This thread is privately moderated by Herb, who may elect to delete unwanted replies.
Old Mar 20, 2012, 01:16 PM
Herb is offline
Find More Posts by Herb
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
I would say yes ! I remember the JHH F-86 flies fine on a 90mm WeMo, and this fan is only slightly larger.
I still think this is a very good fan for the money, bit it absolutely needs to be balanced !!
Herb is offline Find More Posts by Herb
Old Jun 25, 2012, 03:56 AM
bmiller is offline
Find More Posts by bmiller
SoCal, Year Round Flying!
bmiller's Avatar
Newport Beach, CA
Joined May 2002
For fairviews short dirt runway how about more blades to pull air past the radar and thru that loooong duct!
Should give it some extra low speed thrust for the takeoff!
And it'll have that "whoosh" sound too!LOL
Remember your sapac foam hawk shubie vs wemo test flights?
The wemo kicked ass!
Note the time of my post! I got the retracts/struts drilled and assembled for the F100.
Thanks for those 4mm strut wires!
bmiller is offline Find More Posts by bmiller
Old Jun 25, 2012, 01:32 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Yes that sharp intake lip (needed for scale) robs thrust at low speed.
More flight maybe tomorrow (Tuesday) ... ?
I did some maintenance work & cleanup on the nosegear ...
Old Jun 25, 2012, 01:46 PM
bmiller is offline
bmiller's Avatar
Newport Beach, CA
Joined May 2002
Ok for tuesday flying.
Always amazed how stout those springairs are.
btw Probably flying friday at apollo w/Gregg. you in?
Old Jun 26, 2012, 11:27 PM
bmiller is offline
bmiller's Avatar
Newport Beach, CA
Joined May 2002
Pictures came out nice! thanks for posting them on the F-4 thread.
looked at hobbypartz for gens ace packs...out of stock for the size and cell counts I use...
Glad the Mig is flying well after I screwed up the trim sunday....sorry bout that...
Old Jun 28, 2012, 11:57 AM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Yes a few pics came out nice
Old Jun 28, 2012, 10:08 PM
bmiller is offline
bmiller's Avatar
Newport Beach, CA
Joined May 2002
Missed you at the field today. Habu32 instead of F-4 this time.
Vince had a flyfly F-100 which he flew so I got to check out his 6S setup and pester him with build questions/mods. Thing flys great on 1800W and floats in. Inspired to try finish mine by this weekend!
Old Jul 06, 2012, 11:11 AM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Too bad I missed the F-100 ... Sprayed another can of tamiya red on the MiG-21
Old Jul 08, 2012, 01:39 AM
bmiller is offline
bmiller's Avatar
Newport Beach, CA
Joined May 2002
Herb,
Here's the battery IR "true C" calculator website I use in conjunction with my ESRmeter.
http://www.jj604.com/LiPoTool/
Old Jul 08, 2012, 01:20 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Thanks for the link ... the guy is a bit confused about the relationship between pack impedance Z (IR) and C rating.
It's not what he claims, it's significantly more complex.
IR is a completely well defined number: The battery's internal resistance Z you can just compute from the battery voltage drop,
V0 - V = I * Z
V= voltage under load, V0 voltage with no load (eg. 4.20 V on a charged 1S pack), I current under load, Z = battery impedance (at 0 Hz) or pack "internal resistance" . This is basically a modified Ohm's law: http://data.energizer.com/PDFs/BatteryIR.pdf
As an example, if on a fully charged 6S pack your voltage drops from 25.2V to 22.2V under a full load of 80A as measured by your Watt meter (each cell is then dropping from 4.20V to 3.70V, so that 0.50V* 6 =3.0V) then the internal resistance is
Z = 3.0V / 80A = 0.0375 Ohm = 37.5 m Ohm ( per cell that 6.25 mOhm).
It's as simple as that. This is what your device (that grey box) measures, but a pocket calculator will give you exactly the same number ...
(In fact the watt meter / pocket calculator combination will give you a more accurate number, relevant for an 80A load as opposed to the mA load your grey box uses, simply for the reason that the IR is weakly dependent on current ...)
C rating on the other hand is more complex and subjective. What current can the battery sustain w/o damage? That depends on the quality of the electrolyte, by how thick the copper film is inside the battery, how thick the pcb's and cables are etc. That is the reason why C ratings are all over the place. e.g Some just slap on a thicker wire and calls it 40C ...
Nevertheless a battery with a lower Z/IR will get less hot, delivers a bit more punch (more current), blows your motor and esc earlier and hopefully also lasts a bit longer because it gets less hot ...
Personally, if I need more power I just use a bigger battery instead of screwing around with IR's
Old Jul 08, 2012, 10:08 PM
bmiller is offline
bmiller's Avatar
Newport Beach, CA
Joined May 2002
Thanks for the detailed info..very informative!
Unlike most other gadgets out there, the ESRmeter applies (IIRC) a 30A draw for it's pack numbers to give a more real world IR reading.
It may apply a mA load for individual cells...I'll have to check that.
Anyway it's a great aid for us non physics professors!LOL
Regardless I still believe in under 20C draws from any battery so I TRY (but sometimes fail) to use that as my guide for pack size.
Old Jul 13, 2012, 12:07 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
I should really finish up the Mig-21
Clearcoat applied :
Old Jul 20, 2012, 08:26 PM
bmiller is offline
bmiller's Avatar
Newport Beach, CA
Joined May 2002
Shiny!
F-100 ready for tomorrow!
Old Mar 17, 2013, 07:31 AM
juanjulian is offline
Find More Posts by juanjulian
juanjulian's Avatar
Guatemala, Guate
Joined Jul 2007
Herb
Thhanks for posting your build, and viedos. I have enjoyed it a lot.
Bought the plan several years ago, and not sure how air worthy it was.
The first landing was perfect....
Cheers
Juan
juanjulian is offline Find More Posts by juanjulian
Old Mar 17, 2013, 12:34 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Hi Thanks
The MiG-21 is a nice flier once dialed in properly (CG, throws, expo). It's just not an aerobatic plane ...
The main thing about building from plans is to build it LIGHT: select components with a postal scale, weigh every part and use lightweight glues, fillers, paints and fiberglass cloth where you can. This is absolutely crucial in an edf.
Large turbine MiG-21's fly nicely too, see youtube under Airworld MiG-21
Build Log MiG-21 "Fishbed" Park Jet beanie Pusher Prop Jet Models 3280 May 19, 2016 02:33 PM
Mini-HowTo Mig-21 Fishbed Build cdebaca Pusher Prop Jet Models 152 Aug 16, 2006 09:06 PM
Mig-21 "Fishbed" Fanfold Build J Morgan Pusher Prop Jet Models 188 Nov 04, 2005 12:12 AM
Help with CG on Mig-21 "Fishbed"? J Morgan Electric Ducted Fan Jet Talk 5 Jul 06, 2005 07:55 PM
MIG-21 FishBed leesops Electric Ducted Fan Jet Talk 22 Sep 13, 2003 12:31 PM
