Old Apr 12, 2010, 11:07 AM
Daniel Wee is offline
Find More Posts by Daniel Wee
Joined Aug 2005
docphi,
The PPM stream looks okay. I'm wondering how you tapped the PPM from your receiver? Also trying to think if a buffer could help. Something like the ones used for RSSI. Do you happen to have a spare op-amp lying around?
actually, I must say that the PPM trace looks normal - it didn't look like it was degraded. Something very fishy is going on here.
Can you try this:-
1. Disconnect the PPM line from the OSD
2. Power up the RX and OSD
3. Verify that your throttle is working (also see if the other channels, say a servo on the elevator works)
4. Connect the PPM line
5. See if the throttle still works (and also the servo on the elevator)
You also did not specify if adding the resistor (while disabling the OSD menu) did anything to improve the situation with the throttle control. Can you elaborate on that part?
Daniel
Daniel Wee is offline Find More Posts by Daniel Wee
Old Apr 12, 2010, 12:06 PM
docphi is offline
Find More Posts by docphi
Stupid gravity!
docphi's Avatar
Trinity, FL
Joined Jul 1999
Originally Posted by Daniel Wee View Post
docphi,
Can you try this:-
Daniel
Daniel,
Throttle (and elevator servo) works without PPM line plugged into OSD. As soon as the PPM line is plugged in, the throttle overlays to the aileron channel (elevator servo still works on the receiver end). Adding a resistor did not help the throttle situation.
I do have opamps lying around if needed.
PPM stream was tapped as described here:
http://paparazzi.enac.fr/wiki/Image:FAST7ch.jpg
docphi is offline Find More Posts by docphi
Old Apr 12, 2010, 12:16 PM
Joined Aug 2005
docphi,
What exactly do you mean when you say "overlays"?
Take a look at this for a unity-gain buffer:-
http://www.fpv-community.com/forum/s...d=3298#pid3298
I find the receiver situation truly baffling but this buffer should do the trick.
Daniel
Old Apr 12, 2010, 12:20 PM
docphi is offline
Stupid gravity!
docphi's Avatar
Trinity, FL
Joined Jul 1999
docphi,
Daniel
I mean it moves from throttle stick to aileron stick with the aileron servo still working as connected to receiver (so both throttle and aileron servo is being controlled by the same stick).
Old Apr 12, 2010, 02:04 PM
Virgis21 is offline
Find More Posts by Virgis21
FPV flyer
Virgis21's Avatar
Kaunas, Lithuania
Joined Oct 2007
Has any one configured OSD+ setings for AttoPilot Voltage and Current Sense Breakout?
Maby someone wants to share?
i tried 220, but not enough, i will try recalculate after batteries fully charged.
here is another video. I tried to fly as video will be still good enough. and some low pass, sharp turns and etc, but signal quality was always the best
http://www.vimeo.com/10874877
After this low pass flight, i realized how seriously need barometric sensor. So just came back home, made order ArduIMU and pressure sensors
Virgis21 is offline Find More Posts by Virgis21
Old Apr 12, 2010, 04:57 PM
Joined Aug 2005
Virgis21,
Can you clarify what you mean by "I tried 220, but not enough ..."?
docphi,
That sounds pretty bizarre. Might be interesting to watch the trace on the scope when that happens. Could tell you something about what might be going on there.
Daniel
Old Apr 12, 2010, 05:03 PM
JMSTECH is offline
Find More Posts by JMSTECH
JMSTECH's Avatar
Canada, BC, Duncan
Joined Dec 2006
Hey Virgis21,
You are having too much fun now! What is your meaning of the 220? Is it the mAH calibration section in the menu? It should not be that high if so. BTW upgrade the firmware to 5.2 Daniel reuploaded yesterday under same file name.... made the IMU respond pretty well in real time... so fast! I've not had the chance to test this in the air but on the bench... it's awesome!
John
BTW folks.... just a reminder.... 2 more days until I remove the special deal of $99 for Dragon OSD+
JMSTECH is offline Find More Posts by JMSTECH
Old Apr 12, 2010, 06:44 PM
jimbob00 is offline
Find More Posts by jimbob00
Joined Aug 2009
quick quick air test
jimbob00 is offline Find More Posts by jimbob00
Old Apr 12, 2010, 07:32 PM
mark hitchman is offline
Find More Posts by mark hitchman
Zephyr 66" Blunt
mark hitchman's Avatar
New Zealand
Joined Sep 2009
Do you have to have a gps connected to access the autopilot menu and get the artificial horizon indicator on screen? What is the nv connector for on the gps input connector?
Mark
mark hitchman is offline Find More Posts by mark hitchman
Old Apr 13, 2010, 12:02 AM
Joined Aug 2005
mark,
The autopilot menu can be accessed at any time but the autopilot function will not kick in unless a GPS module is attached and a home position has been fixed.
As for the artificial horizon, that is a function of the IMU (or magnetic compass) rather than the autopilot or GPS.
The NV on the GPS header stands for "Non-Volatile", referring to the backup battery in some GPS modules. This provides a charging voltage for it. In some GPS modules, this needs to be connected for the GPS to operate (eg. LS20033.)
Daniel
Old Apr 13, 2010, 12:19 AM
David22 is offline
Find More Posts by David22
North vancouver, B.C. Canada
Joined Apr 2008
It really would be nice to buy an osd that is plug and play
all the experimenting and testing is just
no soldering, just plug and play
One day that should be possable
i thought that this one was a plug and play
one day hopefully
David22 is offline Find More Posts by David22
Reply With Quote  (Disabled)
Old Apr 13, 2010, 12:24 AM
Zephyr 66" Blunt
New Zealand
Joined Sep 2009
Thanks Daniel, that will be why gps is not working. I have the ArduIMU+ V2 and the AHI is not on screen when I power up, I have installed the firmware you modified and it looks like it is working when it boots the lights flash and then it settles down with a green and an orange light on.
The other issue I am having is not being able to control any channel apart from throttle from pwm out 1 or 2. I have tried assigning all normal channels in the menu but only throttle will work and it will work on 1 or 2. i am using the 8 Channel PPM Encoder Version 2 from diy drones.
Old Apr 13, 2010, 12:33 AM
Joined Aug 2005
mark,
A couple of things to note:-
1. update OSD firmware to the latest - 5.3
2. the horizon needs to be turned on - set HORIZONSTYLE to 1 in the menu
3. In some cases, the IMU needs to be powered up a bit earlier than the OSD to be detected
As for assigning channels - can you go into the serial terminal and issue a STATUS command and let me know the results.
Daniel
Old Apr 13, 2010, 12:42 AM
Zephyr 66" Blunt
New Zealand
Joined Sep 2009
>status
Radio settings
Radio mode is JR
AILCHAN: 2
ELECHAN: 3
RUDDCHAN: 4
THROTTLECHAN: 1
AIL2CHAN: 6
CTRLCHAN: 5
RUDDIR: NOR
ELEDIR: REV
GPS settings
VALIDHDOP: 1.500
MINVALID: 15
ADC settings
VMULT1: 11.170
VMULT2: 11.170
VMULT2: 11.170
IMULT: 32.500
MAHMULT: 1.354
CURROFFSET: 0.000
Old Apr 13, 2010, 12:45 AM
Joined Aug 2005
mark,
So you're saying that when you set Output 1 to "THRO" it works but not when it is set to "AIL1" for example? And you tried this when not in the menu mode right?
What are Output 1 and 2 assigned to currently?
Daniel
Discussion Dragon OSD Level Flight FPV Talk 22 Dec 31, 2013 08:08 PM
For Sale New Intelligent Flight Dragon OSD bfischer Aircraft - General - Miscellaneous (FS/W) 7 Jul 19, 2010 11:56 AM
Discussion FS Ready to fly Intelligent Flight Dragon OSD bfischer FPV Talk 0 Mar 03, 2010 05:57 AM
Discussion RV OSD or Dragon OSD djdaveq FPV Talk 1 Feb 06, 2009 12:18 AM
Discussion RV OSD and Dragon OSD - so near to being Really good! magnetman FPV Talk 8 Nov 11, 2008 05:13 AM
