Old Mar 23, 2010, 05:54 PM
jbc is offline
jbc
Find More Posts by jbc
jbc
WHO's your DADDY!!!
jbc's Avatar
Australia, SA, Adelaide
Joined Sep 2009
FMS Giant P-47 EPO 1400mm Warbird
Looks like FMS are following suit with another big Foamie after the success of their P-51 and about to be released P-40. If it's as good as the mustang then they should be onto a winner I think
FAQ's
CG is 80-85mm from LE
Batteries used 2200mAh - 4500mAh 20-30C 4S
Where to buy: Nitroplanes(Airfield brand), PW-RC, RC-castle, Aerialhobby, XtremeRC, ChargedRC
Replacement and/or upgrade motors: Turnigy SK 4250 650, Turnigy SK 5055 580, stock motor available from Hobbyking and the above stores
Stock ESC has been reported in some cases to have problems, here is a manual that has been reported to work for programming http://www.giantcod.co.uk/forum/viewtopic.php?f=9&t=888
Advisable to run an External BEC 3A minimum or atleast an ESC that uses a SWITCHMODE onboard BEC.
Following throws are from a fellow forum member:
Ailerons: 1/2" each way (those are my low rates and that's all I use on her)
Elevator: 3/4" each way low rate
1 1/2" each way high rate only for taxi to keep the tail planted
Rudder: As much as you can get
Flaps: As much as you can get
I take off with half flaps at about half throttle but mine does not have the stock power system.
FMS Airfield P-47 (Pt1) Box REVIEW (6 min 38 sec)
FMS Airfield P-47 (Pt2) 'UPGRADE' Mods - How To (9 min 4 sec)
FMS Airfield P-47 (Pt3) FLIGHT REVIEW (7 min 59 sec)
jbc is offline Find More Posts by jbc
Old Mar 23, 2010, 06:10 PM
LICobra is online now
Find More Posts by LICobra
Warbird Enthusiast
LICobra's Avatar
Long Island, NY
Is that a 3 bladed prop I see....first mod...LOL
LICobra is online now Find More Posts by LICobra
Old Mar 23, 2010, 06:12 PM
Matt Howard is offline
Find More Posts by Matt Howard
Dyess AFB
Joined Apr 2009
That was the first thing I thought as well
Matt Howard is offline Find More Posts by Matt Howard
Old Mar 23, 2010, 06:15 PM
jbc is offline
jbc
jbc
WHO's your DADDY!!!
jbc's Avatar
Joined Sep 2009
Yeah it is, atleast you won't have to worry about a spinner though if you keep it stock I just emailed aerial hobby who are also selling the FMS P-40 to see if they'll be carrying this model and when it might be available so will post when they reply
Old Mar 23, 2010, 06:20 PM
jbc is offline
jbc
jbc
WHO's your DADDY!!!
jbc's Avatar
Joined Sep 2009
I know I said when I was doing the big P-51 that my next big foamie I just wanna plug in a battery and RX and go flying but I like this scheme what'ya think?
Old Mar 23, 2010, 06:26 PM
Warbird Enthusiast
LICobra's Avatar
Long Island, NY
John...Thats a sharp one...black and white checkers of the 78th FighterGroup always look good.
Old Mar 23, 2010, 06:43 PM
jbc is offline
jbc
jbc
WHO's your DADDY!!!
jbc's Avatar
Joined Sep 2009
I know an 11inch prop works well on the similar sized Durafly Spitfire so I wonder if this 4blade from Hobby Lobby would work on it?
http://www.hobby-lobby.com/scale_4_b...18581_prd1.htm
Old Mar 23, 2010, 06:46 PM
Warbird Enthusiast
LICobra's Avatar
Long Island, NY
J...Well if the FMS P-51 uses a 14" prop...I would imagine the P-47 could use that or larger..no !
Old Mar 23, 2010, 07:09 PM
jbc is offline
jbc
jbc
WHO's your DADDY!!!
jbc's Avatar
Joined Sep 2009
This is true, I guess it comes down to what motor they put in it The P-51 is using a 600KV and if the P-40 comes out with the same then it makes sense that this P-47 would have the same. It was just a thought that this 4blade might work as the Big Spitfire uses and 11 inch prop and goes quite well with it however that motor is a 36-42 1100kv on 3S and they've stated that this will run on 4S. I hope they offer a 4blade or 2 blade option like the extra 2blade spinner they chucked in with the P-51 that would be nice......wink wink FMS
Old Mar 23, 2010, 07:39 PM
kusunokimasahige is offline
Find More Posts by kusunokimasahige
Tally Ho!
kusunokimasahige's Avatar
The Netherlands
Joined Apr 2006
I like........ i want......... but will be sold out too quick...... probably...
KM
kusunokimasahige is offline Find More Posts by kusunokimasahige
Old Mar 23, 2010, 08:47 PM
guapoman2000 is offline
Find More Posts by guapoman2000
Account closed
Joined Oct 2002
I want one!
guapoman2000 is offline Find More Posts by guapoman2000
Old Mar 23, 2010, 08:48 PM
jbc is offline
jbc
jbc
WHO's your DADDY!!!
jbc's Avatar
Joined Sep 2009
Go on, take the plunge and get in on the pre-order....be one of the first!
Old Mar 23, 2010, 08:49 PM
jbc is offline
jbc
jbc
WHO's your DADDY!!!
jbc's Avatar
Joined Sep 2009
What do you think Carlos, same power system as the mustang?
Old Mar 23, 2010, 08:54 PM
Tally Ho!
The Netherlands
Joined Apr 2006
Pre-Order where ?
KM
Old Mar 23, 2010, 08:57 PM
Account closed
Joined Oct 2002
Yes, not because I am some sort of Tree Hugging Stock equipment Lover but, because of all the alternative motors only one comes close to the Low Kv and highest Torque motor but, the stock is super light and allows for swinging a large diameter propeller and still be in the mid 30 AMP range such that you can get away with using the smaller and "Lighter" batteries. The model thereby is maintained as "Light" as possible.
For this P-47, I would use a 12.5 inch 4-Blade with 8-Pitch.
Carlos
New Product Giant FMS EPO P-51.....NICE kydawg1 Electric Warbirds 17268 Jun 23, 2016 10:35 AM
Discussion Giant P-40 EPO 1400 mm Lenop Electric Warbirds 3147 May 04, 2016 05:16 PM
New Product Another Giant (?) EPO P-51 Mustang coming.....from BH kydawg1 Electric Warbirds 398 Nov 08, 2010 07:18 AM
New Product FMS GIANT FOAM P-47 Thunderbolt Lexta Electric Warbirds 28 Oct 03, 2010 09:55 AM
