Old Nov 02, 2011, 09:57 AM
meatbomber is offline
Find More Posts by meatbomber
Square-rigger
meatbomber's Avatar
Klatovy, Czech Republic
Joined Mar 2004
well it needs either a Victory or at least a british 74 to keep it company
meatbomber is offline Find More Posts by meatbomber
Old Nov 02, 2011, 10:21 AM
lucc is offline
Find More Posts by lucc
belgium,limburg
Joined Sep 2009
I know now that the plans come from this person .
witch ship i dont know.
http://www.ancre.fr/default.aspx?L=EN
ps :don't look are you have lost a lot of money the next few days
lucc is offline Find More Posts by lucc
Old Nov 02, 2011, 10:33 AM
lucc is offline
belgium,limburg
Joined Sep 2009
Lucc if you use the sheets from the winch to a block on the bowsprit and back qnd you use this as a master sheet you can install 3 ring each side into which you hook the respektive jib sheet, i think that's exactly what Ray did on the Surprise.
I can't find any pictures off this ,can anyone help me
I also don't know what englisch words i need for searching.
I don't get any result in the searchmode.
thx luc
Old Nov 02, 2011, 04:08 PM
Square-rigger
meatbomber's Avatar
Joined Mar 2004
i`ll repost some pics here that come from Dan and Ray in the Brig thread.
Old Nov 02, 2011, 05:54 PM
lucc is offline
belgium,limburg
Joined Sep 2009
Thx meatbomber
but I dont understand something.
first they use this.
Why not put the pulley on top of the bowsprit. (Mayby becose he's got 2 sails and i 3 sails??)
but these (the yellow line) is not attached on the loop that go's tot the pulley.
I know the yellow line is just hanging in the air why does he needs that pulley. (or need not??)
Old Nov 02, 2011, 06:08 PM
Square-rigger
meatbomber's Avatar
Joined Mar 2004
the pulley is on Rays surprise the free hanging one is on DanLs he doesn`t have the pulley...
its`s just 2 different approaches to the same problem with more or less potential line tangle rays system with a looped master sheet should be pretty much tangle free as it can be run under tension from the winch to the pulley and back...
Dan is counting on large disks on his whinch and fairleads that allow the sheet to run relatively loose while still not getting cable salat on the drum...
I think i would go for Dans method but instead of the way he did his fairleads and under deck turning sheaves iŽd try with a thin PVC tube (bowden outer cable) that terminates as near as possible on the winch tube.. that should keep line tangle below decks at a minimum. But then he did it already and i didn`t so the only real authorities on the reliability of those systems would be Dan and Ray
Old Nov 03, 2011, 10:23 AM
lucc is offline
belgium,limburg
Joined Sep 2009
Meatbomber , thank you for this mail.
I hope that Dan or Ray responsing so I know what system is the best for sailing.
Old Nov 04, 2011, 09:22 AM
lucc is offline
belgium,limburg
Joined Sep 2009
Starting with the shrouds.
Ropethickness= 1.6mm .
1 Rope is 66 little ropes.
In totaal 200m rope needed for making 1 rope of 2.5m long and 1.6mm thik.
Old Nov 04, 2011, 09:43 AM
WarpdSpazm is offline
Find More Posts by WarpdSpazm
NYC, NY
Joined Jan 2005
Lucc,
This is fantastic. I'm totally in love with this ship! I have a question about the cannons are you made them. For the metal jig you created, I would like to try the same method to make mine. Might you be able to explain a little more on how you made the metal jig to shape the guns? Thanks and can't wait to see her finished.
Originally Posted by lucc View Post
My lathe for the canons
[/URL]
the result on this moment.
WarpdSpazm is offline Find More Posts by WarpdSpazm
Old Nov 04, 2011, 10:39 AM
lucc is offline
belgium,limburg
Joined Sep 2009
I try with my poor englisch
First this link
http://www.modelships-beagle.eu/faq/map6/a600.htm
Her you find all the canons and his info to make it.
i used this foto for my metal jig.(with adjustments)
the metal for my jigs comes from a sawblade. A sawblade that is 6 a 7cm width en 30cm long. just a cheap sawblade nothing expansieve.
the wood : don't teak a hard wood, you have push to hard fore taking some wood off and the canon breaks (just before you have almost done).
Old Nov 04, 2011, 10:44 AM
lucc is offline
belgium,limburg
Joined Sep 2009
A tip :next to point X and A , you have to draw a horizontale line.
when this line touche the wood (left and right off the canon) you now that you have the correct deept of everythingand the canon is finished.
Old Nov 04, 2011, 01:09 PM
NYC, NY
Joined Jan 2005
Thank you sir! Your English came across perfectly!
Old Nov 04, 2011, 01:28 PM
JerryTodd is offline
Find More Posts by JerryTodd
SCALE Sailor
JerryTodd's Avatar
United States, MD, Severna Park
Joined Apr 2008
Lucc,
Can you get boxwood? I turned a caronade from it a while back and it was a joy to work and came out very smooth with good edges where I wanted them - even with a knot in it.
JerryTodd is offline Find More Posts by JerryTodd
Old Jan 20, 2012, 01:35 PM
lucc is offline
belgium,limburg
Joined Sep 2009
Kitchen is finished.
recycling olf kitchen
started with the standing ropes ??
Old Jan 21, 2012, 12:37 PM
yancovitch is offline
Find More Posts by yancovitch
Joined Oct 2006
this ship is gonna be a knockout....so much attention to detail.....i tended to be a lot more lazy, and took as many shortcuts as i could .....can't imagine winding my own ropes.....
yancovitch is offline Find More Posts by yancovitch
Build Log Scratch-build, own-design ocean-going salvagetug 1:50 tweety777 Scale Boats 36 May 04, 2013 10:26 AM
Scratch-building a 1.8m MDM-1 Fox Joe Yap Scale Sailplanes 26 Mar 27, 2013 10:27 AM
Discussion The Santisima Trinidad (scratch) (1 : 50) lucc Scale Boats 79 Mar 20, 2010 12:06 PM
Build Log Scratch built 1:12 salmon xx29l9 Scale Boats 6 Mar 11, 2010 01:41 PM
Sold 50 airplanes for sale in ohio 1 lot or seperate johnsheri Aircraft - Fuel - Airplanes (FS/W) 28 Mar 04, 2010 09:09 PM
