Old Mar 19, 2010, 01:15 AM
grfcon is offline
Find More Posts by grfcon
chronic in training
grfcon's Avatar
L.A. beautiful san fernando valley
Joined Nov 2008
Question
put a new shaft in my outrunner...forgot the??
washer that sit between the back of the motor and the "C" ring/clamp thing. If my motor is a pusher..can I run it without the washer.... or will I burn up the "c" clamp washer thing?
thanks
grfcon is offline Find More Posts by grfcon
Old Mar 19, 2010, 10:02 AM
jackerbes is offline
Find More Posts by jackerbes
Jack
USA, ME, Ellsworth
Joined May 2008
The washer under circlip is usually called the thrust washer. It evens out the load as the washer and circlip are pulled up again the inner race of the bearing. It may also serve to raise the circlip up slightly to clear the shield or outer race as the thrust washer, circlip and shaft all turn with the inner race as the motor runs.
If you left it out, pulled the circlip up against the inner race, and everything holding OK and the circlip staying in place, you can get away with leaving the thrust washer off.
If it is being used in a pusher, it is a moot point as the load is going the other direction and the clip is not loaded at all.
Jack
jackerbes is offline Find More Posts by jackerbes
Old Mar 19, 2010, 11:05 AM
grfcon is offline
chronic in training
grfcon's Avatar
Joined Nov 2008
thanks a lot! appreciate it
Discussion Ice50 govenor set w/castlelink...what do I put in my radio? SidewaysLS4 Castle Creations 20 Sep 12, 2009 02:26 PM
Discussion Bent shaft on my new outrunner - now what? Electriflied Power Systems 1 Jan 22, 2006 03:10 PM
