Old Jan 24, 2011, 11:24 AM
cherokee180c is offline
Find More Posts by cherokee180c
KB3VOJ
cherokee180c's Avatar
USA
Joined Sep 2007
Originally Posted by Coyote64 View Post
Nice 1 cherokee180c, i never thought about that, all my OSD`s power off the current sensor without issue so just didnt think twice about it
So what are you and Mark doing then, cutting the positive and ground wires off the current sensor wire and feeding that into an LC filter first before going to the OSD? That sounds like what Mark is doing. Are you powering all other 12V or 5V step-down devices (ie camera and Vtx) from those same wires? None of that is covered in the manual or anything else I have seen. I also wonder is that 12V that comes out of the sensor after the sensing circuit so all current passing through would be totalized in the OSD? For me it is just easier to leave as provided and run the dedicated filtered 12V.
cherokee180c is offline Find More Posts by cherokee180c
Old Jan 24, 2011, 12:01 PM
Tankogen is offline
Find More Posts by Tankogen
Tankogen's Avatar
USA, AZ
Joined Jun 2010
I am finally attempting first autopilot flight (soon), meanwhile in early versions the control surface's moved while in-menu, now they just freeze.... you work with menu and exit to regain control. Is there exact setting? or something everyone decided? thanks you all!! Good day!
Tom-
Tankogen is offline Find More Posts by Tankogen
Old Jan 24, 2011, 01:28 PM
Virgis21 is offline
Find More Posts by Virgis21
FPV flyer
Virgis21's Avatar
Kaunas, Lithuania
Joined Oct 2007
just another test.
Some place works OK, some - not.
Another Ap test (4 min 34 sec)
Virgis
Virgis21 is offline Find More Posts by Virgis21
Old Jan 24, 2011, 02:11 PM
beginner4life is offline
Find More Posts by beginner4life
beginner4life's Avatar
United States, MD, Ellicott City
Joined Mar 2008
I got a cx161 that is a 5v camera...Im going to change to a one battery setup, so can someone give me a list of what i need to get the voltage down to 5 and also to prevent noise?
I was thinking this
http://www.dpcav.com/xcart/product.p...8&cat=0&page=1
and this
http://www.dpcav.com/xcart/product.php?productid=16497
beginner4life is offline Find More Posts by beginner4life
Old Jan 24, 2011, 03:03 PM
devfor is offline
Find More Posts by devfor
O <- this a ground loop
Japan
Joined Nov 2010
I was thinking this
and this
If you can handle a soldering iron then a 7805 regulator rated at 500mA or 1A would give you noise free power for your camera.
Assuming your camera draws 100~200mA its not a great deal of energy lost to heat. Cheaper than a BEC and no noise (in theory).
12-5 =7v
7v x 0.15A = 1.05w
http://forum.allaboutcircuits.com/sh...d.php?p=177439
Ren
devfor is offline Find More Posts by devfor
Old Jan 24, 2011, 03:20 PM
Derek_S is offline
Find More Posts by Derek_S
Videopilot
Derek_S's Avatar
United States, NC, Charlotte
Joined May 2009
I was thinking this
and this
As mentioned a 7805 works well. It does get very hot though when powered by 3s, so just be sure it has access to cooling air. I do not know how hot it can get before it is damaged, but mine easily gets hot enough to melt hot glue..
Derek_S is offline Find More Posts by Derek_S
Old Jan 24, 2011, 03:30 PM
badlands is offline
Find More Posts by badlands
When in doubt, throttle out...
badlands's Avatar
Joined Mar 2010
Is that with or without a heatsink?
badlands is offline Find More Posts by badlands
Old Jan 24, 2011, 03:43 PM
MikeTheCrash is online now
Find More Posts by MikeTheCrash
Just clumsy. Oh, forgetful too
MikeTheCrash's Avatar
undefined
Joined Jun 2008
if you want to position hold with the position set in the menu, do you have to set waypoint to "1" or is it "home"/"0"?
thanks
MikeTheCrash is online now Find More Posts by MikeTheCrash
Old Jan 24, 2011, 04:39 PM
KB3VOJ
USA
Joined Sep 2007
That was my 7805 that i just made in the video. It was easy but you do need a hat sink if running on 3S. I am using for the VTx, so about 3 watts to heat.
Old Jan 24, 2011, 04:42 PM
Derek_S is offline
Videopilot
Derek_S's Avatar
Joined May 2009
WITHOUT! I just put it outside hanging in the wind and it keeps it cool enough I guess. A heat sink would be good insurance.
Old Jan 24, 2011, 06:54 PM
badlands is offline
badlands's Avatar
Joined Mar 2010
cool (like your regulator!)
Old Jan 24, 2011, 07:06 PM
Coyote64 is offline
Find More Posts by Coyote64
Praying for better weather
Coyote64's Avatar
Joined Dec 2007
I have a theory for an idea, ill put it forward see what people think.
When your testing you new install DOSD you have to check Autopilot etc, to test the control surfaces etc you either need someone on the ground running around a field or test in the air.
My suggestion is, how about an interface to connect to the DOSD in place of the GPS sensor to send fake data.
You sit your plane at home on your bench, plug in a PC, play a simulated gps signal to the OSD and you can monitor, adjust or reverse controls fom the menu before taking it anywhere in safety. A simulated flight can be programmed in so AP activation could be checked, you could compare control surfaces to OSD screen and double check everything before going anywhere
Coyote64 is offline Find More Posts by Coyote64
Old Jan 24, 2011, 07:27 PM
Vantasstic is offline
Find More Posts by Vantasstic
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
thanks
Funny you should mention this. I was experimenting with the Hold function. You want your waypoint to 0 AND set your waypoint mode to HOLD...you can set this up before launch. Now while in flight you enter menu, select the Hold position in the main menu (by scrolling down to it an then hitting right aileron)...you won't see anything to indicate the Hold position was set, now whenever you flick to AP mode the plane will head for the HOLD position and circle it until you turn off AP. You'll ALWAYS been in HOLD mode whenever you hit the AP switch. To return to RTH mode you must change the waypoint mode off HOLD. I set mine to 'next' and got RTH back. You'll notice the screen with say either Autopilot <HOLD> or Autopilot <Home> when in AP mode. The key here is setting HOLD for the Waypoint Mode. The small your hit distance the tighter the plane turns to keep in the hold area. I had mine set for 30m and it worked pretty well. Probably 100m or more would give a larger and smoother turn.
Vantasstic is offline Find More Posts by Vantasstic
Old Jan 24, 2011, 07:30 PM
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
I believe the DOSD has some sort of simulator in it already...at least older versions did and Daniel didn't make mention of removing it yet. I forget how to enter it and I've never tried it. Perhaps someone who has more insight can chime in on what it does and how it works. It's kinda a hidden feature and not documented, that I could find at least.
Old Jan 24, 2011, 08:51 PM
Justin C is offline
Find More Posts by Justin C
Adelaide, Australia
Joined Aug 2010
Hi,
I'm new to this thread and was just curious about a couple of things...
1) Does Daniel have a antenna tracker?
2) Does the waypoint function work in all countries?
Excuse me if I have overlooked something as like I said I am new. I have been using rvosd and dont YET have UHF.
Justin C is offline Find More Posts by Justin C
Discussion Dragon OSD Level Flight FPV Talk 22 Dec 31, 2013 09:08 PM
For Sale New Intelligent Flight Dragon OSD bfischer Aircraft - General - Miscellaneous (FS/W) 7 Jul 19, 2010 12:56 PM
Discussion FS Ready to fly Intelligent Flight Dragon OSD bfischer FPV Talk 0 Mar 03, 2010 06:57 AM
Discussion RV OSD or Dragon OSD djdaveq FPV Talk 1 Feb 06, 2009 01:18 AM
Discussion RV OSD and Dragon OSD - so near to being Really good! magnetman FPV Talk 8 Nov 11, 2008 06:13 AM
