what a dangerous thread you have started here. Since reading it first time a few months ago, I have managed the locate and purchase the wonderful Sonic Liner (which I had never heard of before), and now the TwinJet ![]() ![]() ![]() Like the Sonic Liner, I will build and fly the TwinJet. Probably with modest power 2122mm outrunners and counter rotating props. As far as I can see, the wing profile of the TwinJet is designed for more lift / lower speed than the FunJet... EDIT: I read somewhere that the recommended CoG point is at bit too far aft for most pilots liking. Would 1 cm further forward be better? THX I stumbled over this nice, old video when searching for CoG info:
Jürgen
Latest blog entry: 12th. German- / 1st. European Indoor...
United States, NY, New York
Joined Nov 2012
the reason it looks like it has alot of reflex is because it doesnt have any control horns/rod or servos installled . so it just stood up like that in the photo . once i installed back the electronics i will massage the reflex to be straigt. as for paint . i just used miniwax. over the stock gray .then i painted it and and put another coat of miniwax .
i want a white one so i can do a different paint scheme |
You might be able to save a small amount of drag by flattening them out but unless you're going for a speed record, I suggest leaving them alone. This is a fairly draggy airframe regardless. |
Joined Nov 2012
S.F. Bay Area
Joined Aug 2002
My TJ flew ballistic (read that vertical) with slight up input.Full down could barely keep it level.Yes,there was carnage.
I suspected thrust angle & reflex so I flattened the reflexed elevon and re-mounted the motors to adj. the thrust angle (using short lengths of tubing for visual reference) to parallel with the chord line. Flew a dream afterwards. In the early days after the TJ's release there was a couple vids that blew me away.This is from those vids! One was a fellow flying along side or in front of a boat as it cruised a waterway.about 5-7 min long IIRC.I would guesstimate 5-15 mph speeds.All caught on camera from behind the pilot.Right up to the landing (or catch?) in the boat. The there was the vid flying around a fountain,The pond,IIRC was a large circle in & above ground maybe.The singular fountain streamed about 40' in the air around 10-20 degrees from vertical forming a pleasant arc.This TJ pilot fly around the fountain,through the arc and thru the water stream! It was Great!. Alas,all lost on a HDD far far away. Skies Jay. |
Jürgen
| Thread Tools | |
| Discussion Where do you find your kits?? | kfreak | Fuel Warbirds | 23 | Mar 28, 2010 01:22 PM |
| Poll Aurora 9 owners, Do you want rx's included with Multiplex planes so you can bind n fl | vhoward1122 | Radios | 22 | Mar 25, 2010 09:46 AM |
| Discussion Dremel tool...which one do you like? | slappySF | The Builders Workshop | 32 | Feb 12, 2010 01:26 PM |
| Poll Infrared Thermometers: which one do you use? | Bing44 | Electric Plane Talk | 10 | Jan 19, 2010 08:35 PM |
| Poll Which one do you like best? | xxxvizard | Mini Helis | 4 | Oct 14, 2009 05:19 PM |
