Old Apr 15, 2010, 08:45 PM
Cralis is offline
Find More Posts by Cralis
I love FPV!
Cralis's Avatar
Eastern side of Australia
Joined Jan 2007
Daniel, any opinion on this question I asked?
Craig
Cralis is offline Find More Posts by Cralis
Old Apr 15, 2010, 08:46 PM
Dialfonzo is offline
Find More Posts by Dialfonzo
DiaLFonZo - UAV/Drone
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Tanks a lot
Daniel Wee
Look like you modification have work.
http://helifreak.com/album.php?albumid=4620
Now i need to make the gps work..
Dialfonzo is offline Find More Posts by Dialfonzo
Old Apr 15, 2010, 08:54 PM
plesk is offline
Find More Posts by plesk
plesk's Avatar
Malaysia
Joined Apr 2006
Daniel,
OK. Now I get it work. Sorry
plesk
plesk is offline Find More Posts by plesk
Last edited by plesk; Apr 15, 2010 at 09:14 PM. Reason: OK. Now I get it work. Sorry
Old Apr 15, 2010, 09:36 PM
Daniel Wee is offline
Find More Posts by Daniel Wee
Joined Aug 2005
Cralis,
Not at the moment. The problem is we just don't have the funds to put into stocking up on GPS modules and current sensors. However, I think if you make a special request to John, he should be able to help you out with this. I just don't think we can offer this on a large scale.
Dialfonzo,
Another thing you can try, instead of the above modifcation, try inserting a single 75ohm resistor in the camera video line to the OSD (in series). You may, or may not need the capacitor but if this works, you won't need the 220ohm resistor.
Daniel
Daniel Wee is offline Find More Posts by Daniel Wee
Old Apr 15, 2010, 09:50 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Will Try
Daniel Wee
Tanks i will try it that way.
BTW i have the GPS aquired
I have play with X and Y to make lettering fit.
Do it have a way to play with the size of the letterig ?
Old Apr 15, 2010, 09:52 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Forgot something
The information on the left:
Peak Value...
Is popping and disapear all the time. Is it normal ?
Old Apr 15, 2010, 10:08 PM
mark hitchman is offline
Find More Posts by mark hitchman
Zephyr 66" Blunt
mark hitchman's Avatar
New Zealand
Joined Sep 2009
DOSD+ flight
Not much to see really, just flew arounf home. Plane is too heavy now with camera and about a kilometer of wiring that I haven't sorted yet. Shows AHI working but not much else. Tomorrow I will put gear into a glider that will fly smoother. End of video is picture of the plane, it's what I use to crash test
Dosd+ firmware 1.6e extra 300 800mm wingspan foamy (5 min 5 sec)
Mark
mark hitchman is offline Find More Posts by mark hitchman
Old Apr 15, 2010, 11:57 PM
barok is offline
Find More Posts by barok
barok's Avatar
Joined Apr 2006
hi dialfonzo.. have the same rx..nice mod..neat.. just wondering? why do you not have a 5v line in the ppm? and the rssi, signal and ground only.. omit the middle pin (3.3v) on the osd...
http://helifreak.com/picture.php?alb...ictureid=35760
barok is offline Find More Posts by barok
Old Apr 16, 2010, 12:09 AM
Zephyr 66" Blunt
New Zealand
Joined Sep 2009
Hi Daniel, 6.1f looks good, not have time to upload vid now, autopilot and IMU be all working sweet soon with the speed you bring out the changes.
Mark
Old Apr 16, 2010, 02:33 AM
Joined Aug 2005
Dialfonzo,
No, you cannot change the font size. You can however select a display screen with smaller fonts. Try setting OSD mode to 2 and you should see smaller fonts if that's what you're after.
The peak values will only show up if your speed indicates that you have stopped flying, usually. Sometimes it can show up if you are flying into the wind such that the ground speed is zero. GPS fluctuations while stationary can also cause the display to pop on/off depending on how stable your GPS position fix is.
mark,
WOW!!! 1.6e did real well. I think you will like 1.6f more though. For sustained turns, I would expect 1.6f to perform much better but it's a lot of tweaking.
Daniel
Old Apr 16, 2010, 02:49 AM
JMSTECH is offline
Find More Posts by JMSTECH
JMSTECH's Avatar
Canada, BC, Duncan
Joined Dec 2006
Mark:
I can't get over how well that version worked out for you!!! Love your play ground... you lucky MAN!
John
JMSTECH is offline Find More Posts by JMSTECH
Old Apr 16, 2010, 03:53 AM
plesk is offline
plesk's Avatar
Malaysia
Joined Apr 2006
JR PCM RS10DS Receiver
Daniel,
I have found the PCM RS10DS RSSI signal and now DOSD+ can show the RSSI value.
plesk
Old Apr 16, 2010, 05:51 AM
jimbob00 is offline
Find More Posts by jimbob00
Joined Aug 2009
excellent results for this imu video
you should try rolls and loopings, there seemed to be something wrong about it on jettiplot's video (imu not going back exactly on the horizon)
jimbob00 is offline Find More Posts by jimbob00
Old Apr 16, 2010, 08:05 AM
Joined Aug 2005
JettPilot was using an earlier version of the IMU code. Mark is using a newer one with improvements. 1.6f should be even further improved.
Daniel
Old Apr 16, 2010, 08:16 AM
jimbob00 is offline
Joined Aug 2009
no worries, given the results i have no doubt you will have it perfect overtime, still would be good to roll it around a bit so we know it's fixed/working. at least, on my side the only idea i can have of how well it's working is the videos ppl post here.
i have already ordered the imu you guys are using (and the baro from dyidrones) too due to these good results anyway so i can check by myself too soon i hope :P
Discussion Dragon OSD Level Flight FPV Talk 22 Dec 31, 2013 08:08 PM
For Sale New Intelligent Flight Dragon OSD bfischer Aircraft - General - Miscellaneous (FS/W) 7 Jul 19, 2010 11:56 AM
Discussion FS Ready to fly Intelligent Flight Dragon OSD bfischer FPV Talk 0 Mar 03, 2010 05:57 AM
Discussion RV OSD or Dragon OSD djdaveq FPV Talk 1 Feb 06, 2009 12:18 AM
Discussion RV OSD and Dragon OSD - so near to being Really good! magnetman FPV Talk 8 Nov 11, 2008 05:13 AM
