Old Feb 12, 2012, 09:05 PM
freshmint is offline
Find More Posts by freshmint
Joined Nov 2011
Download the program it will tell you which firmware you have
freshmint is offline Find More Posts by freshmint
Old Feb 14, 2012, 02:22 PM
melsailsnorth is offline
Find More Posts by melsailsnorth
Fight for the Right to FPV!!!
melsailsnorth's Avatar
United States, CA, Chico
Joined Dec 2010
EZUHF and RSSI feeds
I just purchased my new EZUHF and am preparing to take the plunge into LRS>
I'm excited about the prospect of having RSSI information on screen to monitor the status of reception, but I use another OSD besides EZOSD. I'm wondering if the only option is to try one of those "digital to analogue" mods to convert the digital RSSI signal coming from the EZUHF receiver, or if anyone out there has met with success getting an RSSI measurement using other OSD's such as EagleTreeOSD, Skylarks, or any of the many others that are needing an analogue signal. I realize the short and easy answer is to ditch my current osd and move to EOSD, but it would seem that this would be a common dilemma for many, and I would not think that immersionrc would want to dissuade those that want to use EZUHF just because they might be partial to another OSD. As such,I was hoping this might have been addressed by someone at Immersion and (if not) if someone could help me to understand my options for getting an RSSI reading. In my searches I've seen this same issue addressed with all the other LRS manufacturers but still have not found anything from immersionrc. Any help appreciated!!
melsailsnorth is offline Find More Posts by melsailsnorth
Old Feb 14, 2012, 03:17 PM
Moelich73 is offline
Find More Posts by Moelich73
Bazinga!
Moelich73's Avatar
South Africa, KZN, Durban
Joined Feb 2007
I use EZUHF with the DragonOSD and bought a tiny unit which converts the RSSI/Link QUality signal. I'll PM you the link to the thread where you can find more info about it.
Moelich73 is offline Find More Posts by Moelich73
Old Feb 15, 2012, 03:43 PM
ov3rmind is offline
Find More Posts by ov3rmind
United States, NJ, Millburn
Joined Sep 2011
Is there a place I can buy the EZUHF system as a kit -- dragonlink style, or do I have to piecemeal this thing myself? Presumably there should be a kit out there that's in stock and for a better price than individual components. Maybe I'm missing something. Also, nobody seems to have it in stock in the US?
ov3rmind is offline Find More Posts by ov3rmind
Old Feb 16, 2012, 01:28 PM
dr_patso is offline
Find More Posts by dr_patso
N00b
Boise
Joined Mar 2009
It's not hard to piece together!
http://www.readymaderc.com/store/ind...roducts_id=181
http://www.readymaderc.com/store/ind...roducts_id=179
http://www.ebay.com/itm/Diamond-SRH7...item19cd85e694
^^ for TX
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXJGU7
http://www.ebay.com/itm/10pcs-RP-SMA...item256956ad75
if you are confused about what wire to use..
http://www.ebay.com/itm/JRPA170-Rece...item336f5f5716
Here is the guide for building the monopole antennas
http://www.rcgroups.com/forums/showthread.php?t=1413650
it's really easy, just get a fine tip solder for like 8$ at radio shack.. I did and I'm honestly really dumb.
PS: I hope you roll with purple antennas because of this effort... Also I still feel like the antennas should be provided, but it's kind of worth it, especially now with the lower price... I got an ezuhf just a month or so ago and I had a diamond 771 from over a year ago because I got too impatient and wasted my money on something that made me wish i had the ezuhf.
dr_patso is offline Find More Posts by dr_patso
Old Feb 16, 2012, 01:30 PM
dr_patso is offline
N00b
Boise
Joined Mar 2009
for better support go to F-P-V-L-A-B
Old Feb 19, 2012, 04:59 PM
LexusFPV is offline
Find More Posts by LexusFPV
TBS Crossfire or DragonLink?
Joined Feb 2011
correction, found it......
LexusFPV is offline Find More Posts by LexusFPV
Old Mar 06, 2012, 03:42 PM
carlocivicsi is offline
Find More Posts by carlocivicsi
United States, FL, Miami
Joined Mar 2012
question.
i have a dx8 radio and I've seen online (youtube video)
Connect EzUHF to Spektrum Dx6, Dx7, or Dx8 (6 min 38 sec)
how people connect them to the ezuhf tx. my question is i have already a cable that goes from male ps2 connection to 1/8 (3.5mm) stereo jack that fits in the back of my dx8 trainer port.
that cable came with the fatsharks that i bought.
(http://www.readymaderc.com/store/ind..._image&pID=676)
will that cable work with the dx8 and ezuhf?
carlocivicsi is offline Find More Posts by carlocivicsi
Old Mar 06, 2012, 08:00 PM
scrape is offline
Find More Posts by scrape
Joined Mar 2006
THIS is what the DX8 cable looks like.
Yours looks like a stereo plug instead of mono, it might still work.
Here what I use, works fine.
scrape is offline Find More Posts by scrape
Old Mar 07, 2012, 09:56 AM
Joined Mar 2012
on the power cable. how do you know which one is positive and negative?
Old Mar 07, 2012, 10:11 AM
_ELLIOT_ is offline
Find More Posts by _ELLIOT_
Team Flying Pirates
_ELLIOT_'s Avatar
Joined Nov 2011
today my 2 ez uhf arrived....
one question:
is an half wave dipole better than the sanderstyle antennas??!?
can i build the "sanders" using a coaxial cable between sma connector and the antenna?
_ELLIOT_ is offline Find More Posts by _ELLIOT_
Old Mar 07, 2012, 04:13 PM
scrape is offline
Joined Mar 2006
From the MANUAL
EzUHF Transmitter
Powering the transmitter
The EzUHF transmitter has two flexible power options. Both of which may be used for additional
redundancy:
1) Power supplied via the 4-pin mini-din connector.
In the case where the transmitter is connected to a futaba radio, with 9.6v, or 3s Lipo power
source, this is the preferred method of powering the transmitter.
2) Power supplied via the DC power jack.
In cases where the R/C transmitter either doesn’t provide power via its trainer connector, or
when a lower voltage is available (2s radios for example), it is preferred to power the EzUHF via
the DC power jack.
The power jack is center-pin positive, 2mm internal pin, 5.5mm outer diameter.
A suitable plug is Mouser #502-S760BK
NOTE: The EzUHF transmitter may safely be powered via both connectors simultaneously, even if two
different voltages are presented.
I used a Continuity Tester to find the center pin and connected it to the positive (red wire) on the battery plug.
Old Mar 07, 2012, 10:14 PM
Rrated is offline
Find More Posts by Rrated
Rrated's Avatar
United States, NJ, Ocean
Joined Aug 2011
Warning !!! With your DX8 ?!? I have flown over 6 miles with my dx6i but wanted more channels so i bought a dx8 .I have been doing differnt thing with both my planes but yesterday flying I couldnt go past a mile then even half mile my video was great but my RTH was activating alot !!! I have been thinking all day W-T-F but about an hour ago i grabed a volt meter to check my ppm signal volts . At first I pug it in to the controler and it was
3.12 plug it in
2.13 after 1min
1.18 after 2 min
.89 after 3 min
.24 after 4
.16 after 5 min !!!!!!!!!!!!! Then pluged in my DX6 I 2.81v almost steady for 5 min
please some one else check theres before flying ! Thanks
Rrated is offline Find More Posts by Rrated
Old Mar 11, 2012, 01:17 PM
_ELLIOT_ is offline
Team Flying Pirates
_ELLIOT_'s Avatar
Joined Nov 2011
today i tested my new ez uhf mounted on my futaba 6ex with stock cable.
after 5 flight with bad performance (10km @ 200mw = failsafe) I smelled something burning....
and after a few minutes my ez, has stopped working properly.
works, but much warmer and the range has been drastically reduced (about 500m).
I tried to unscrew the lid but the part that heats up is not visible, the card itself seems to be heating up. ... ok .. I do not understand anything about electronics but I have mounted several successful lrs without problems.
how can I do? I checked the antenna on rangelink but a friend of mine works perfectly.
Old Mar 11, 2012, 02:39 PM
gtaero is offline
Find More Posts by gtaero
Joined Mar 2012
EzUHF Rx OSD Link Cable (RSSI)
Have just bought EzUHF Tx & Rx - Both Installed, paired and working ok - BUT
EZUHF Rx has an OSD Link Cable which plugs into rx but the tinned wires at the other end have to be 'spliced' into the EZOSD cable going from Battery Sensor to OSD.
The wire colours are different.
Can someone tell me which colours to splice to which colours - PLEASE.
gtaero is offline Find More Posts by gtaero
New Product Long Range UHF RC system now avail on STOCK thomasscherrer FPV Equipment 14079 Jul 27, 2016 05:58 PM
Discussion First FPV application for the iPhone, decode EzOSD Telemetry : Beta Now Available! ImmersionRC FPV Talk 107 Sep 09, 2011 09:37 PM
Discussion EzUHF, the full duplex long range link with FHSS and diversity ssassen FPV Talk 304 Feb 23, 2011 02:48 AM
For Sale Hitec Mini 6s Extra Long Range Receiver Flyin Brick Aircraft - General - Radio Equipment (FS/W) 1 May 22, 2010 09:54 PM
Discussion Your Long Range FPV Heli Dream Set Up ? djdaveq FPV Talk 2 Feb 26, 2010 12:55 AM
