Old Mar 31, 2010, 06:05 AM
baronrouge is offline
Find More Posts by baronrouge
baronrouge's Avatar
Nérac -FRANCE-
Joined Aug 2009
Hi,
After seing the drawing of the Doblhoff, it is not really an autogyro because of jet blast on the tips of the blades I think, like french Djinn helicopter.
These jet blast make the rotor turn and create lift without any torque.
But it can easily make a good RC autogyro.
A very nice project.
Jérôme
baronrouge is offline Find More Posts by baronrouge
Old Mar 31, 2010, 09:36 AM
jodini is offline
Find More Posts by jodini
AND FOR MY NEXT TRICK....!
jodini's Avatar
Omaha Millard, Nebraska, United States
Joined Sep 2004
I thought the jets just got the rotors up to speed for quicker takeoffs....yes?
jodini is offline Find More Posts by jodini
Old Mar 31, 2010, 12:20 PM
Gyrocopter is offline
Find More Posts by Gyrocopter
What could possibly go wrong!!
In Bedfordshire, UK.
Joined Oct 2008
No they were powered the whole time, one of the problems was the very high fuel consumption but it must have made a great sound.
Gyrocopter is offline Find More Posts by Gyrocopter
Old Mar 31, 2010, 10:53 PM
Boneswamped is offline
Find More Posts by Boneswamped
RC Group therapist
Boneswamped's Avatar
DeRidder LA.
Joined Nov 2008
Originally Posted by baronrouge View Post
Hi,
Jérôme
The rotors were powered only for takeoff and landing.
Boneswamped is offline Find More Posts by Boneswamped
Old Apr 01, 2010, 02:20 AM
Joined Oct 2008
Hi Mike,
Sorry Mike, you are correct, it was only powered for take offs and landings and to quote a book " Towards the end of 1944 WNF 342 V3 was rebuilt and featured a second propeller mounted coaxially to provide thrust for forward flight when clutched to the compressor. This meant that autorotation could be used for forward flight."
Good luck with the build
Chas
Old Apr 01, 2010, 04:38 PM
RC Group therapist
DeRidder LA.
Joined Nov 2008
Hello Chas,
What's the name of the book you found those great pics and info in? You've posted the best pics so far. I can find very little information that's not already in this thread.
I'm finding that welding small tubing is challenging to say the least. I'm also wondering about the rotor head being fixed parallel to the datum line of the aircraft. I suppose if I pre-rotate the head, I'd have no problems with pitch and roll functions being via swashplate. I have absolutly ZERO experience with Swash controlled autogyros. Mickey's designs seem to have a bit of aft tilt in the mast. The 342 head is level, and it did fly. We shall see.
Pre-rotation plans;
The head and mast will be from Heli parts. I'm considering incorporating a few more parts from a heli frame, namely the main drive gear to facilitate the pre-rotation, and some of the bearing supposrt blocks. Per Mickey's advice, the pre-rotation motor will be a large brushed motor(cheaper, takes more abuse for short durations). The main drive gear on lots of helis contains the one-way bearing.
Thanks for all the input guys, I appreciate all of it.
-Mike
Old Apr 01, 2010, 05:12 PM
Joined Oct 2008
Mike,
The book is "helicopters of the Third Reich" by Steve coates. An excellent read.
You will have no problem silver soldering brass tube assuming thats what you will use.
Regards Chas
Old Apr 29, 2010, 03:58 PM
SafeLandings is offline
Find More Posts by SafeLandings
It was a GLITCH! Honestly!
SafeLandings's Avatar
Stourport on Severn ,Worcestershire, United Kingdom
Joined Dec 2007
Hows it going Mike? you have been quiet for way to long mate
SafeLandings is offline Find More Posts by SafeLandings
Old Apr 30, 2010, 01:32 PM
RC Group therapist
DeRidder LA.
Joined Nov 2008
I'm still working on all the details for this build, but it's going to be expensive to build with the engine, and store bought machined 3-blade grip. I've put all my other projects on hold until I build the PCA-2. I'll get back to it eventually.
Regards,
-Mike
Wanted RCGF or 45-50cc rear carb gas plasticjoe Aircraft - Fuel - Engines and Accessories (FS/W) 0 Oct 28, 2009 06:45 AM
Wanted 50cc gas 3D aerobatic plane *3dpilot* Aircraft - Fuel - Airplanes (FS/W) 4 Oct 04, 2009 05:24 PM
Help! Giant Scale Katana 50CC ARF Nitro Gas ratalsauto Giant Scale Airplanes 0 Aug 10, 2009 03:14 PM
Quadra 50cc gas and ryobi 26cc 4 stroke gas for sale. grant31781 Aircraft - Fuel - Airplanes (FS/W) 2 Dec 17, 2004 09:29 AM
