Old Mar 18, 2010, 08:42 PM
Edubarca is offline
Find More Posts by Edubarca
Edubarca
Edubarca's Avatar
Colombia, South America
Joined Oct 2009
Tomboy by Vic Smeed
Hello. I have just finished a Tomboy from Aeromodeller Plans Service and designed by Vic Smeed, Without doubt one of the most popular Sports Free Flight model ever. The plan was a best seller. It is my fourth Tomboy and the first one with RC. It is powered with an old Cox Black Widow .049, monokote covered and it uses a Hobby King 2.4 GHZ radio with a miniature servo, only rudder in order not to lose the free flight spirit but not having to chase the model all over the countryside!! I would like to obtain a scan of the original Aeromodeller Magazine article and cover where it was published. Thanks!! I also want to hear about other Tomboys made and flown.
Edubarca is offline Find More Posts by Edubarca
Old Mar 19, 2010, 04:00 PM
kdc. is offline
Find More Posts by kdc.
Joined Nov 2009
If you go to http://www.modelflyermagazine.com/ you will find a link to the Aeromodeller index.
The index shows Tomboy as November 1950
Model Flyer recently had a column by David Boddington about enlarging the Tomboy to 60 inches and 72 inches I think.
Also Aviation Modeller had one enlarged as TomEBoy for electric at about 54 inches.
kdc. is offline Find More Posts by kdc.
Old Mar 19, 2010, 04:34 PM
Edubarca is offline
Edubarca
Edubarca's Avatar
Joined Oct 2009
Thanks for information. A double size Tomboy is a good idea!! Perhaps one day I will do it. In the meantime, my 4th Tomboy is flying superbly even at our elevation in Bogotá of 8.650 feet above sea level. Will post photos soon.
Old Mar 19, 2010, 05:53 PM
Warren B is online now
Find More Posts by Warren B
Warren B's Avatar
Mt Evelyn, Melbourne, OZ
Joined Dec 2008
Hi Eduardo,
I'll send those scans soon.
Warren B is online now Find More Posts by Warren B
Old Mar 19, 2010, 05:56 PM
RSTMG is offline
Find More Posts by RSTMG
Sunny Sarfend on Sea. UK
Scan for the original Aeromodeller article can be found here
http://www.rcgroups.com/forums/showt...2#post12762491
RSTMG is offline Find More Posts by RSTMG
Old Mar 19, 2010, 06:23 PM
Edubarca is offline
Edubarca
Edubarca's Avatar
Joined Oct 2009
Thank you very much Warren you are very kind.
Best wishes!!
Old Mar 20, 2010, 07:20 AM
kdc. is offline
Joined Nov 2009
Sorry my information about TomEBoy was incorrect it was a free plan in RC ModelWorld ( not Aviation Modeller) September 2002 and only 42 inch span RCMW is at www.traplet.com
I had assumed that as Aviation Modeller International had aquired Aeromodeller that AMI would have published the new plan. Not so it seems.
Old Jun 01, 2010, 03:58 AM
Teals1 is offline
Find More Posts by Teals1
Teals1's Avatar
New Zealand, Auckland, Papakura
Joined Nov 2006
Tomboy
Yes, the Tomboy is a lovely model - just finishing off the 36" version for the third time only this one RC. It is fitted with a Boddington Mills .75 and lightweight radio. I also have built one at 80inch wing span. Lovely flyer which underwent several changes due to....ahem....slight mishaps. Eventually lowered dihedral and fitted ailerons and had many happy hours of flying with it.
Teals1 is offline Find More Posts by Teals1
Old Jun 01, 2010, 09:05 AM
patmcc is online now
Find More Posts by patmcc
Northumberland, England
Joined Jan 2007
Nice job Teals.
How is the wing fixed ?
patmcc is online now Find More Posts by patmcc
Old Jun 02, 2010, 02:36 AM
Teals1 is offline
Teals1's Avatar
Joined Nov 2006
Tomboy
Hi Patmcc, This photo was taken prior to compete finishing. For the photo pins held the wings in place but the usual dowels have since been fitted and rubber bands will hold things together as per the original. I have used Airspan for covering, stuck down with Stixit, a light coat of thin dope followed by a light coat of polyurethane. Looks like the weight will come out around 15oz.
Old Jun 02, 2010, 02:32 PM
John38 is online now
Find More Posts by John38
Southampton, UK
Joined May 2007
Is polyurethane diesel fuelproof ??
John38 is online now Find More Posts by John38
Old Jun 02, 2010, 05:58 PM
Joined Jan 2007
I asked because I thought someone else was following the same principle as me. I avoid using bands if possible & usually retain the wings with a single screw on vintage models on the principle that the original only had bands because there was little, or more likely, no control over how it landed but now we can at least line it up into wind & land on the wheels.
I've always found it so.
Old Jun 12, 2010, 12:18 AM
Teals1 is offline
Teals1's Avatar
Joined Nov 2006
Tomboy
Sorry for late reply. Have been told a light coat of polyurethane is Ok. Even so, the Airspan covering used is fuel proof according to the brochure enclosed with the covering material. Also gave it a light coat of thin dope to help fill the weave. Test flight will have to wait as work calls me out of town.
Old Jul 29, 2010, 07:11 PM
Teals1 is offline
Teals1's Avatar
Joined Nov 2006
Tomboy
Just to report that test flights went like clockwork. Just a little right rudder trim adjustment needed. Cold frosty morning with no wind to speak of so no thermals but still got around 5 minutes total flight time - just over a minute on power with just under 4 minutes glide. Will need to try out various props etc in an effort to lengthen the motor run time. Weight has come out at just a tad over 12oz all up. Have used micro servos, small receiver and 800mah batteries. Everything except servos fit behind the first fuselage former, the firewall. Delightful flyer and other modellers enjoyed diesel fuel fumes again, bringing back memories of the past!
Old Jul 30, 2010, 02:06 AM
orange&white is offline
Find More Posts by orange&white
Scott R/C Time Pilot
orange&white's Avatar
NorthBend/Coos Bay,Oregon USA
Joined Dec 2009
Hello Allen.
Beautiful, a real head turner and good flyer.
Nice job.
Scott
orange&white is offline Find More Posts by orange&white
Discussion Pushy Cat by Vic Smeed olmod Vintage & Old-Timer Designs 214 Nov 25, 2014 11:52 AM
Discussion Vic Smeed Tumble Tot Plan Please surflyer Vintage & Old-Timer Designs 11 Oct 31, 2012 03:54 PM
Popsy by Vic Smeed olmod Vintage & Old-Timer Designs 241 Mar 26, 2011 01:23 PM
Cool little known Vic Smeed designs RyanNX211 Vintage & Old-Timer Designs 6 Sep 04, 2009 12:41 AM
Discussion Panache by Vic Smeed AlphaWhisky Sailboats 5 May 28, 2009 12:03 PM
