Old Apr 28, 2010, 03:01 PM
Virgis21 is offline
Find More Posts by Virgis21
FPV flyer
Virgis21's Avatar
Kaunas, Lithuania
Joined Oct 2007
i just tried to upload firmware into ArduIMU via TTL converter cable. everything connected as Daniel described, but got this message:
Maby tx and rx are reversed?
I tried other versions, didn't succeed
P.S. sorry, my mistake, rx and tx was reversed, after changing it and pressing reset button after compiling made upload complete!
Virgis21 is offline Find More Posts by Virgis21
Old Apr 28, 2010, 03:10 PM
Virgis21 is offline
FPV flyer
Virgis21's Avatar
Kaunas, Lithuania
Joined Oct 2007
Mike,
As i see this sensor you got, has only Analog output? it is not compatible with I2C P... ??
Old Apr 28, 2010, 03:23 PM
MikeTheCrash is offline
Find More Posts by MikeTheCrash
Just clumsy. Oh, forgetful too
MikeTheCrash's Avatar
undefined
Joined Jun 2008
Originally Posted by Virgis21 View Post
Mike,
That's what I was beginning to think when i read the data sheet
D'oh!
I guess I don't need stacking connectors now.
MikeTheCrash is offline Find More Posts by MikeTheCrash
Old Apr 28, 2010, 03:59 PM
Shikra is offline
Find More Posts by Shikra
SILURIA / UK
Shikra's Avatar
United Kingdom
Joined Jun 2009
Originally Posted by badlands View Post
Shikra - just tried that Locosys GPS mod - wow it works well. I dont quite get a 2 min fix but it has definately halved my 'setting home' time.
Thanks bud!
Glad it works!
This one works very well on the DOSD+ too. It's the one I used on my vid I posted earlier.
Jett - your right - that was a bit of a cockup. I noticed that on my newer one Locosys appear to have attempted a mod themselves - there is a piece of sticky aluminium running along one of the sides. I removed this and soldered it up properly! Since then, not having a backup really hasn't been an issue as it locks quickly. Probably a source of frustration of many OSD users. It was for me with my first one.
Shikra is offline Find More Posts by Shikra
Old Apr 28, 2010, 04:26 PM
Virgis21 is offline
FPV flyer
Virgis21's Avatar
Kaunas, Lithuania
Joined Oct 2007
i just came through the latest firmware upload, and made these calibration (max and min) values for AN3, AN4, An5 at first it was confusing, but latter got it
Finally my IMU is done i am lucky by test only in hands. Video is uploading and will be posted latter..
DOSD+ firmware 6.1. ArduIMU Version 1.6f (the latest one)
Sorry for the mess in my workplace
I was holding camera and imu little not parallel so horizon isn't as camera was
Testing ArduIMU with DragonOSD+ (1 min 6 sec)
P.S. how to connect Pressure/temp sensor if ArduIMU is connected already?
Old Apr 28, 2010, 04:38 PM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Thanks for the replies.
Hmm.. on the GPS module. I have it, so may as well use it. I could add a battery, I think I recall seeing a mod for that on the web - using just a lithium button cell?
..a
Old Apr 28, 2010, 06:09 PM
undefined
Joined Jun 2008
Virgis21 or Daniel I'm trying to open up the arduimu.exe with the Arduino.exe program, but there's only arduimu.pde file on the zipped firmware folder I downloaded from Tsebi Projects...is that the right one?
thanks
Old Apr 28, 2010, 06:20 PM
mark hitchman is offline
Find More Posts by mark hitchman
Zephyr 66" Blunt
mark hitchman's Avatar
New Zealand
Joined Sep 2009
Hi,
Andy W, I was thinking about adding a battery too, Range video uses a supercap I think which is a long power holding capacitor. Not sure where to get though.
Virgis21,
The IMU is cool aye, my last flight was with my funjet and it worked really good on roll but pitch is a bit slow still, still I think it's ready to couple to the autopilot
Only problem with my video I recorded was the camera is aiming too low and the AHI is only level with the horizon when I am climbing. I am now in the proces of moving the dosd+ to my foam glider which is reasonably stable with 2 meter wingspan. Not sure how to power my 12 volt video transmitter from my 2 cell lipo, any ideas?
Daniel,
Not sure if you are back yet but I was wondering if you are considering coupling the IMU to the autopilot yet?
Mark
mark hitchman is offline Find More Posts by mark hitchman
Old Apr 28, 2010, 06:23 PM
Zephyr 66" Blunt
New Zealand
Joined Sep 2009
Mike the crash, I think the guide is wrong, open the .pde file from inside Arduino program.
Mark
Old Apr 28, 2010, 06:31 PM
Daniel Wee is offline
Find More Posts by Daniel Wee
Joined Aug 2005
Guys,
I just got back and am still reviewing the IMU data. I'm still not entirely happy with it and am still trying to improve the code.
MikeTheCrash,
There is no arduimu.exe, only arduimu.pde and that's the one you want to open.
Also, fortunately for you, the DOSD+ also accepts analog temperature sensors. However, you may want to use the port for RSSI rather than temperature. It can use either one analog sensor as input but not both.
For those of you wanting to connect more than one I2C device, just daisy chain it. Same wires go to each of them. So the SCL goes to device #1's SCL, and you just hook up another wire out to device #2's SCL, and so on. In this way, the DOSD+ can support multiple devices.
Daniel
Daniel Wee is offline Find More Posts by Daniel Wee
Old Apr 28, 2010, 08:32 PM
Zephyr 66" Blunt
New Zealand
Joined Sep 2009
IMU 1.6f
Funjet DOSD+ IMU firmware 1.6f (2 min 50 sec)
Old Apr 28, 2010, 09:18 PM
Joined Aug 2005
mark,
Thanks for that video - now - THAT was very very good. If the IMU performs like that for most guys, I think I will start working on integration. I am also testing some different (and more expensive IMU's) but that's the best video I've seen yet.
Daniel
Old Apr 28, 2010, 09:47 PM
David22 is offline
Find More Posts by David22
North vancouver, B.C. Canada
Joined Apr 2008
very cool video showing the horizontal thing working very well
Originally Posted by mark hitchman View Post
David22 is offline Find More Posts by David22
Reply With Quote  (Disabled)
Old Apr 28, 2010, 11:46 PM
gobigkahuna is offline
Find More Posts by gobigkahuna
United States, CA, San Diego
Joined Nov 2008
Hi Daniel, welcome back! You asked me to remind you about "camera pan /tilt" when you got back.
gobigkahuna is offline Find More Posts by gobigkahuna
Old Apr 29, 2010, 04:39 AM
undefined
Joined Jun 2008
I think I've uploaded the firmware to the ArduIMU+ V2, I get the flashing lights, but when I connect it to the OSD and power up, the OSD won't initialise.
there's no power going to the IMU, does it get it from the SDA SCL lines or do i need to supply 5v like when loading software?
thanks
Discussion Dragon OSD Level Flight FPV Talk 22 Dec 31, 2013 08:08 PM
For Sale New Intelligent Flight Dragon OSD bfischer Aircraft - General - Miscellaneous (FS/W) 7 Jul 19, 2010 11:56 AM
Discussion FS Ready to fly Intelligent Flight Dragon OSD bfischer FPV Talk 0 Mar 03, 2010 05:57 AM
Discussion RV OSD or Dragon OSD djdaveq FPV Talk 1 Feb 06, 2009 12:18 AM
Discussion RV OSD and Dragon OSD - so near to being Really good! magnetman FPV Talk 8 Nov 11, 2008 05:13 AM
