I am pretty sure it should be powered through the 6 to 8 volt in.
http://code.google.com/p/ardu-imu/wiki/Hardware |
The two system work independant of one another. The copilot attempts to keep the plane stable to when you have it on it mutes your control inputs keeping the plane stable. So then you use the dosd+ rth function and it will attempt to steer your plane home while at the same time the copilot ensures that the plane is flat and level. They sort of fight each other to be honest to get the desired effect. To connect run the servo outputs from the dosd+ through the copilot then on to the servos. |
i tried to pass controls from osd to servo via Co-pilot. but didn't like the servo job, they glitch all the time. servo buffer didn't help at all. so i decided to do so:
co pilot works only on aileron Dragon osd (RTH) controls elevator and ruder. so nothing will conflict. but as long IMU is here, so it's time to sell Co-pilot! ![]() Daniel confirmed about 5v to ArduIMU, but must be connected where TTl cable connects (mine usb-TTL has 5V out). but will be ok to start together DOSD+ and IMU at the same time? because at first startup, i connected ArduIMU to DOSD+ but didn't power up. DOSD+ didn't boot until i connected IMU. Will see. |
| Thread Tools | |
| Discussion Dragon OSD | Level Flight | Video Piloting (FPV/RPV) | 20 | Apr 17, 2011 12:12 PM |
| For Sale New Intelligent Flight Dragon OSD | bfischer | Aircraft - Electric - Miscellaneous (FS/W) | 7 | Jul 19, 2010 11:56 AM |
| Discussion FS Ready to fly Intelligent Flight Dragon OSD | bfischer | Video Piloting (FPV/RPV) | 0 | Mar 03, 2010 05:57 AM |
| Discussion RV OSD or Dragon OSD | djdaveq | Video Piloting (FPV/RPV) | 1 | Feb 06, 2009 12:18 AM |
| Discussion RV OSD and Dragon OSD - so near to being Really good! | magnetman | Video Piloting (FPV/RPV) | 8 | Nov 11, 2008 05:13 AM |
