Old Apr 21, 2010, 09:55 AM
badlands is offline
Find More Posts by badlands
When in doubt, throttle out...
badlands's Avatar
Joined Mar 2010
Originally Posted by alexedit View Post
talking about stupid questions, here is mine. Could I fly with a 2.4 video transmitter and 2.4 airplane receiver in the same plane and be ok?
I am sure this has been asked before, but I have not been able to find a real answer. --- this is my only option till I get a DL
I'm no expert - only just had my 1st FPV flight 3 days ago but i did try a 2.4Ghz video link with my Spektrum (also 2.4ghz) as expected they both interfered with each other, for me totally unusable.
badlands is offline Find More Posts by badlands
Old Apr 21, 2010, 04:40 PM
Virgis21 is offline
Find More Posts by Virgis21
FPV flyer
Virgis21's Avatar
Kaunas, Lithuania
Joined Oct 2007
I have tested the 2nd osd just received today. John has made some modifications to work with other cameras that didn't work with stock. Dx201 looks working. but..
DOSD+ and dx201 :( (0 min 46 sec)
then connecting dx201, text shades is darker, but menu doesn't work. Any suggestions?
version 6.1, just updated few minutes ago
Virgis21 is offline Find More Posts by Virgis21
Old Apr 21, 2010, 06:10 PM
badlands is offline
badlands's Avatar
Joined Mar 2010
I had similar probs using one of my ebay CCD cams, have you tried adding a capacitor inline with the cam feed into DOSD+?
Worked for me.
http://www.forum.tsebi.com/viewtopic.php?f=7&t=74
Good luck...
Old Apr 21, 2010, 07:18 PM
barok is offline
Find More Posts by barok
barok's Avatar
Canada, ON, Toronto
Joined Apr 2006
Originally Posted by barok View Post
hey daniel, john.. good news.. my bad.. i label'ed the video wire wrong, DOH!!, it was reversed.. so all is well now.. sorry for the drama..
thanks..
vergis21.. i had similar problem.. you're video wire is reversed on the connection to the dosd+
http://www.rcgroups.com/forums/showp...&postcount=310
i see the other cam has a clearer text..i have that same text in your 2nd image(the one w/problem)..think i'll get another cam..
this one.. http://www.securitycamera2000.com/pr...Security-.html
any thoughts??
barok is offline Find More Posts by barok
Old Apr 21, 2010, 08:42 PM
Dialfonzo is offline
Find More Posts by Dialfonzo
DiaLFonZo - UAV/Drone
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Video Problem
Virgis21
I had the same problem with my cheap camera.
Try That:
Dialfonzo is offline Find More Posts by Dialfonzo
Old Apr 21, 2010, 11:52 PM
edberg91 is offline
Find More Posts by edberg91
Joined Jul 2009
Can anyone list a few PPM receivers that will work with the OSD without modification? Plug and play? I have a JR XP6102.
edberg91 is offline Find More Posts by edberg91
Old Apr 22, 2010, 02:55 AM
magnetman is offline
Find More Posts by magnetman
Fly the Discombooberator!
magnetman's Avatar
Joined Nov 2003
I do not beleive there are any out there with an existing PPM stream output - unless someone knows different - in which case we would all be using them.
magnetman is offline Find More Posts by magnetman
Old Apr 22, 2010, 05:07 AM
renatoa is offline
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
Indeed...
renatoa is offline Find More Posts by renatoa
Old Apr 22, 2010, 05:30 AM
CrashingDutchman is offline
Find More Posts by CrashingDutchman
CrashingDutchman's Avatar
The Netherlands, Utrecht, Amersfoort
Some are very easy to modify. For example this receiver at DealExtreme is an easy one.
More information for adding a PPM pin can be found in this picture (see yellow wire):
I did the modification (on the 35MHz variant). I took a 3 pin male header. Removed 2 of the pins and glued the plastic part of the header with CA to the black box on the left side of the receiver (with the text CFWM - 455HT on it).
Europeans (35MHz) can use this receiver.
CrashingDutchman is offline Find More Posts by CrashingDutchman
Old Apr 22, 2010, 06:22 AM
renatoa is offline
Joined Sep 2007
The Hitec Electron 6 DC I am using for tests become crazy when I solder the PPM out wire.
How is this noname receiver behaviour ?
Old Apr 22, 2010, 06:29 AM
I have done the mod last weekend. Didn't have time to test it yet.
My information (and the photo) came from this thread at the Arduino forums. See at bottom of the page. I assume from reading that thread that the poster (mem) tested it.
Old Apr 22, 2010, 08:56 AM
badlands is offline
badlands's Avatar
Joined Mar 2010
Nice share CrashingDutchman, worth grabbing one of these as the shipping is free also.
Thanks.
Old Apr 22, 2010, 09:39 AM
Every receiver should have a PPM stream pin
Old Apr 22, 2010, 06:44 PM
barok is offline
barok's Avatar
Canada, ON, Toronto
Joined Apr 2006
daniel/john...
oh man... did this mod.. http://www.forum.tsebi.com/download/file.php?id=732 reverse this A2 chip so i thought i can improve the text.. well the whole video image (not just text) got too dark and saturated, chopppy edges so i put it back as before now the video image is stable but its to dark and saturated.. when i remove the DOSD+ without using it,(connect the in and out video wire, ie: jump pin) the video is fine.. so the problem is in the osd.. any ideas?
Old Apr 23, 2010, 02:00 AM
JMSTECH is offline
Find More Posts by JMSTECH
JMSTECH's Avatar
Canada, BC, Duncan
Joined Dec 2006
first of all double check your soldering job if you think it looks fine then replace the diode. I PMed you the digikey part #
John
JMSTECH is offline Find More Posts by JMSTECH
Discussion Dragon OSD Level Flight FPV Talk 22 Dec 31, 2013 08:08 PM
For Sale New Intelligent Flight Dragon OSD bfischer Aircraft - General - Miscellaneous (FS/W) 7 Jul 19, 2010 11:56 AM
Discussion FS Ready to fly Intelligent Flight Dragon OSD bfischer FPV Talk 0 Mar 03, 2010 05:57 AM
Discussion RV OSD or Dragon OSD djdaveq FPV Talk 1 Feb 06, 2009 12:18 AM
Discussion RV OSD and Dragon OSD - so near to being Really good! magnetman FPV Talk 8 Nov 11, 2008 05:13 AM
