Old Apr 14, 2010, 05:02 PM
barok is offline
Find More Posts by barok
barok's Avatar
Joined Apr 2006
ok.. daniel i got that.. able to move those text..didn't know what that safezone feature was for...
but at boot up (the boot up screen) the very first text.. is still overscaled.. that is where the version is shown, correct???, can't see it cuz it happens in a split second.. even tried to take a pic, but i need 3 hands..
barok is offline Find More Posts by barok
Old Apr 14, 2010, 06:20 PM
Daniel Wee is offline
Find More Posts by Daniel Wee
Joined Aug 2005
barok,
In the serial terminal, just type:-
VERSION
Make sure you are running the latest firmware though as this command didn't do much in earlier revisions. Either that or just watch the message show up when you power up the board.
Daniel
Daniel Wee is offline Find More Posts by Daniel Wee
Old Apr 14, 2010, 07:47 PM
barok is offline
barok's Avatar
Joined Apr 2006
yes got the latest firmware 5.9 installed..
can't type anything in that terminal window in the ds30 loader prog.
how do you put a callsign?
Old Apr 14, 2010, 07:54 PM
plesk is offline
Find More Posts by plesk
plesk's Avatar
Malaysia
Joined Apr 2006
barok,
You should read about the Serial Port here http://forum.tsebi.com/viewtopic.php?f=7&t=63
Also about the commands line here http://forum.tsebi.com/viewtopic.php?f=7&t=70
Right now I only use the terminal commands line while waiting for my Diydrone PPM encoder.
plesk
plesk is offline Find More Posts by plesk
Old Apr 14, 2010, 08:17 PM
Dialfonzo is offline
Find More Posts by Dialfonzo
DiaLFonZo - UAV/Drone
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Serial talk
Barok, and others.
I use Putty to talk to the board. Serial link with ttl interface.
Work good
Dialfonzo is offline Find More Posts by Dialfonzo
Old Apr 15, 2010, 12:18 AM
barok is offline
barok's Avatar
Joined Apr 2006
help pls...ok.. just got another rx futaba r168df,, my hitec6 is very glitcy..
done this ppm mod.. http://blog.uofaarc.org/wp-content/u...1/p1030791.jpg.. tapped it on that #682 resistor as per instruction...can not access the menu... anyone use this rx..??
Old Apr 15, 2010, 01:33 AM
mark hitchman is offline
Find More Posts by mark hitchman
Zephyr 66" Blunt
mark hitchman's Avatar
New Zealand
Joined Sep 2009
Jettpilot, did you power the IMU with 5 or 6 volts? I just flew with 5 volts from my receiver to power it and it seemed sweet, it says 6 on the circuit board but it is a pain to find 6v without adding more junk to the plane. You see any potential problems with 5v?
Mark
mark hitchman is offline Find More Posts by mark hitchman
Old Apr 15, 2010, 07:16 AM
Joined Aug 2005
mark,
You should use 12V. I don't think 5V is highly recommended.
In the meantime, please look at the IMU firmware 1.6e that I have posted. There are extensive instructions to use it but it should produce much better results that earlier firmwares. If you make any tests (even if it's just flying around the field or a short flight), please video it and let me have a look at it so I can improve the performance.
http://forum.tsebi.com/viewtopic.php?f=7&t=76
Daniel
Old Apr 15, 2010, 07:42 AM
Zephyr 66" Blunt
New Zealand
Joined Sep 2009
I am talking about the arduIMU which you have just released firmware "1.6e" , I can not see where you can put 12v only 3.3v 5v and 6v. I presumed the 6volt is for running it, 5volt for serial connection and 3.3v I ave no idea. It worked ok with the 5v going in to where it says 6v.
When the red light comes on from moving the board too fast, is this when it loses symmetry with the horizon. I flew my extra 300 foamy in 60 km/hr winds today and I think it was moving too fast for the IMU to keep up, was way too windy to fly it really. I will work through installing and calibrating with the new firmware and then post the vid
thanks
Mark
Old Apr 15, 2010, 08:08 AM
Joined Aug 2005
If you look carefully you will see that the "6VIN" is really ">6VIN" meaning "MORE than 6V". So 12V will work. If you use 5V, feed it to the 5V input.
Daniel
Old Apr 15, 2010, 10:42 AM
JettPilot is offline
Find More Posts by JettPilot
JettPilot's Avatar
Miami
Joined Apr 2005
Hi Mark,
Just like Daniel said, I used the 12 volts in from my video system. Nothing got super hot and the board seemed to be OK, with it. The only information I had was the >6 V on the board, so I gave it what it asked for, greater than 6 volts
Everyone,
Remember one thing on the IMU, the other day was the first flight ever, there is much more calibration and work to be done, do not expect good results yet, this is a process that will take many test flights by us and then software adjustments by Daniel to perfect as he sees the results of each new code.
JettPilot is offline Find More Posts by JettPilot
Site Sponsor
Old Apr 15, 2010, 11:41 AM
gobigkahuna is offline
Find More Posts by gobigkahuna
United States, CA, San Diego
Joined Nov 2008
Had a bad day the other day. The DC-DC converter on my robot project shorted sending 48 volts (instead of 12) to all my electronics, frying the camera, DOSD+ and who knows what else. I checked and double checked the DOSD+ and it's definitely dead. I don't suppose it's fixable, is it? Good thing I bought two. When did that $99 deal end?
gobigkahuna is offline Find More Posts by gobigkahuna
Old Apr 15, 2010, 12:24 PM
Joined Aug 2005
Darn, sorry to hear that. It's hard to say off-hand if the board is fixable. With some luck, only the switching regulator blew but if the MCU took a hit, that will be hard to remove for you. Let me know if you want to attempt to fix the power supply.
How long was the over-voltage condition? If it was very brief, chances are only the power supply died. Otherwise it's really hard to say.
Daniel
Old Apr 15, 2010, 12:43 PM
Joined Nov 2008
Yeah, it was a pretty expensive "accident". I'm still checking things out, but so far looks like I'm out $500 worth of components. At least the DOSD+ that fried isolated the compass and it's still working, otherwise it would have been another $160.
Fixing it is likely well beyond my soldering skills. After I total up the damage hopefully I'll still be able to afford finishing this project and maybe get another spare DOSD+.
Old Apr 15, 2010, 12:51 PM
Joined Aug 2005
gobigkahuna,
That sounds like an interesting project so why don't you just talk to John - maybe we can do something to help you out.
Daniel
Discussion Dragon OSD Level Flight FPV Talk 22 Dec 31, 2013 08:08 PM
For Sale New Intelligent Flight Dragon OSD bfischer Aircraft - General - Miscellaneous (FS/W) 7 Jul 19, 2010 11:56 AM
Discussion FS Ready to fly Intelligent Flight Dragon OSD bfischer FPV Talk 0 Mar 03, 2010 05:57 AM
Discussion RV OSD or Dragon OSD djdaveq FPV Talk 1 Feb 06, 2009 12:18 AM
Discussion RV OSD and Dragon OSD - so near to being Really good! magnetman FPV Talk 8 Nov 11, 2008 05:13 AM
