Old Mar 17, 2010, 05:01 AM
danielpetrescu is offline
Find More Posts by danielpetrescu
Tulcea Romania
Joined Mar 2010
Help!
Octocopter with folding arms on the cheap... need help
Hi everybody
This is my first post after reading a few hundred posts about multi rotor helis... I am a photographer and would like to build a rig to carry my camera (max 1.5kg payload) so I have opted for octocopter configuration. Usually octocopters are big and not easy to transport so I am planing on doing something with folding arms. I am on a tight budget so I am trying to reduce costs as much as I can please just help me out with ideas as I am full of information and... have a hard time putting it together. So here is what I had in mind...
What I want to use:
Octocopter structure with folding arms - like this one
The arms - I have studied a lot of options and carbon fibre seems to be the lightest but expensive... so I went to one of the china shops in my town and found these fishing rod tubes for 0.6 Euro a peace
These rods are light about 35 grams for 50 cm with diameter of 1.9cm at one end and 1.7cm at the other. They are tough and will not bend much... but they are thin... about 1mm or so. All good but the problem is they schread easily if you cut them and I don't think drilling a hole in them is a good idea. For this I had to find a solution that doesn't imply drilling so I came out with the idea of a clamp (that one I cut just for the idea it is not the final thing):
To hold the arm in position I am thinking at these pipe fixing clamps found in all plumber shops:
For motor mounts I will use the same type of metal clamps as I have no other viable solution. The main problem here is the conical structure of the tube that will not fit a standard motor mount.
For centre plate I want to use carbon fibre plate of 2.5mm as there is a guy here in Romania selling them 2.5x300x350mm 10 layers for 40 Euro/plate. Do you know a better offer?
Motors - I was thinking of buying some of the RCTimer motors for this task and I would like to know if anybody here can recommend one motor to work with the Mikrokopter system? - http://www.rctimer.com/index.php?app=goods&spec_id=159 I think this is a good choice as it is close to what MK is recommending... I will try to buy more of these so I have spare ones in case they fail.
For props I will go with some APC Slow Fly Prop 12 x 3.8SF or 12x4.7 for hover power. Do you think is worth going for larger ones? APC Slow Fly Prop 14 x 4.7SF? or is it overkill?
Any advice would be welcomed.
Please excuse the big pictures but better bigger than too small.
danielpetrescu is offline Find More Posts by danielpetrescu
Old Mar 18, 2010, 03:01 PM
Tulcea Romania
Joined Mar 2010
Hmm... I see no one had any new ideas
Old Mar 18, 2010, 03:28 PM
chickenblender is offline
Find More Posts by chickenblender
Free Tinker
chickenblender's Avatar
Augusta, GA
Joined Jan 2007
Wow, your tight budget is way different than my tight budget. This is way out of my league. One question I have is why build an octo since many smaller props are much less efficient than fewer large ones?
chickenblender is offline Find More Posts by chickenblender
Old Mar 18, 2010, 05:30 PM
Smokytyrz is offline
Find More Posts by Smokytyrz
The Dude
Smokytyrz's Avatar
Louisiana, USA
Joined Jan 2009
How small does it need to be? Something like this isn't that big:
http://www.nghobbies.com/cart/index....roducts_id=454
Smokytyrz is offline Find More Posts by Smokytyrz
Old Mar 19, 2010, 05:42 AM
Tulcea Romania
Joined Mar 2010
Well in reality there is no tight budget for such things ... maybe I should have said limited budget .
When you want to fly a SLR camera you have to think on safety too as the camera price can exceed the price of the whole setup. I think 8 propellers are ok for this project and don't forget that most of the quads and octos out there use 10" props while I intend to use 8 props 12 or 13" for hover power as I am not interested in acrobatics and agility just stability.
One of the main features is the folding arms as I will have to transport the rig. I could also build a 4 arms coax octo but all people say that coax-es are not so efficient and not so ergonomic as any unbalance on the ground will produce some broken props. Also the down facing motors are hard to handle as you can get cut by the props by trying to catch it.
This guy has build lots of multi rotors - http://plischka.at/MK9-Y6.html and he has some experience.
I might reconsider and try using the quadpower board but it has issues and no gps yet. Any ideas about a good quad folding frame?
Old May 03, 2010, 03:48 AM
Imagecatcher is offline
Find More Posts by Imagecatcher
Imagecatcher's Avatar
NSW Australia
Joined Mar 2010
My Folding Octo
I am in the same situation and have developed this
http://gallery.me.com/imagecatcher/100191
you might get some ideas.
Imagecatcher is offline Find More Posts by Imagecatcher
Old May 07, 2010, 02:46 PM
Tulcea Romania
Joined Mar 2010
Thanks for the pictures. You have a great idea there and you have put a lot of work in it. It looks great. What is the total wheight? And.. Does it fly?
In the end I think I will go with a coax okto as it is simpler and smaller. What do you think about the folding arms? Is there any inconvenience to it?
Old May 08, 2010, 11:18 AM
jesolins is offline
Find More Posts by jesolins
Tri-Quad-Hexa-Octo-copters!!
Joined Feb 2007
I would suggest just making pinch mounts for the arms and then removing and unplugging as many as you need to for packing and portability. Keep it simple. A flat octo or hexa is more efficient and perrforms better.
Cheers,
Jim
Quadrocopter and Tricopter Mega Link Index
jesolins is offline Find More Posts by jesolins
Old Mar 24, 2014, 09:10 AM
gtxkid is offline
Find More Posts by gtxkid
1300mm Octo K130 / Mikado Logo
United States, FL, Gulf Breeze
Joined May 2006
You need to look at two links, there is NO way you can build something yourself to get something so sweet.
Cheep and super cheep that are top of the line in quality and durability.
http://www.rcgroups.com/forums/showthread.php?t=2054477
http://www.shop.aglhobbiesllc.com/UA...cto-Frame.html
I have study this for long time now and it does make sense to have a folding booms.
One has them and the other you would have to modify, but the components are cheep and high quality with lifetime warranty.
FU from foxtech has the market cornered with his K130 and is so cheep with the only large frame out there, could only compare it
to the very expencive DJI S100
Now as another option you could look at the tarot 960, seams to be a very popular unit for DLSR.
Stay with an octo.
Do not get anything that stacks one motor on top of anouther like that Y=6
gtxkid is offline Find More Posts by gtxkid
Old Apr 02, 2014, 01:30 PM
Tulcea Romania
Joined Mar 2010
Stay with an octo.
Thanks for the reply but this post is so old... now I have build a few quads and I will stick to them. Check my other posts.
Cheers,
Daniel
Discussion Need help with new set up on B28 hampboats Racing Boats - Electric 16 Jan 11, 2010 12:30 PM
Discussion I need help with music selection on my next vid. BushmanLA Life, The Universe, and Politics 10 Dec 24, 2009 03:09 PM
Discussion need help with hardware on Dumas DeepVee 60 the larch Racing Boats - Internal Combustion 2 Nov 23, 2009 03:58 PM
Help! Need help with CPD4 on student foamie planes LexDM3 FMA Direct 0 Nov 10, 2009 02:57 PM
Need Help with Large Servo Arms & Linkage Setups Diego642 3D Flying 3 Jul 26, 2005 11:26 PM
