Old May 02, 2010, 11:35 AM
Daniel Wee is offline
Find More Posts by Daniel Wee
Joined Aug 2005
barok,
What kind of GPS module are you using? And what version of firmware? I noticed that you have many satellites detected. Could you try covering the GPS so that less satellites are detected and see if that allows the OSD to go on without resetting?
Daniel
Daniel Wee is offline Find More Posts by Daniel Wee
Old May 02, 2010, 02:27 PM
barok is offline
Find More Posts by barok
barok's Avatar
Joined Apr 2006
hi daniel.. it is 6.1ver. and gps is LS20033 5 HZ
when its ok, while flying, i find the home arrow pointing away from me(the home or GS)..any thought on this one also..
thanks..
barok is offline Find More Posts by barok
Old May 02, 2010, 02:37 PM
gobigkahuna is offline
Find More Posts by gobigkahuna
United States, CA, San Diego
Joined Nov 2008
Sounds great! You're running in PAL mode, right? One thing I'm not clear on about the camera, I thought I read that it does both NTSC and PAL. Does that look to be the case?
Originally Posted by magnetman View Post
OK Guys... This camera is fantastic, just switched on running through the DOSD+. Best vid quality I have seen, but I'm comparing it to a KX 141 480 TVL cam.
Word of caution - have a close look at the input connector, on mine, it seems that someone has tried to put the wrong size pins in the plug, with a risk of shorting. I ended up fitting a spare plug I had, plus bespoke vid/ power lead.
ralso Remember this cam needs 12V not 5.
Now for that IMU testing.....
gobigkahuna is offline Find More Posts by gobigkahuna
Old May 02, 2010, 03:08 PM
magnetman is offline
Find More Posts by magnetman
Fly the Discombooberator!
magnetman's Avatar
Joined Nov 2003
Hiya Gobig,
Funny you should say that... it is not selectable but mine is PAL by default, I guess because i'm in UK... I don't actually remember asking. The part number for mine is PZ0104 -P where the P must mean PAL.
Daniel/John - IMU V 1.6 F - yes correct baudrate now works. Here is a short clip demonstrating the IMU, although I can't say I'm all that impressed with thequality of my video recording - it was pretty good live, and I have not done any focussing adjustments on the camera yet
http://www.youtube.com/watch?v=xTVbVccFcJU
magnetman is offline Find More Posts by magnetman
Old May 02, 2010, 05:07 PM
Virgis21 is offline
Find More Posts by Virgis21
FPV flyer
Virgis21's Avatar
Kaunas, Lithuania
Joined Oct 2007
I had a flight today with the latest firmware. tested stabilization
little with autopilot
the ArduIMU wasn't in parallel with airplane, so artificial horizon was not as suppose to be but so far I am happy with it!
Flight video is uploading now, i will post as soon it will be available.
here is my setup
Dragon Labs (0 min 37 sec)
DOSD+ IMU test (2 min 5 sec)
Virgis21 is offline Find More Posts by Virgis21
Old May 02, 2010, 06:24 PM
mark hitchman is offline
Find More Posts by mark hitchman
Zephyr 66" Blunt
mark hitchman's Avatar
New Zealand
Joined Sep 2009
That worked awesome, I might have to re-calibrate my IMU, yours looked to stay more accurate than mine, how long have you let the autopilot run for, was keen to see if it got it back under control.
Mark
mark hitchman is offline Find More Posts by mark hitchman
Old May 02, 2010, 07:25 PM
jimbob00 is offline
Find More Posts by jimbob00
Joined Aug 2009
is it me or in most videos the imu always drifts/"de"calibrate somehow at some point, just tracks a little less good. i wonder whats causing that. after a few turns it "comes back". even on those +- stable planes without rolls etc
jimbob00 is offline Find More Posts by jimbob00
Old May 02, 2010, 09:04 PM
Joined Aug 2005
barok,
Can you try the OSD+GPS unless less sky view so that the GPS won't see so many satellites and let me know if it starts up normally? I need to know this in order to fix this problem.
As for the home being pointed in the wrong direction - I cannot see any problem in the code and all the other users seem to have it working correctly. Can you do more tests and describe the problem in more detail?
jimbob00,
That is the nature of IMUs. The IMU ascertains the attitude using a combination of gyros and accelerometers. The gyros are only good for the very short term due to accumulating biases and drift, and needs to be corrected by the accelerometers. Unfortunately, the accelerometer is only good for the longer term due to it being affected by temporal accelerations. The IMU code tries to decide which to use at all times, and uses them in a kind of combination. The point though is that it is hard to get a perfect estimate of the horizon under dynamic conditions. This is further compounded by vibrations which can impair the accelerometer's ability to correctly measure the gravitational vector.
Ideally, you have a heavily damped, non-vibrating, accurately calibrated accelerometer, and highly stable gyros. In practice, this would be considerably more expensive and in the case of damping, would be heavier as well. So the best we can do is to accurately calibrate the accelerometer, reduce vibrations, and avoid flying long coordinated turns. In fact, the performance of the ArduIMU+ can be further augmented by using GPS data. I will leave that to a later stage though, as right now I am trying to optimize the inertial solutions.
What you will see then, is over time - the horizon will drift, due to the gyro's accumulated error, but whenever the opportunity presents itself (such as when not turning), the accelerometer will correct for the errors and the horizon will improve. This whole balance of which to use and when, is the tweaking process I referred to some posts ago and can be a tedious process. Firmware 1.6f represents both code changes, as well as tweaks I have made while driving a car in circles.
I should also add that temperature will affect the amount of gyro drift and I am not sure that the ArduIMU+ code actually compensates for thermal drift at this point of time. What might be a possible thing to try would be to fly around a bit, and when things have warmed up - to reset everything at operating temperature and fly again. This may help since there is a calibration process at the the booting up stage of the IMU.
Daniel
Old May 02, 2010, 10:00 PM
Joined Aug 2005
Virgis21,
I forgot to mention - great video! Thanks for posting it. A couple of comments:-
1. I noticed that there was a display problem with the gain in the menu, so I have put out version 6.4 which displays the gain in the correct format and allows more granularity.
2. You probably want to use a lower gain so that the plane doesn't "snap" back to level but goes back more gradually. I'm not sure if that will work better but I suspect that it might.
Again, thanks - I really learn a lot from these videos.
gobigkahuna,
I'm not sure if you noticed - but your tilt indicator feature has already been incorporated for a while. You may want to test it out.
mark,
About the resetting of the level, right now my preference would be to have it mounted correctly but I may look into a software option for this at a later stage. The reason is that there are physical performance benefits from mounting the IMU correctly as opposed to compensating for mounting error in software, albeit this might only be a small performance hit.
Daniel
Old May 02, 2010, 10:23 PM
barok is offline
barok's Avatar
Joined Apr 2006
Originally Posted by Daniel Wee View Post
barok,
Daniel
hi daniel...today was a cloudy day, it rained b4 i flew.. i did increase the hdop setting to 2.0, don't remember the default, read here that increasing the number aquires the satelites faster, less wait time..
a short clip of resetting Dosd+
Dosd+ restting.WMV (0 min 33 sec)
couple of pics regarding the gps arrow
Old May 02, 2010, 10:49 PM
Joined Aug 2005
barok,
Aha - so you're talking about that compass mode. Can you check if the other compass modes point you in the right direction? I must admit that I've not tested the arrow much due to lack of use but I will check it out now. Thanks for the heads up.
More importantly, I need to know about the resetting issue during GPS position acquisition. Is the OSD still resetting upon acquiring a GPS lock? Is there any correlation between the resets and the number of satellites in view?
Daniel
Old May 02, 2010, 11:07 PM
plesk is offline
Find More Posts by plesk
plesk's Avatar
Malaysia
Joined Apr 2006
Barok, I also experiencing the same problem as you only in compass modes. The DOSD+ keep restarting
barok,
Daniel
plesk is offline Find More Posts by plesk
Old May 02, 2010, 11:33 PM
Joined Aug 2005
plesk,
That's a great clue. Let me check it out.
Can you guys try out version 6.4 and see if this problem is still there?
Daniel
Old May 02, 2010, 11:51 PM
barok is offline
barok's Avatar
Joined Apr 2006
barok,
Daniel
ya that what i meant compass arrow... will try other compass mode 2morrow..
as for the re-setting, the Dosd+ will lock for say 5 second then it do that video clip..it takes 5 attemps of unplugging/plugging the CS lipo bat. there's also the wait time 3-5 min. there's about 10 bars...then it cycles-re-sets like the vid. when i do get a lock the osd is fine..3 video today 7, 10, 12 satellite..
hope that help daniel..
Old May 03, 2010, 12:13 AM
Joined Aug 2005
barok,
Can you try out version 6.4. The compass issue is fixed in there (hopefully). Not sure if the GPS reset issue is also addressed.
Also, in your case, there is no need to increase HDOP valid - that is only necessary if you are getting poor satellite views.
What I would like to know is if it still resets when:-
1. you use the normal compass modes (mode 1 or 2)
2. you use version 6.4 firmware
3. you use all the default settings
Basically I am trying to ascertain if some setting is causing this reset. I just tried a test with all display elements on (but with SAFEZONEX and SAFEZONEY at 0), with the same LS20033 GPS, with compass mode 3, current sensor - the works, in PAL mode. With firmware 6.4 I was unable to get the OSD to reset. However, I only had 5 satellites in view. So maybe you can use that as a reference.
Daniel
Discussion Dragon OSD Level Flight FPV Talk 22 Dec 31, 2013 08:08 PM
For Sale New Intelligent Flight Dragon OSD bfischer Aircraft - General - Miscellaneous (FS/W) 7 Jul 19, 2010 11:56 AM
Discussion FS Ready to fly Intelligent Flight Dragon OSD bfischer FPV Talk 0 Mar 03, 2010 05:57 AM
Discussion RV OSD or Dragon OSD djdaveq FPV Talk 1 Feb 06, 2009 12:18 AM
Discussion RV OSD and Dragon OSD - so near to being Really good! magnetman FPV Talk 8 Nov 11, 2008 05:13 AM
