gone. also makesure the battery id far foward. once you found the sweet spot mark it.
we ll been there, done that.
Old Apr 21, 2012, 10:36 AM
Nighthawk74 is offline
Find More Posts by Nighthawk74
RC addict? I'm not addicted...
Nighthawk74's Avatar
Danmark, Midtjylland, Roslev
Joined Jul 2011
Just adding to Mudd and Fishy's advice. Could be you need some control surface adjustments. Just jump a minute into this clip, and the horizon guy will guide you
HobbyZone Champ Trim Tips (1 min 37 sec)
Nighthawk74 is offline Find More Posts by Nighthawk74
Old Apr 21, 2012, 11:25 AM
Joined Oct 2006
thanks NH74
take steps. something you are overlooking I bet
Old Apr 24, 2012, 10:55 PM
jwp2 is online now
Find More Posts by jwp2
United States, IL, Essex
Joined Feb 2010
I finally got to get out and do some touch-n-goes with the Champ. It sure is nice to be able to just step outside your door and theres a runway. Others might refer to it as a street!
jwp2 is online now Find More Posts by jwp2
Old Apr 25, 2012, 02:41 AM
Liverpool, UK
Joined Jul 2006
fantastic flight last night
well besides my champ still cutting out
very little wind, its the first time i have flown in totally flat calm conditions, so now i see what you all mean when you say the Champ flies its self
fantastic
unfortunately, there was too little light for my 808 camera
Old Apr 25, 2012, 10:12 AM
jwp2 is online now
Joined Feb 2010
Hopefully some new batteries will help with the cutting out.
Old Apr 25, 2012, 04:35 PM
Doug Sipprell is offline
Find More Posts by Doug Sipprell
Elfi Flyer
Doug Sipprell's Avatar
Rock Hill, SC
Joined Oct 2002
Fishy: thanks for the clarification. All this time I thought it was the Dutch Roll!
RD
Doug Sipprell is offline Find More Posts by Doug Sipprell
Latest blog entry: Big Red Cadillac
Old Apr 25, 2012, 05:53 PM
Joined Oct 2006
RD
swiss rolls oh my favorites, never had a dutch roll though Lol
Have you gotten the champ leveled.
Discussion What plane is this? Debolt Livewire Champ-w/short video reacher10 The Builders Workshop 48 Mar 29, 2011 03:20 PM
Discussion Super Champ Restoration x-craft Off-road Cars 48 May 25, 2010 07:48 PM
For Sale Champ (1/8th scale, electric) Maggie Han Aircraft - Electric - Airplanes (FS/W) 12 Mar 19, 2010 08:31 PM
For Sale 2x Ni-Mh batts will fit PKZ or HBZ planes gazza1 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Sep 07, 2009 09:46 AM
Question digital camera for hbz extreme bluescoobydoo Aerial Photography 0 Jul 31, 2005 11:25 AM
