No mixing required. Just use Throttle Curve. Set the Position 1 curve to 0-0-0 and select the switch you want to use for hold using SW SELECT.
With the 9303 this works for both heli and plane mode. |
Latest blog entry: Polaris Aileron Pushrods
And thanks for the ideas re nitro model throttles. I will try setting up a momentary kill switch as you suggest. |
My conclusions are the same. However, I find that setting throttle to 0% in the TRIM STEP menu makes throttle trim inoperative. This seems to me to fix the problem you identified regarding the use of a 0% throttle curve as a throttle hold technique for fixed wing (the problem being that raising the trim could make the motor start). Do you see any problems with this approach? As I said earlier, I never use throttle trim for electric models under normal circumstances. |
| Thread Tools | |
| Discussion Differences between Dx7 and JR 9303/9503 | John63 | Hand Launch | 15 | Sep 10, 2010 09:03 PM |
| Question JR9503 throttle hold for planes? | bhoges17 | Radios | 3 | Mar 08, 2010 03:34 PM |
| Question 9303 throttle hold/cut for electric plane | PatternFlyer | Radios | 3 | Mar 20, 2009 03:50 PM |
| Discussion How to Program a throttle hold switch on 9303 for electric planes | sneasle | Radios | 14 | Mar 19, 2009 04:53 PM |
| Discussion JR 9303 / DSX9 - changing directions of throttle hold? | Drachenstein | Radios | 2 | Feb 26, 2009 06:01 AM |
