Old Mar 20, 2010, 01:04 PM
lucc is offline
Find More Posts by lucc
belgium,limburg
Joined Sep 2009
My lathe for the canons
lucc is offline Find More Posts by lucc
Old Mar 21, 2010, 10:02 AM
lucc is offline
belgium,limburg
Joined Sep 2009
Start building the ra's the past few weeks
explanation :
the end of the ra.
I put a dowel between 2 irons in a specific angle.
Evreything what's above the irons must away.
topview
starting with the head
shapping the rest
Old Mar 21, 2010, 10:13 AM
lucc is offline
belgium,limburg
Joined Sep 2009
started with the rectangler in the middle of the ra
8 planks rounded
In the middle dubbelside tape and the rest woodglue.
the result
Old Mar 21, 2010, 10:15 AM
lucc is offline
belgium,limburg
Joined Sep 2009
also working on the deck
pipes for attaching the bulb
view on the deck
Old Mar 21, 2010, 10:18 AM
lucc is offline
belgium,limburg
Joined Sep 2009
another view on the deck.
I'm going the use silicone for stopping the water comming into the boat
A finished cannon.
view outside
28 cannons.
Old Mar 21, 2010, 10:28 AM
lucc is offline
belgium,limburg
Joined Sep 2009
Am now also busy with the sails, so I know approximately where the yards have come.
Very unclear on the plan.
The top left is a sheet of A4 paper. Question to a sight of how big the sails of the main mast.
The ra 's placed above it.
Now I suspect that the plans of the sails do not come from the museum, but work of a builder of scale is not correct.
As you can see the side of the sail is 4.5 cm away from the bulge.
Can someone tell me where to get the sail somewhere.
I suspect that nokleuver (the eye to the angle of the sail with which the sail is attached to the yard) is about 1 cm.
Old Mar 21, 2010, 10:30 AM
lucc is offline
belgium,limburg
Joined Sep 2009
I see in paratrooper pictures that his sails are a few cm from the ends of the ra removed.
Old Mar 21, 2010, 10:56 AM
JerryTodd is offline
Find More Posts by JerryTodd
SCALE Sailor
JerryTodd's Avatar
United States, MD, Severna Park
Joined Apr 2008
The sheets usually go through the a sheave set in the yard arm outside the shoulder you've carved, then in toward the mast to block that turn them down the to pin rails at the base of the mast. The earring of the sail below is lashed to the shoulder which keeps the head of the sail stretched out and tight. ie: the sheet sheave is outside the shoulder and the head of the sail will be narrower than the foot of the sail above it.
Ideally - if you drew a line from the earring, diagonally across the sail to the opposite clew, it should project right at the sheave in the yard for the sheet. That way the sheet feeds into the sheave without binding and hauls on the sail evenly along the foot and the leech.
JerryTodd is offline Find More Posts by JerryTodd
Old Jul 07, 2010, 12:56 AM
SeaMan2 is offline
Find More Posts by SeaMan2
Denver Colorado
Joined Nov 2009
what's going on with this build, you didn't stop did you???
SeaMan2 is offline Find More Posts by SeaMan2
Old Jul 16, 2010, 08:01 AM
lucc is offline
belgium,limburg
Joined Sep 2009
no,but a lot of work ,so no time for building.(2 hours in one week is the max)
a little update is comming.
sorry for waiting.
Old Jul 17, 2010, 04:34 AM
lucc is offline
belgium,limburg
Joined Sep 2009
material for moving little doors.
I'm going to use "brass black" for making it dark.
Yards moving 90 in each direction.
little yard's between 5mm <> 10mm I use this.
Old Jul 17, 2010, 04:41 AM
lucc is offline
belgium,limburg
Joined Sep 2009
In Dutch " de Keggenrand " .
For avoiding water down the mast.
Old Jul 17, 2010, 04:44 AM
lucc is offline
belgium,limburg
Joined Sep 2009
the floor en doors.
result :
Old Jul 17, 2010, 04:45 AM
lucc is offline
belgium,limburg
Joined Sep 2009
other little work
Old Jul 17, 2010, 04:12 PM
muidaq is offline
Find More Posts by muidaq
USA, OH, Westerville
Joined Aug 2007
Simply stunning work my friend.
muidaq is offline Find More Posts by muidaq
Build Log Scratch-build, own-design ocean-going salvagetug 1:50 tweety777 Scale Boats 36 May 04, 2013 11:26 AM
Scratch-building a 1.8m MDM-1 Fox Joe Yap Scale Sailplanes 26 Mar 27, 2013 11:27 AM
Discussion The Santisima Trinidad (scratch) (1 : 50) lucc Scale Boats 79 Mar 20, 2010 01:06 PM
Build Log Scratch built 1:12 salmon xx29l9 Scale Boats 6 Mar 11, 2010 02:41 PM
Sold 50 airplanes for sale in ohio 1 lot or seperate johnsheri Aircraft - Fuel - Airplanes (FS/W) 28 Mar 04, 2010 10:09 PM
