Old Apr 13, 2010, 11:33 PM
mark hitchman is offline
Find More Posts by mark hitchman
Zephyr 66" Blunt
mark hitchman's Avatar
New Zealand
Joined Sep 2009
It shows on the boot up screen when you power it up.
mark hitchman is offline Find More Posts by mark hitchman
Old Apr 14, 2010, 12:09 AM
docphi is offline
Find More Posts by docphi
Stupid gravity!
docphi's Avatar
Trinity, FL
Joined Jul 1999
Ok guys, here's what I got:
FW 5.9, Futaba R6008HS FASST Rx, Paparazzi PPM encoder works/DIY drones encoder works - It works! PWM outputs all functional. Nice!
FW 5.9, Futaba R617FS FASST Rx, PPM directly tapped - Works with the caveat that the throttle channel is still being overlaid on the aileron channel. Kind of inconvenient with a powered plane. Haven't tried it with a PPM encoder. Still need to try it with a unity buffer. PWM outputs all functional.
So, all in all, I'm closer to getting this put in an airplane. I think there are issues with the Futaba R617FS that I'm just not smart enough to figure out. Having said that, I'll stick with the R6008HS and the PPM encoder since that is a working solution.
docphi is offline Find More Posts by docphi
Old Apr 14, 2010, 06:01 AM
barok is offline
Find More Posts by barok
barok's Avatar
Joined Apr 2006
thanks..
it shows up in a blink of an eye..
text is overscaled so part of the info is cut off.. i'lltry another lcd..
barok is offline Find More Posts by barok
Old Apr 14, 2010, 07:02 AM
magnetman is offline
Find More Posts by magnetman
Fly the Discombooberator!
magnetman's Avatar
Joined Nov 2003
Whoo hoo... just ordered my IMU can't wait!!!
magnetman is offline Find More Posts by magnetman
Old Apr 14, 2010, 07:10 AM
Dialfonzo is offline
Find More Posts by Dialfonzo
DiaLFonZo - UAV/Drone
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
FPV for Puffer Ghoti
Hi All,
I have the contract of wiring everything for Puffer Ghoti.
So that's my setup so far.
We have a video problem close to that one:
http://www.rcgroups.com/forums/showp...&postcount=310
Look very similar.
I have reprogram the OSD with the latest version... 5.xx (don't remember)
And with a comand line i have set the Futaba radio.
Anyone know how to solve it?
Tanks a lot
Dialfonzo
Dialfonzo is offline Find More Posts by Dialfonzo
Old Apr 14, 2010, 07:17 AM
Virgis21 is offline
Find More Posts by Virgis21
FPV flyer
Virgis21's Avatar
Kaunas, Lithuania
Joined Oct 2007
I did too via EMS, to get it faster! with barometric sensor!
I like this OSD! even it has some surgery operations, but it is so fun to use it!!
Virgis21 is offline Find More Posts by Virgis21
Old Apr 14, 2010, 07:55 AM
Daniel Wee is offline
Find More Posts by Daniel Wee
Joined Aug 2005
Dialfonzo,
Try this:-
http://forum.tsebi.com/download/file.php?id=748
See if it helps.
Daniel
Daniel Wee is offline Find More Posts by Daniel Wee
Old Apr 14, 2010, 09:11 AM
kempo is offline
Find More Posts by kempo
kempo's Avatar
United States, CO, Denver
Joined Nov 2008
FW 5.9, Futaba R6008HS FASST Rx, Paparazzi PPM encoder (DIY Drones encoder does not work) - It works! PWM outputs all functional. Nice!
So, all in all, I'm closer to getting this put in an airplane. I think there are issues with the Futaba R617FS that I'm just not smart enough to figure out. Having said that, I'll stick with the R6008HS and the Paparazzi PPM encoder since that is a working solution.
Sorry if this is OFFTOPIC but I have also a R617FS receiver and I tried to order a ppm encoder from here: http://www.mftech.de/catalog/index.p...2a&language=en (I tried twice and there are problems with payment through paypal) and from here http://jreise.de/PPM/R617FS.html (still no answer). Someone(from Europe) is selling a ppm encoder?
kempo is offline Find More Posts by kempo
Old Apr 14, 2010, 10:23 AM
JMSTECH is offline
Find More Posts by JMSTECH
JMSTECH's Avatar
Canada, BC, Duncan
Joined Dec 2006
barok: did you adjust the text position in the menu? If it's off to the left/right/up or down... you can adjust that in the OSD.... switch off menu mode to see if text is aligned and switch back into menu mode to "save to eprom".
Oh yeah.... your OSD version is 4.3 , best up grade it with a ttl converter.
virgis21: you gotta hook up osd audio to a/v tx then play with some more of those features such as the glide scope... you will appreciate the music.
JMSTECH is offline Find More Posts by JMSTECH
Old Apr 14, 2010, 10:32 AM
Zephyr 66" Blunt
New Zealand
Joined Sep 2009
Originally Posted by barok View Post
thanks..
If you use a terminal program you can see it too with your usb to serial adapter, http://forum.tsebi.com/viewtopic.php...=63&p=699#p699
When you power the dosd it will show firmware version. You might as well download the latest version and upgrade it, follow this http://forum.tsebi.com/viewtopic.php?f=7&t=67&start=0
Mark
Old Apr 14, 2010, 12:23 PM
kempo is offline
kempo's Avatar
Joined Nov 2008
Daniel this could work as PPM encoder?
https://www.mikrocontroller.com/inde...0e04edd6e02427
Old Apr 14, 2010, 03:43 PM
badlands is offline
Find More Posts by badlands
When in doubt, throttle out...
badlands's Avatar
Joined Mar 2010
This is my 1st OSD & it going well.
I have no access to my rx ppm stream yet so can i get to ALL menu items via the serial terminal port just like using the on-screen menu?
badlands is offline Find More Posts by badlands
Old Apr 14, 2010, 04:02 PM
JMSTECH is offline
JMSTECH's Avatar
Canada, BC, Duncan
Joined Dec 2006
pretty well but much easier through the OSD menu. Kind of like DOS and GUI. But in the Tera Term (TTL) screen, you can set some things which can not be done via menu selection such as set CALLSIGN.
John
Old Apr 14, 2010, 04:23 PM
barok is offline
barok's Avatar
Joined Apr 2006
tried that, still same.. on my plasma tv
here's some pics..
will try firmware upgrade.. will that fix it..
Old Apr 14, 2010, 04:37 PM
Joined Aug 2005
barok,
You just need to use the SAFEZONEX and SAFEZONEY feature to move the text inwards and you'll be fine. This doesn't apply to the boot-up screen though. You can either do this via the on-screen menu or via the serial terminal. Just issue the command:-
SET SAFEZONEX 10
SET SAFEZONEY 20
SAVE
You can play around with the values.
Daniel
Discussion Dragon OSD Level Flight FPV Talk 22 Dec 31, 2013 08:08 PM
For Sale New Intelligent Flight Dragon OSD bfischer Aircraft - General - Miscellaneous (FS/W) 7 Jul 19, 2010 11:56 AM
Discussion FS Ready to fly Intelligent Flight Dragon OSD bfischer FPV Talk 0 Mar 03, 2010 05:57 AM
Discussion RV OSD or Dragon OSD djdaveq FPV Talk 1 Feb 06, 2009 12:18 AM
Discussion RV OSD and Dragon OSD - so near to being Really good! magnetman FPV Talk 8 Nov 11, 2008 05:13 AM
