Espritmodel.com Heli Air
Old Mar 23, 2010, 10:07 PM
bashing on vancouver island
veggieslinger's Avatar
Joined Sep 2008
neep help finding screws for a metal gear servo
i stripped my only screw for a tower hobbies metal gear servo and cant seem to find replacements. i would like to come across different lengths if possible. im also going to assume the thread type for mg servos is mostly the same. any help is great. funny how one little screw can mean the difference between go and no go.
veggieslinger is offline Find More Posts by veggieslinger
Old Mar 24, 2010, 12:03 PM
Joined Mar 2010
usually for mg servos, a machined thread screw (not a self tap in), that is 3mm wide will work. for example a 3x6mm or a 3x8mm button head screw will work.
robitronic_usa is offline Find More Posts by robitronic_usa
Old Mar 24, 2010, 06:48 PM
Joined Sep 2008
okay so i measured the width and it is 2mm. now im not sure if there are different thread pitches for different brand servos or if there is a common thread pitched used.
Old Mar 25, 2010, 12:02 PM
Joined Mar 2010
most standard size servos from ko, jr, hitec, futaba use a 3mm screw. but if it is a mini or micro servo, than they sometimes use a smaller screw. i myself, have never used a tower hobbies servo, so they could be using a different screw for the servo.
Old Mar 25, 2010, 12:30 PM
Retired CFI Helicopter
Hughes500Bob's Avatar
Southeast PA
Joined Jun 2007
http://www.mcmaster.com/#screws/=6dg2jf
If you can't find it here ... it probably does not exist.
Are you talking about the control horn/arm retaining screw, or one of the 4 case screws?
Hughes500Bob is offline Find More Posts by Hughes500Bob
Old Mar 25, 2010, 01:29 PM
Joined Sep 2008
yes im talking about the screw that holds the control horn onto the servo.
Question JR DS285 servo conversion to metal gear mediclavina Electric Heli Talk 3 Mar 18, 2010 06:22 PM
Sold 3 metal gear cordless digital servo HeliPro5 Aircraft - Electric - Power Systems (FS/W) 0 Mar 10, 2010 07:31 PM
Discussion Fusonic (MG-A-9G) 9g Metal Gear Mini Servo... are they any good? nathan089 Mini Helis 0 Mar 01, 2010 03:50 AM
Sold Du-Bro Sheet Metal Screws NIB 32 screws for $3.00 shipped jodini Aircraft - General - Miscellaneous (FS/W) 2 Jan 11, 2010 12:43 PM
Wanted Servo Arm Screw-DSV130 3-Wire Digital Servo Metal Gear by ParkZone Yablonsky Aircraft - General - Radio Equipment (FS/W) 0 Nov 23, 2009 02:00 PM
