Old Apr 11, 2012, 06:20 PM
leethetreeguy is offline
Find More Posts by leethetreeguy
Fly em if ya got em.
leethetreeguy's Avatar
Winder Ga
Joined Sep 2008
Welcome to the Champsters pdp!!! I agree there are a lot of great people here. And on the off topic champ thread as well. You should come there and introduce yourself. I am positive you will get a warm welcome from all. Happy Flyin.
Lee
leethetreeguy is offline Find More Posts by leethetreeguy
Old Apr 11, 2012, 06:38 PM
fishycomics is offline
Find More Posts by fishycomics
Joined Oct 2006
Here you go, theDX4E Tx sells for a lot less, and can be found all over if researched. the trims are old fashion. if anyone here, am sure will be able to help you, modify the Electronic trims to manual.
Be warned opening your Spectrum, voids your Warranty, no exceptions, from HH
http://www.youtube.com/watch?v=GeqMkr7nEW4
fishycomics is offline Find More Posts by fishycomics
Reply With Quote  (Disabled)
Old Apr 12, 2012, 04:09 AM
SpidarX is offline
Find More Posts by SpidarX
Joined Mar 2012
Onboard with the Champ
I mounted an 808 keychain camera on my champ and have been able to get some decent aerial footage. On this day, there was a pheasant wandering around the field where I fly. I tried to do some low passes to get him on camera. I also got some decent aerial views as the sun was setting on the horizon. Once I upgrade from the stock transmitter, I should be able to get some more height and better vids. Hope you enjoy.
HZ Champ Onboard Camera - Pheasant, Crash, and Sunset over Germany (4 min 15 sec)
SpidarX is offline Find More Posts by SpidarX
Old Apr 12, 2012, 07:31 AM
mudcow007 is offline
Find More Posts by mudcow007
Liverpool, UK
Joined Jul 2006
how do you guys get your champ flying so steady?!
ok granted, the days when there is little or no wind here is as rare as "hen's teeth" but my champ seems to constantly climb unless barely using any throttle. it also seems to porpoise quite a lot
i have added a "waaay" larger battery (E-flite 120SR 3.7V 500mAh) so that would have added quite a bit of weight. The battery is mounted as far back as possible in the battery "slot"
do you think i need to find the CoG an adjust to suit the original?
mudcow007 is offline Find More Posts by mudcow007
Old Apr 12, 2012, 07:41 AM
murdude is offline
Find More Posts by murdude
Joined Jan 2012
I find the trick is to set the power at one throttle setting (I like about 50%) and trim for that setting to maintain level flight.
Murray
murdude is offline Find More Posts by murdude
Old Apr 12, 2012, 08:14 AM
aeronca is offline
Find More Posts by aeronca
The figure "9" Specialist
aeronca's Avatar
A Barrier Island in New Jersey, USA
Joined Oct 2003
Your porpoising could be the result of incorrect COG. Sounds to me with the larger battery all the way back that the plane could be tail heavy. Have you checked the COG?
Aeronca
aeronca is offline Find More Posts by aeronca
Old Apr 12, 2012, 08:48 AM
Liverpool, UK
Joined Jul 2006
Aeronca
not yet but i will do tonight, its really sunny here today (for a change) still a bit breezy - its around 6mph wind)
i have just read that the CoG on the champ is 28mm from the leading edge of the wing
i will install battery an my trusty 808 to see where it is on mine
i will keep you all informed. thanks!
Old Apr 12, 2012, 08:53 AM
olthump is offline
Find More Posts by olthump
Occupying RCG
olthump's Avatar
United States, MS, Ocean Springs
Joined Sep 2009
Mudcow,
Even with a smaller 160/190 size battery, most Champs balance at 28mm with the batt well forward in the slot. In light air when properly balanced the Champ will fly itself and can be manuevered with little nudges on the stick and throttle.
When you find the sweet spot, you'll love it.
olthump is offline Find More Posts by olthump
Old Apr 12, 2012, 10:38 AM
Winder Ga
Joined Sep 2008
Tail heavy causes porposing. Like they all said. Check it. Or do what I do. Land, put the battery further forward untill you find Olthump's sweet spot. LOL
Lee
Old Apr 12, 2012, 12:29 PM
GooberSB is offline
Find More Posts by GooberSB
An Ordinary User
United States, VA, Fluvanna
Joined Jan 2011
Also, too much much down elevator will cause it to porpoise. If it's going up to a stall and then dropping it's tail heavy or too much up elevator. If it's diving until it picks up speed and then climbs out of it a little you should try adding some up elevator until it maintains altitude at the throttle you want.
GooberSB is offline Find More Posts by GooberSB
Old Apr 12, 2012, 02:38 PM
Bluhammer is offline
Find More Posts by Bluhammer
Bay Area Prop Buster
Bluhammer's Avatar
Bay Area CA
Joined Jan 2011
I Fly the Champ a lot with the 120SR 500 battery and it ALWAYS goes all the way forward in the trench! No wonder your going up
Blu
Bluhammer is offline Find More Posts by Bluhammer
Old Apr 12, 2012, 03:39 PM
pugsam is offline
Find More Posts by pugsam
LiPo-Sucker & Airframe EMT
pugsam's Avatar
Charlottesville, Virginia, USA
Joined Aug 2010
Just came in from flying Champ One with nano-tech 300s -- full forward in the battery tray.
pugsam is offline Find More Posts by pugsam
Old Apr 13, 2012, 03:08 AM
Liverpool, UK
Joined Jul 2006
Thanks for all the replies guys
with the battery as far forward as possible an the 808 camera attached to the bottom of the battery it flew much better
one other continuing issue is randomly loosing all controls of my champ, but regaining them after a few (scary) seconds
this can happen with my champ near or far. i keep the tx upright an not pointed at the champ as per instruction on here.
its quite scary seeing my poor champ wandering away.....
anyone had anything similar?
oh new batts in tx an plane too
Old Apr 13, 2012, 04:13 AM
Joined Oct 2006
e fly the champ wit ha DX6I for a smoother control. we practice more than others, and it takes some time to just relaxe.
Trim her, and let her glide see how much smooth control you gots, no full power
Old Apr 13, 2012, 06:36 AM
BlackIce is offline
Find More Posts by BlackIce
Joined Dec 2007
I have, and haven't had the Champ for long. Stock tx.
I have not had the same issue with my Night Vapor or Ember 2.
I thought it may be going out of range because it has never happened to me close.
Or maybe LVC, because It has really only happened to me when I have the 808 attached, and the Champ is WOT for a min or more while climbing.
BlackIce is offline Find More Posts by BlackIce
Discussion What plane is this? Debolt Livewire Champ-w/short video reacher10 The Builders Workshop 48 Mar 29, 2011 03:20 PM
Discussion Super Champ Restoration x-craft Off-road Cars 48 May 25, 2010 07:48 PM
For Sale Champ (1/8th scale, electric) Maggie Han Aircraft - Electric - Airplanes (FS/W) 12 Mar 19, 2010 08:31 PM
For Sale 2x Ni-Mh batts will fit PKZ or HBZ planes gazza1 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Sep 07, 2009 09:46 AM
Question digital camera for hbz extreme bluescoobydoo Aerial Photography 0 Jul 31, 2005 11:25 AM
