This thread is privately moderated by Herb, who may elect to delete unwanted replies.
Old Sep 21, 2010, 12:12 PM
corsair nut is online now
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
turned out very nice herb. i look forward to seeing her fly in so cal some time.
corsair nut is online now Find More Posts by corsair nut
Old Nov 19, 2010, 01:07 PM
Herb is offline
Find More Posts by Herb
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Thanks for the comments
Well the anticipated maiden did not take place yet since the taxi test at the field resulted, at the end of a 5-min test run on the ground, in a shorted 1515-1.5 motor (on 9S 4000's , 94A measured, 2900W measured), a blown brand new 100A controller due to the shorted motor, and a fire in the plane that reduced most of the rear servo wiring to charcoal ...
Luckily that was all the damage as we got the batts quickly out of the plane in seconds (one of them sits right next to the esc)...
Now I got a second brand new 120A TGY HV HK controller (the poor thing got initially blamed for the fire, but now I think it had nothing to do with it), the 1515 motor still fibrillates, I redid the servo wiring, and finally need to do major surgery to get the fan & motor out (which clearly has a short in one of the three Y's). The 1515-1.y will then go back to Steve Neu ...
Looking at the long can HET 700 motors as an alternative to get the MiG-21 into the air, eventually.
Herb is offline Find More Posts by Herb
Old Nov 19, 2010, 01:18 PM
CORONA EX is offline
Find More Posts by CORONA EX
CORONA EX's Avatar
Joined Nov 2003
You need a good test pilot!!!!
CORONA EX is offline Find More Posts by CORONA EX
Old Nov 19, 2010, 02:11 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Need to fix the motor problem first before we break the sound barrier.
Old Nov 19, 2010, 08:03 PM
CORONA EX's Avatar
Joined Nov 2003
Now all you need to do it get a proper radio!!!!
JR12X!!!!
Old Nov 28, 2010, 07:05 PM
pencon is offline
Find More Posts by pencon
Joined Dec 2008
Awesome Mig 21, I have the het version (unfinished) . Is this from the plans they sell on ebay? Looks a lot like it ..
pencon is offline Find More Posts by pencon
Old Nov 29, 2010, 01:35 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Yes it is ... see post no. 1
http://cgi.ebay.com/RC-plans-Giant-D...item20b550b371
Old Dec 10, 2010, 01:26 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Shorted (?) Neu 1515-1.5 going back to Neumotors, no visible sign of any malfunction from the outside ...
MiG-21 taxi test was at 94A, 9S 4000's, 2940W initially (hot off the charger).
Old Dec 10, 2010, 05:02 PM
gtfreeflyer is offline
Find More Posts by gtfreeflyer
Put a bigger motor on it!
gtfreeflyer's Avatar
Costa Mesa, CA
Joined Feb 2007
94A for taxiing. Gotta love trying to drive around on Fairview's "runway" You'll probably pull less amps in flight. Let me know when you plan first flight so I can come videotape it
gtfreeflyer is offline Find More Posts by gtfreeflyer
Old Dec 11, 2010, 01:04 AM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Jonathan ... it had been planned as a dry run
To test how hot the esc & motor would get, I was concerned about the esc not getting enough cooling, check the steering & general ground handling - all things easier to do at a local field than at home The MiG was airborne after I hit the first bump.
It was agood thing that the short & fire happened on the ground and not in the air.
The maiden is planned possibly at Prado or some other location with a nice long runway - when I get a New motor ...
Old Dec 29, 2010, 02:08 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Shorted Neu 1515 motor sent in on Dec 10 ... three weeks gone by, two e-mails, no reply ...
I ordered a HET 700-68 motor, similar to Neu 1515 (actually "same as Neu", whatever that means in China ), got it in three days EMS shipped from HongKong (free shipping).
New 120A HV controller (old one caught fire when the Neu shorted), re-programmed for "no brake", "slow start" , "low lipo cutoff", low advance (7 deg) & low PWM freq (4 pole inrunner as Neu).
Mounted it in the fan, checked the rotor balance one more time, installed it in the MiG-21 ... I think it's ready to go.
I used aluminum pieces to balance that rotor, man that thing is so out of balance. Now it seems smooth as silk, we'll see
Old Dec 29, 2010, 02:34 PM
Costa Mesa, CA
Joined Feb 2007
Sounds great Herb. Now, can you please do something about this rain? You may need to build some floats for this plane.
Old Dec 29, 2010, 03:00 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Jonathan, the forecast for Dec 31 2010 & Jan 1 2011 looks pretty good
http://www.accuweather.com/us/ca/los...t-weekends.asp
Old Jan 06, 2011, 04:29 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
... After three weeks finally got a call from NeuMotors service. Stator shorted out due to a manufacturing defect, they will replace complete stator under warranty. I should see my 1515-1.5y motor back at the end of the month
Old Feb 05, 2011, 08:10 PM
CORONA EX's Avatar
Joined Nov 2003
Awesome jet herb!!!!!!! Where is the video?
Build Log MiG-21 "Fishbed" Park Jet beanie Pusher Prop Jet Models 3299 Yesterday 12:22 PM
Mini-HowTo Mig-21 Fishbed Build cdebaca Pusher Prop Jet Models 152 Aug 16, 2006 09:06 PM
Mig-21 "Fishbed" Fanfold Build J Morgan Pusher Prop Jet Models 188 Nov 04, 2005 12:12 AM
Help with CG on Mig-21 "Fishbed"? J Morgan Electric Ducted Fan Jet Talk 5 Jul 06, 2005 07:55 PM
MIG-21 FishBed leesops Electric Ducted Fan Jet Talk 22 Sep 13, 2003 12:31 PM
