Old Jan 10, 2011, 08:44 PM
Vantasstic is offline
Find More Posts by Vantasstic
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Originally Posted by Vantasstic View Post
...2) I did notice how when the GPS locks as it passes 0 that once it starts 'moving' again the controls had a little 'snap'. I'll have to watch my last WP mission to see if I had the same thing.
Yep. I rewatched my WP video and sure as heck, when the GPS heading 'froze' at 000 for a few the plane had a little 'snap' when the heading starting moving again. I don't think most folks would even recognize it, but when you're looking for it, it is there. Hopefully the GPS folks get/have that bugged worked out now.
Vantasstic is offline Find More Posts by Vantasstic
Old Jan 10, 2011, 09:21 PM
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
I know Daniel's 'out of office' for the next several weeks, but thought I'd post this anyway for inputs.
As I mentioned in an earlier post, I was trying to assign channel 9 as my SW control, which would then be passed from my DL Rx to the DOSD in the PPM stream. It didn't work. The DOSD does not seem to recognize any input over channel 8. I went into the diagnostic screen (OSD mode 3) and it only shows 8 channels (r/h side of screen). It shows 8 channels no matter how many/few channels of input it's getting (I can adjust my Tx channel output from 1-9 channels...but it sends out a minimum of 6 no matter what). Has anyone noticed this or worked around trying to get info into the DOSD that is above channel 8?
Old Jan 10, 2011, 11:25 PM
kyle7119 is offline
Find More Posts by kyle7119
United States, IA, Cedar Rapids
Joined Aug 2009
I am having a few problems with an attempted setup for my DOSD. In the past, I have powered my DOSD via the current sensor. However, I am waiting for some equipment for my plane so I decided to play around with a new configuration. I hooked up a y-splitter to my video battery so that my video battery powers both the DOSD and the video tx. The advantage of this is that I can now monitor the voltages of both my video battery and my flight battery.
This setup comes with a serious drawback. I did not filter the power supply in any way, and there is noticeable interference in my video signal now which goes away when I disconnect my DOSD.
Does anyone have a solution for this problem?
kyle7119 is offline Find More Posts by kyle7119
Old Jan 10, 2011, 11:42 PM
Virgis21 is offline
Find More Posts by Virgis21
FPV flyer
Virgis21's Avatar
Kaunas, Lithuania
Joined Oct 2007
Nice video. Two things I did notice.
1) That temp... .9C. Are you kidding. I'd be inside trying to keep warm, not out flying a plane around. . Okay, maybe it's not that bad, but still...to much snow then.
3) Okay, I know I said 'two' earlier...but .9C?????
Van
1. temperature sensor is flying inside (like regular pilot ).
2. yep that "snap" I noticed looking to the plane nonFPV
3. inside.. but inside
Virgis
Virgis21 is offline Find More Posts by Virgis21
Old Jan 11, 2011, 12:57 AM
Virgis21 is offline
FPV flyer
Virgis21's Avatar
Kaunas, Lithuania
Joined Oct 2007
Originally Posted by KrisW View Post
Mmmmm. . . you give me WAYYY too much credit, Virgis. . . . .I'm a noob to this stuff. . ignore my big mouth.
Nice flight. . love the full-speed run. . what song is that? It's very gripping.
Kris Welter
Kris,
we will see who is noob
song is: Sia- Breathe Me (soundtrack from the movie: The O.C.)
Will try waypoints next flyable day (up to 10km).
Virgis
Old Jan 11, 2011, 01:11 AM
mark hitchman is offline
Find More Posts by mark hitchman
Zephyr 66" Blunt
mark hitchman's Avatar
New Zealand
Joined Sep 2009
As I understand it you can fly waypoints with your transmitter off ie: out of radio range, anyone tried it?
Mark
mark hitchman is offline Find More Posts by mark hitchman
Old Jan 11, 2011, 01:57 AM
Virgis21 is offline
FPV flyer
Virgis21's Avatar
Kaunas, Lithuania
Joined Oct 2007
Mark
Mark,
I will try today (if weather will be friendly). Actually for AP doesn't matter is yours tx on or off. I bet can do waypoints over yours transmitter max range..
Ap flies out there, do job (video or photos) and come back.. even no need to have video for whole distance It is risky, but will do latter then will pass more tests around my place.
Virgis
P.S. Mark checkout my last video (one page back).
Old Jan 11, 2011, 03:38 AM
Zephyr 66" Blunt
New Zealand
Joined Sep 2009
Originally Posted by Virgis21 View Post
Mark,
Virgis
Awesome, that looks sweet. Is that with that big wingspan plane?
Mark
Old Jan 11, 2011, 03:40 AM
Virgis21 is offline
FPV flyer
Virgis21's Avatar
Kaunas, Lithuania
Joined Oct 2007
Mark
That's correct! Conclusion - size does mater! (even in wind)
Virgis
Old Jan 11, 2011, 03:42 AM
MikeTheCrash is online now
Find More Posts by MikeTheCrash
Just clumsy. Oh, forgetful too
MikeTheCrash's Avatar
undefined
Joined Jun 2008
Thanks all for nice words (comments). That setup is almost default ( lucky ah?)
And after some advice from Daniel and Kris, i had clue what to change (just a little bit)..
and wola.
Video is still uploading dam that vimeo with plus account
Finaly:
http://www.vimeo.com/18645087
Check out things:
GPS then passes 000 heading, locks Ap for that time
doesn't matter the wind, turns almost the same
how altitude is hold nice +-10m (in turns).
and etc.. any comments are welcome
Virgis
that works very well Virgis, especially in that wind!!
MikeTheCrash is online now Find More Posts by MikeTheCrash
Old Jan 11, 2011, 03:46 AM
Virgis21 is offline
FPV flyer
Virgis21's Avatar
Kaunas, Lithuania
Joined Oct 2007
Thanks guys!
That's why I wanted FY-20 (or IMU) to have stabe flight.. and AP works with Rudder and elevator only! that way the turns are so precise (or it can be done precise) of that way whole system works (FY-20A for ailerons and elevator).
DOSD+ is uploaded with 8km mission just 1.5km max distance, but fly around over roads and etc.. can't do it right now of bad weather (work or weather is always "killing" my plans (()
Virgis
Old Jan 11, 2011, 05:42 AM
devfor is offline
Find More Posts by devfor
O <- this a ground loop
Japan
Joined Nov 2010
Started a swarm that might interest Twinstar II owners
http://www.rcgroups.com/forums/showp...postcount=2030
cheers,
Ren
devfor is offline Find More Posts by devfor
Old Jan 11, 2011, 07:38 AM
KrisW is offline
Find More Posts by KrisW
Eccentricus Magnus
Joined May 2006
I2C peripherals attachment
Okay. . got a question. .. I2C peripherals ALL get attached at the I2C connector. . . how does one "daisy chain" i2C peripherals that do not have in-out plugs for the next peripheral? Kind of reminds me of a SCSI computer drive system. . with no SCSI ports on the components. I really don't think you are supposed to run them all in parallel, i.e all using the same in-out pins in parallel, are you?
TIA
Kris Welter
KrisW is offline Find More Posts by KrisW
Old Jan 11, 2011, 07:40 AM
galaxiex is offline
Find More Posts by galaxiex
my karma ranover my dogma
galaxiex's Avatar
Edmonton,Canada Eh
Joined Jun 2007
Okay. . got a question. .. I2C peripherals ALL get attached at the I2C connector. . . how does on "daisy chain" i2C peripherals that do not have in-out plugs for the next peripheral? Kind of reminds me of a SCSI computer drive system. . with no SCSI ports on the components. I really don't think you are supposed to run them all in parallel, i.e all using the same in-out pins in parallel, are you?
TIA
Kris Welter
Yes, I have hooked them up that way and seems to work fine.
(note; I am not an expert at this... YMMV )
galaxiex is offline Find More Posts by galaxiex
Old Jan 11, 2011, 08:24 AM
KrisW is offline
Eccentricus Magnus
Joined May 2006
Hmm. . .okay.
I have an I2C temp sensor to wire in, in addition to the IMU, so I guess I'l parallel them and see what happens.
Thanks.
Kris Welter
Discussion Dragon OSD Level Flight FPV Talk 22 Dec 31, 2013 08:08 PM
For Sale New Intelligent Flight Dragon OSD bfischer Aircraft - General - Miscellaneous (FS/W) 7 Jul 19, 2010 11:56 AM
Discussion FS Ready to fly Intelligent Flight Dragon OSD bfischer FPV Talk 0 Mar 03, 2010 05:57 AM
Discussion RV OSD or Dragon OSD djdaveq FPV Talk 1 Feb 06, 2009 12:18 AM
Discussion RV OSD and Dragon OSD - so near to being Really good! magnetman FPV Talk 8 Nov 11, 2008 05:13 AM
