Old Mar 23, 2010, 11:14 PM
CooHead is offline
Find More Posts by CooHead
Don't watch this...
CooHead's Avatar
Northern IL
Joined Oct 2003
A50-16S max amps/watts?
I have this motor in my 68" Velox and 6S voltage.
It is the recommended and works great with a 18x8 prop (APC)
I'm at 70ish amps and 1600+watts.
Can I go to 18x10 and 79ish amps and 1750+watts?
I'm talking APC here. Maybe I should try some wood props to drop the amps a bit.
I have the ICE100
The specs for the motor is like 1250watts. But everybody runs them on this size plane and over amps them a ton. Mine doesn't get hot so guess it's OK.
But 18x8 and 70amps and 1600watts max for it?
Can I go 80amps and 1800watts with it?
How far over is to much with this A50-16S?
CooHead
CooHead is offline Find More Posts by CooHead
Old Mar 23, 2010, 11:36 PM
sun.flyer is offline
Find More Posts by sun.flyer
Test your skills....fly IMAC!!
sun.flyer's Avatar
Swanton, Ohio
Joined Feb 2005
An 18 x 10 APC E prop on 6s is just fine with this motor..........no worries.
Tim
sun.flyer is offline Find More Posts by sun.flyer
Old Mar 24, 2010, 01:35 AM
G.P. is offline
Find More Posts by G.P.
iumop ap!sdn w,I
G.P.'s Avatar
Canada, AB
Joined May 2005
Why does Hacker de-rate their motors so much? Even their team members post about proping up to watts that are almost double what they publish. Is it just to get out of warranty claims? It sure makes it a pain in the when trying to find the right motor for an airframe.
G.P. is offline Find More Posts by G.P.
Old Mar 24, 2010, 02:34 AM
blucor basher is offline
Find More Posts by blucor basher
ExtremeFlight - 3DHS - Legacy
blucor basher's Avatar
United States, TX, Tyler
Joined Jun 2003
Why does Hacker-Germany (where the ratings come from) do SO many weird things? Why ask why?
blucor basher is offline Find More Posts by blucor basher
Old Mar 24, 2010, 04:29 AM
Azarr is offline
Find More Posts by Azarr
RIP Azarr - "Old age is not for sissies"
Azarr's Avatar
Dayton Intl, Ohio, United States
Joined Jan 2000
All I know is that when I told Ranier Hacker at Toledo that I was running a A30-10XL at 65A, 1000W he just shook his head and sort of cringed. Motor was out in the breeze in a 60" flat foamy bipe and never got warm. Of course, it was hardly ever at full throttle.
Azarr
Azarr is offline Find More Posts by Azarr
Old Mar 24, 2010, 04:53 AM
simon737 is offline
Find More Posts by simon737
Triple boxed goodness!
simon737's Avatar
United Kingdom, Doncaster
Joined Sep 2008
I have the A50-16s with the ICE 100 on a Xoar 18x10 flying my 68" Velox, no problems here.
simon737 is offline Find More Posts by simon737
Old Mar 24, 2010, 04:59 AM
sun.flyer's Avatar
Swanton, Ohio
Joined Feb 2005
Ditto
Old Mar 24, 2010, 07:30 AM
CooHead is offline
Don't watch this...
CooHead's Avatar
Northern IL
Joined Oct 2003
Thanks peoples.
I'll sharpie the 18x10 black and try it at lunch today.
Each flight I put my finger in the cowl and rest it on the motor whilst I take the battery out. With the 18x8, it was never hot. I'd put 3100-3300 back into the 6S5000 after seven minute flight, so if all's well, I should be able to take a couple more amps/watts out of my present set up.
18x8 is fine and runs good. Just when I'm hovering and "backing up" by lowering it to the ground, tail first and have to abort at WOT...it is pretty sluggish. But I understand it's a 8-9pound plane and isn't going to rocket away like my little Slick does. Just thought a bit more power/pitch might be good.
WOT on level pass is fast, but seems to max out by the pitch of the prop and seems to "need another gear."
Coo
Old Mar 24, 2010, 08:30 AM
Azarr is offline
Azarr's Avatar
Joined Jan 2000
Originally Posted by sun.flyer View Post
Ditto
Cool, my Velox is in the Basher's trailer waiting to meet me in Toledo, I have the A50-16S with the Hacker 80 3D esc patiently waiting. (not that regular flying season ever comes to OH this early anyway )
Azarr
Old Mar 24, 2010, 08:39 AM
simon737 is offline
simon737's Avatar
Joined Sep 2008
Be interesting to see how you like the X80, I wasn't that keen on the throttle response/acceleration with it and swapped it out in the end for the ICE.
Old Mar 24, 2010, 11:17 AM
BoneDoc is offline
Find More Posts by BoneDoc
Team 3DHS
BoneDoc's Avatar
San Antonio, TX
Joined Sep 2004
Why ask why?
Isn't that a beer commercial from way back when?
BoneDoc is offline Find More Posts by BoneDoc
Old Mar 24, 2010, 01:16 PM
G.P. is offline
iumop ap!sdn w,I
G.P.'s Avatar
Canada, AB
Joined May 2005
You just have to play with your throttle end points, and throttle curve to make it more linear. I agree that it really sucks and makes the plane feel under powered stock. All of the power is in the last 10% of the throttle stick movement.
Old Mar 24, 2010, 01:27 PM
CooHead is offline
Don't watch this...
CooHead's Avatar
Northern IL
Joined Oct 2003
Hey Boyz.
I flew it at lunch.
Much better and stronger.
In the shop with 18x10 it was about 80amps and 1800watts.
With 18x8 is was just over 70amps and 1600+ watts.
Motor did not get much over warm.
I'm posting a vid of it in "Electric Vid" section....gimmie another ten minutes for it to load.
Thanks for your help here.
Coo
Old Mar 24, 2010, 01:47 PM
CooHead is offline
Don't watch this...
CooHead's Avatar
Northern IL
Joined Oct 2003
http://www.rcgroups.com/forums/showt...2#post14680774
Old Mar 24, 2010, 07:08 PM
Azarr is offline
Azarr's Avatar
Joined Jan 2000
Good to know, If it's a problem I'll swap it out, but I'd rather not have to.
Azarr
Sold Hacker A50-16S outrunner cje0114 Aircraft - Electric - Power Systems (FS/W) 3 Mar 13, 2010 11:27 PM
Discussion Watts or Amps? 4Dim Power Systems 21 Mar 05, 2010 09:40 AM
Sold Hacker A50-16S & Jeti Spin66 mr.pickle Aircraft - Electric - Power Systems (FS/W) 2 Feb 28, 2010 12:55 PM
Wanted Hacker A50-16S jsc Aircraft - Electric - Power Systems (FS/W) 2 Oct 06, 2009 03:45 PM
Sold Hacker A50-16S (sold) & Jeti 70A for 3DHS 70" tai626 Aircraft - Electric - Power Systems (FS/W) 2 Sep 25, 2009 05:55 AM
