This thread is privately moderated by Herb, who may elect to delete unwanted replies.
Old Jul 30, 2010, 07:33 PM
Herb is offline
Find More Posts by Herb
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
I decided to finish up, connect and attach the wings and stabs before finishing the top and bottom planking ... easier to work with and way too many wires and airlines to route.
Also, this allowed me a cleaner (sturdier) nosegear install
Herb is offline Find More Posts by Herb
Old Jul 30, 2010, 07:37 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
I checked the static fan rotor balance one more time on my $3 magnetic balancer, and then went ahead and installed the fan (semi-permanently) in the MiG-21 fuse ...
Old Jul 30, 2010, 07:45 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Once the Springair retracts were installed and tested, she was ready for one more picture:
Old Aug 14, 2010, 03:08 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Finishing up the planking,
Old Aug 14, 2010, 03:16 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Fiberglassing ...
I use 48g (3/4 oz) lightweight glass cloth for the front half of the fuse, and 18g ultralight weight cloth for the tail part. I got this excellent cloth from HC.
I apply the Z-Poxy laminating (finishing) resin with a disposable brush. I don't like spreading resin with a credit card like you are applying peanut butter ...
I heavily dilute the resin with propyl alcohol to save weight, undiluted resin adds a ton of weight and serves no purpose. The alcohol evaporates within a matter of minutes.
I fill the weave with krylon primer, which is a lot lighter and easier to sand than laminating resin (which is shell hard).
Old Aug 18, 2010, 11:39 PM
bidule is offline
Find More Posts by bidule
jean-claude Terrettaz
bidule's Avatar
Carp, Ontario, Canada
Joined Mar 2000
The Mig look impecable, well done Herb...
I'm flying mine saturday on a sod farm, let you know.
bidule is offline Find More Posts by bidule
Old Aug 20, 2010, 02:48 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Thanks JC ... don't know about impeccable , seems a never ending story.
Good luck on you sod farm overflight
Old Sep 04, 2010, 02:14 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Paint, sand ... more paint, more sanding
Hinged all surfaces & installed linkages ...
Old Sep 04, 2010, 10:57 PM
bidule is offline
bidule's Avatar
Joined Mar 2000
Again very nice Herb, I like the color. You are a great builder and I know you can fly those jets....
J-C
Old Sep 05, 2010, 10:13 PM
XPHAM is offline
Find More Posts by XPHAM
HUNTINGTON BEACH, CA, USA
Joined Feb 2000
The Delta 21 is a beauty...!!
XPHAM is offline Find More Posts by XPHAM
Old Sep 06, 2010, 02:59 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Thanks for the comments ... it might even fly ... someday
Old Sep 09, 2010, 04:39 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
I closed the hinge gap on all surfaces, to give a cleaner wing profile, and prevent flutter. I made the covers out of cheap drafting mylar.
The various linkages still need to be adjusted for travel (ie hole choice to give max mechanical advantage & least epa reduction).
I also made a foam plug for the fibegrlass linkage covers.
Old Sep 17, 2010, 04:42 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
The MiG-21 "bottom work" is almost finished.
Tested the Springair retracts & steering, installed the tail sub-fin, cut out the cavernous wheel well openings, & touched up the paint a bit.
Old Sep 17, 2010, 04:50 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
The top hatch is long enough to allow plenty of batteries to slide in there.
Unfortunately the batts have to go all the way forward, and into the cockpit area, to get the CoG right. Very cramped in there ...
The nose shock cone is, for now, removable.
Old Sep 18, 2010, 07:24 PM
CORONA EX is offline
Find More Posts by CORONA EX
CORONA EX's Avatar
Joined Nov 2003
Looks good Herb!!!! Now where is the radio so I can test fly that bad boy!!
CORONA EX is offline Find More Posts by CORONA EX
Build Log MiG-21 "Fishbed" Park Jet beanie Pusher Prop Jet Models 3270 Jan 18, 2016 10:39 PM
Mini-HowTo Mig-21 Fishbed Build cdebaca Pusher Prop Jet Models 152 Aug 16, 2006 10:06 PM
Mig-21 "Fishbed" Fanfold Build J Morgan Pusher Prop Jet Models 188 Nov 04, 2005 01:12 AM
Help with CG on Mig-21 "Fishbed"? J Morgan Electric Ducted Fan Jet Talk 5 Jul 06, 2005 08:55 PM
MIG-21 FishBed leesops Electric Ducted Fan Jet Talk 22 Sep 13, 2003 01:31 PM
