Old Mar 18, 2010, 02:49 PM
turbored21 is offline
Find More Posts by turbored21
USA, WV, Moundsville
Joined Oct 2006
Question
GPV-1 Alum rear sprocket?
either I'm doing something wrong or my chain isnt setup right but Ive split two of these rear sprockets on light bobbles/crashes i tried searching didn't see any information on a metal rear sprocket i checked with Bruce as well
do i have too much chain lash? could that cause the breakage? or am i missing something?
Tim
turbored21 is offline Find More Posts by turbored21
Old Mar 18, 2010, 04:10 PM
motonovice is offline
Find More Posts by motonovice
Joined Nov 2009
There isn't a venom alloy sproket but look for coug on this board. He does some beatifull work w/ cnc. He does allu rims, hub, and sproket at a good price. That's about all I can recomend.
Motonovice
motonovice is offline Find More Posts by motonovice
Old Mar 18, 2010, 06:25 PM
test driver is offline
Find More Posts by test driver
newcastle Australia
Joined May 2004
Tim
Two things:
1/. try to get on the brakes when you crash not hold the throttle still on.
2/. check the chain tension when the rear of the bike is fully compressed. make sure it is not to TIGHT in the situation. the chain may seem loose in normal stance but it tightens up under suspension movement and that can cause the sprocket to crack with the extra loads on it.
Eden
as for Al sprocket (or steel) I have seen aluminium wheels and sprockets from the Kyosho HOR adapted to the venom bike.
test driver is offline Find More Posts by test driver
Old Mar 19, 2010, 04:29 AM
koh is offline
koh
Find More Posts by koh
koh
Joined Jun 2004
Tim
You can consider to use either,
1. the kyosho wheel with the steel sprocket or
2. Alu rear hub for Venom, from ZH racing, by using the alu rear hub, you have to use the ZH/oto alu rear wheel as well.
wilson
koh is offline Find More Posts by koh
Old Mar 19, 2010, 02:54 PM
Joined Oct 2006
thanks guys looks like ill be using the HOR rear wheel/sprocket
Old Mar 19, 2010, 04:01 PM
KermitGTT is offline
Find More Posts by KermitGTT
KermitGTT's Avatar
cape town
Joined Apr 2006
Unfortunately these aren't available to any one outside South Africa, but they are pretty sweet.
KermitGTT is offline Find More Posts by KermitGTT
Old Aug 17, 2010, 03:19 PM
Appel82 is offline
Find More Posts by Appel82
Appel82's Avatar
Sweden
Joined Aug 2010
Is this the only parts I have to use for this options ????
(the kyosho wheel with the steel sprocket)
No other modification ?
Appel82 is offline Find More Posts by Appel82
Old Aug 19, 2010, 12:14 PM
CLKSPEED is offline
Find More Posts by CLKSPEED
CLKSPEED's Avatar
Joined Dec 2007
Hello, you kyosho parts we can use for venon? I want to know if the rear sprocket, and tires are usable.
Greetings
CLKSPEED is offline Find More Posts by CLKSPEED
Old Aug 22, 2010, 11:07 PM
ehirobo is offline
Find More Posts by ehirobo
Hong Kong
Joined Nov 2008
the rear wheel is a direct fit for kyosho to venom using kyosho sprocket and the plastic brake disk. The rear tire fit too. The front tire not 100% sure but think it is too wide and will rub on the fork.... For the sprocket just use the ZH one (need to use ZH rims too) as the quality is very good and they least forever.
ehirobo is offline Find More Posts by ehirobo
Old Aug 26, 2010, 03:16 PM
CLKSPEED is offline
CLKSPEED's Avatar
Joined Dec 2007
Hi ehirobo
Thanks for your comment, looking for options Kyosho found this, serves to venon?
the rear sprocket is the same as that of the venon?
Thank you.
Old Aug 26, 2010, 03:58 PM
slawsonb is online now
Find More Posts by slawsonb
Bruce
Palmdale, CA
Joined Sep 2005
I do not think that the swingarm will fit on the Venom but maybe the sprocket and rear wheels could be used but that is just speculation.
Coincidentally, I just put this swingarm set on the website.
http://2wheelhobbies.com/product_inf...roducts_id=996
Bruce
slawsonb is online now Find More Posts by slawsonb
Old Aug 26, 2010, 05:44 PM
CLKSPEED is offline
CLKSPEED's Avatar
Joined Dec 2007
Hi Bruce
the sprocket rear for kyosho is in the same way that the poison? it is important whether the string goes for venom. Thanks.
Greetings
Old Aug 26, 2010, 06:16 PM
Bruce
Palmdale, CA
Joined Sep 2005
Originally Posted by CLKSPEED View Post
Hi Bruce
Greetings
I think a lot is lost in translation.
Old Aug 26, 2010, 06:58 PM
CLKSPEED is offline
CLKSPEED's Avatar
Joined Dec 2007
It is true, sorry for the translator.
Whether the size of rear sprocket teeth kyosho is identical to the poison,for the chain size. Thanks.
Greetings
Old Aug 31, 2010, 01:44 PM
CLKSPEED is offline
CLKSPEED's Avatar
Joined Dec 2007
Whether the size of rear sprocket teeth kyosho is identical to the poison,for the chain size ???. Thanks.
Greetings
Help! GPV1 rear sprocket Bking1340 Motorcycles 4 Feb 01, 2010 01:51 AM
Discussion GPV-1 Forks and Rear Shock 621clay Motorcycles 19 Jan 05, 2010 06:58 PM
Wanted rear sprocket nitro22 Cars - Trucks and Parts (FS/W) 3 Dec 15, 2009 07:37 AM
Discussion Delete iansu Motorcycles 11 Oct 16, 2009 08:07 AM
Discussion Venom GPV-1 Rear tyre mrbiccies Motorcycles 5 Apr 30, 2009 03:45 PM
