Old Mar 19, 2010, 01:03 PM
flyinhigh025 is offline
Find More Posts by flyinhigh025
How can we stop winter?
flyinhigh025's Avatar
Frederick, CO
Joined Sep 2005
Build Log
3D Hobby Shop 65" BIG Vyper Build Thread
Hey all! During the last 4 weeks or so I have assembled and flown the 3DHS 65" Vyper. And all I can say is... WOW. In my experience the big Vyper has been the single most pleasurable build to date, and has been nothing short of -astonishing- in the air. This has been one of the most enjoyable experiences I have had during the over 15 years I have been building and flying RC model aircraft. Could not be happier!
I will now be detailing the build with some good close-up pictures and commentary. Want more information pertaining to a section of the build? More pictures? Any question please feel free to ask!
Are you wondering why I located the build thread for the 3D Hobby Shop 65" Vyper in the Sport Planes section? Well, a lot has been said about the Vipers’ 3D "hucking" ability already. But this is really the first of a TRUE HYBRID aircraft to hit the market, the real deal. The Vyper has amazing precision and sport flying abilities. After the build log is complete, we will be working to get some further information and video displaying the forgiving sport/precision nature of the Vyper. And yes, some 3D stuff... I can't help myself!?
With a simple flip of a switch from high to low control rates, you have yourself an elegant, smooth sport flying machine!
Link to 3DHS Airframes:
http://www.3dhobbyshop.com/SearchRes...x?CategoryID=4
Original 65" Vyper Thread:
http://www.rcgroups.com/forums/showthread.php?t=1093928
Note: I want to take this opportinity to thank Rob at ADC Hobby Store for the amazing DIAMOND PLATE graphics for the Vyper! Check them out, top notch!
http://adchobbystore.com/vinyl-decal...es-65vyper.htm
-Jeff
flyinhigh025 is offline Find More Posts by flyinhigh025
Frederick, CO
Joined Sep 2005
Let's take a close look at the Vyper, parts, and my chosen set-up items.
Instruction Manual Located Here: http://3dhobbyshop.com/Manuals.aspx
My set-up:
1)65" Vyper
2) Hacker A50-16S
3) Hacker X110 PRO ESC
4) Castle Creation BEC PRO
5) 6S 5000mAh 20C and 25C Lipoly Packs
6) HITEC 7985MG Digital Servos (4x)
7) 2x 24" / 2x 6" / 1x12" Servo Extensions
8) Extreme Flight 76mm Elite Spinner
9) Xoar 18x8 and 18x10 e-props
10) HITEC Aurora 9 w/ Optmina 7ch Receiver
Old Mar 19, 2010, 01:04 PM
Frederick, CO
Joined Sep 2005
Covering:
Let's take a look at the covering.
The first item I like to tackle in a build is the covering. I took a moment to remove some MINOR wrinkles from the covering using my iron and heat gun. Very few wrinkles were present.
I then removed covering with a hot knife where instructed in the manual.
Important Note: I chose not to use the included rudder Pull-Pull system. I located the rudder servo on the aft fuselage to assist with proper CG location.
Frederick, CO
Joined Sep 2005
Next...
I have found it to be good practice to go over the forward fuselage structure including motor mount and landing gear areas with thin CA before starting the major assembly. While this is not an essential step, the addition of CA will improve the overall strength of the most abused areas on an airplane.
Let’s get the assembly underway by piecing together the landing gear.
Old Mar 19, 2010, 01:05 PM
Frederick, CO
Joined Sep 2005
Rudder Installation:
The rudder and elevator require the builder to glue the hinges in place. The builder can use either Polyurethane Glue ("Sumo or Gorilla") or 30-min. epoxy to get the job done.
I have recently become acquainted with Polyurethane Glues; in particular I like "Sumo Glue". PU glue (as it is commonly referred to) will expand as it dries filling any internal gaps resisting gravity to further increase the strength of a given installation.
Quick HOW TO use PU glue: (Using hinge installation as the example)
1) Apply Vaseline to hinge joint using cotton swab.
2) Lightly wet all holes with water.
3) Squeeze in a small amount PU glue into all hinge holes.
4) Install hinges.
5) Wipe away glue as it expands and foams using denatured alcohol. (Keep an eye on it and wipe as required for the first 10-20 mins)
6) Allow to fully cure.
I then used the same method to install all control horns.
Old Mar 19, 2010, 01:06 PM
Frederick, CO
Joined Sep 2005
Hinge gap sealing:
I like to seal all hinge gaps on my high performance airplanes. This is a personal preference, and I again chose to do so on the Vyper.
My gap seal of choice is Blenderm Tape. I have found it to be extremely forgiving and easy to apply. See pictures below for further information.
The ailerons come factory installed and sealed. This is a huge time saver!
Old Mar 19, 2010, 01:07 PM
Frederick, CO
Joined Sep 2005
Rudder Servo Installation:
The control system hardware used on the Vyper is very high quality. The ball links provide an ultra smooth and secure bearing surface for those precision maneuvers!
Important Note: I chose not to use the included rudder Pull-Pull system. I located the rudder servo on the aft fuselage to assist with proper CG location. Personal preferance.
See pics below for details.
Old Mar 19, 2010, 01:08 PM
Frederick, CO
Joined Sep 2005
Horizontal Stabilizer / Elevator Installation:
Time to install the horizontal stab and elevators. Often one of the most feared steps when building a model airplane, we need not worry any more. 3DHS has taken much of the work out of this step.
Builders Note: Do NOT remove covering from center section of stab for installation. It is proven that thin CA will form a permanent bond between fuselage structure and horizontal stab covering. Quick, easy... no epoxy mess!
Glue elevator hinges using previously mentioned technique.
See pics below for installation details.
Old Mar 19, 2010, 01:09 PM
Frederick, CO
Joined Sep 2005
Elevator Servo Installation:
Install elevator servo and linkage as shown using the same technique we used to install rudder servo.
Old Mar 19, 2010, 01:11 PM
Frederick, CO
Joined Sep 2005
Aileron Servo and Linkage Installation:
Using the same technique we previously used to install the rudder and elevator servos, drop the aileron servos in place.
Frederick, CO
Joined Sep 2005
Final Set-UP:
1) Center of Gravity Checks.
-The instruction manual calls for a CG of 170-180mm behind leading edge of wing at root for maiden, sport and precision flight.
-Using your chosen battery pack, slide lipo fore and aft until maiden CG is obtained.
-Balance aircraft in inverted position.
-Once satisfied with battery position, apply supplied Velcro to battery tray and secure with hold down straps.
2) Tie up loose ends.
-Secure loose wiring using zip ties or preferred method for a clean installation.
3) Adjust and set all control throws as specified in the assembly manual.
- http://www.3dhobbyshop.com/Manuals.aspx
-I found both the specified low and high rates to be right on for my flying.
4) Perform final pre-flight checks:
-Check ALL flight controls are operating in the correct direction. EVERY FLIGHT! ;-)
-Quick full power motor run-up check.
-GO FLY!
Old Mar 19, 2010, 01:12 PM
Frederick, CO
Joined Sep 2005
I reserved the next few posts for upcoming videos, in flight pics, and further information pertaining to sport/precision flying the Vyper.
Hopefully the weather here in Colorado will cooperate next week and allow us to FINALLY get some good in flight video.
-Jeff
Old Mar 19, 2010, 01:13 PM
Frederick, CO
Joined Sep 2005
A call to all Vyper pilots!!!!
I reserved this slot hoping to collect some pics of the many 65" Vypers and the proud owners!
So PLEASE!
Send any and all of your 65" Vyper pics to: flyinhigh025@aol.com and a little information about yourself and your Vyper.
Thanks!!!
-Jeff
Old Mar 19, 2010, 01:14 PM
Frederick, CO
Joined Sep 2005
Video's wanted!
Attention Vyper pilots! (Addicts!)
Please send links to your Vyper videos to: flyinhigh025@aol.com
I will post them, HERE!
Thanks!
-Jeff
Discussion 3D Hobby Shop 71" AJ Slick - Build & Fly thread BoneDoc 3D Flying 32218 Jul 20, 2016 09:35 PM
Video 3D Hobby Shop 65" Vyper sukhoi26mx Electric Plane Talk 5 Dec 21, 2009 05:06 AM
Sold 3D Hobby Shop 46" Vyper 3D/Precision jadamian75 Aircraft - Electric - Airplanes (FS/W) 3 Sep 04, 2009 01:13 AM
