Old Mar 21, 2010, 05:34 AM
jonotaylor is offline
Find More Posts by jonotaylor
Joined Mar 2010
OS Max 37 sz Hring won't start
Hello,
Tried to start this engine, fitted to a helicopter, today. I bought it new last year. It was broken in, and used on the chopper a couple of times last Spring.
Trying to start it today and when I attach it up to the starter, it can barely turn the engine over - seems very stiff. Any ideas?
jonotaylor is offline Find More Posts by jonotaylor
Old Mar 21, 2010, 06:58 AM
Hemikiller is offline
Find More Posts by Hemikiller
-insert witty saying here-
Hemikiller's Avatar
United States, CT, Killingworth
Joined Dec 2005
The fuel and any castor oil in the engine is probably all gummed up, or your bearings are rusted badly. There's three ways I know of to free a gummed engine: heat, fuel or dis-assembly. You can try a heat gun on the sides of the engine, being careful to not to damage any of the plastic parts.
If that does not do the trick, then flood the engine with fuel. Remove the glow plug, rotate the crank so the piston is at bottom dead center. Use your fuel pump and literally fill the engine with fuel. Let it sit for a while, rocking the crank back and forth to work the fuel through the engine. When it's sufficiently free, pour the excess fuel out of the cylinder and muffler. With the glow plug still out, gently tap it with your starter, which will blow out the excess fuel. You might need to repeat this a couple times.
If fuel flooding does not do the job, you are probably in need of a set of bearings, so it'll have to come apart. If you pull the backplate, You should be able to see what's going on inside.
Hemikiller is offline Find More Posts by Hemikiller
Old Mar 21, 2010, 05:17 PM
cmulder is offline
Find More Posts by cmulder
Ireland
Joined Apr 2001
remove the glow plug and see if that has thick goo on it then feel how stiff the engine is without the glow plug.
Also check if the carb barrel mooves freely or you could overload your trottle servo.
cmulder is offline Find More Posts by cmulder
Old Mar 22, 2010, 06:45 AM
Joined Mar 2010
Hello all,
Removed the glow plug, it is clean. Engine equally difficult to turn over with it removed. Carb barrel moves OK.
I will take the engine out next weekend and see if I can find a problem - in the mean time, my starter has stopped working - left it connected to the car battery while I wrote the above post and by time I got back it had stopped working - it was hot, but did not smell, so not sure what the problem is. Maybe it's just the starter that wasn't working properley. Will get a new one and see.
For Sale OS Max 37 SZ-H Steve Boone Aircraft - Fuel - Engines and Accessories (FS/W) 1 Mar 25, 2010 07:21 AM
Sold Used OS 37 SZ-H $80.00 SHIPPED!!! SOLD raypadro Aircraft - Fuel - Engines and Accessories (FS/W) 0 Aug 04, 2008 07:33 AM
For Sale Os 37 Sz-h New In Box.... rcgalore Aircraft - Fuel - Engines and Accessories (FS/W) 0 Feb 16, 2008 05:42 PM
Sold OS .37 SZ-H Ringed w/fan & clutch Motions Aircraft - Fuel - Engines and Accessories (FS/W) 0 May 21, 2007 03:57 PM
Wanted Os 37 Sz-h npm108 Aircraft - Fuel - Engines and Accessories (FS/W) 0 Feb 09, 2007 11:55 AM
