Old Nov 13, 2010, 07:33 PM
Southampton, Ontario CA
Joined Feb 2005
Originally Posted by Daniel Wee View Post
BuffytheSaint,
Can you try putting a 100ohm resistor across the video input to the DOSD+ and let me know what happens? Thanks.
Daniel
I'll look for some resistors. That's video in, across to ground, right?
Buffythesaint is offline Find More Posts by Buffythesaint
Old Nov 13, 2010, 08:13 PM
Plane Insane RC.com
chicken hawk's Avatar
Spanish Fork Utah
Joined Mar 2005
I don't know what I did but I'm not getting the normal flashing lights. I get the green light but thats it. Anyone what to buy a lightly used arduIMU?
chicken hawk is offline Find More Posts by chicken hawk
Old Nov 13, 2010, 08:43 PM
Fus ro dah!
Bigster's Avatar
Grafton, Massachusetts, United States
Joined Sep 2004
Heh. I'll give it a go, chicken hawk. You sure you're willing to give up on it?
Bigster is online now Find More Posts by Bigster
Old Nov 13, 2010, 08:50 PM
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
I added the 100ohm resistor across Vout and GND. That was to help the test 'smearing' issue. Mine wasn't that bad to begin with, but did have some smearing.
Vantasstic is offline Find More Posts by Vantasstic
Old Nov 13, 2010, 08:52 PM
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Where is your green light? On the ArduIMU or on the TTL? If you're not getting 5v to your IMU using the serial pins then you won't get LEDs on the IMU board.
I can't tell by your original picture, but it looks like the CTS pin on the TTL is connected to the 5V pin on the IMU? Make sure that you're getting 5V at the IMU 5V pin. You can also leave the 5v on the serial line off altogether and use the >6v connector on the corner of the board. This is how I did mine. Connect a 2S LiPo at the >6v and GND pins...OBSERVER POLARITY to see if that helps. DON'T have the 5v line AND the >6v line connected at the same time.
Old Nov 13, 2010, 09:16 PM
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Originally Posted by yvesOttawa View Post
1 out of 4 OSD power on's lands an "unable to identify GPS Type - using MTK". Is this something I should be worried about?
also, why do we specify pan and tilt channels? I didn't see anything in documentation on what it does.
one more for you, no mention on what the safezoneX and Y do?
thx
If you specify Pan and Tilt channels the OSD will display (I believe) a little scale or such to show how much pan and/or tilt your using. That should help you figure if your camera is straight ahead, a little down and to the right, etc...
The Safe Zone X & Y are in the manual. One moves the left and right text closer/further from the edges, the other moves text closer/further to the top and bottom of the screens. You use this to adjust your left/right/top/bottom text borders so you can see all the text and not having some of the text dropping out of view.
Old Nov 13, 2010, 11:16 PM
IamLegend's Avatar
Valencia, CA
Joined Aug 2005
Is there a way to calibrate the video on the video monitor? My screen has the voltage and timer cut off on the left and the display is too high/cut off on the top.
IamLegend is offline Find More Posts by IamLegend
Old Nov 13, 2010, 11:30 PM
Tankogen's Avatar
USA, AZ
Joined Jun 2010
what does arduIMU do?
For the Smear, or Resistance Mod I had to play with resistor values with camera in hand then point it at light- cover lens, go from dark to light and keep good eye on display, within a range of resistance and tuning a knob inside my video tx i got mine fixed. I am using a Bev800mw Tx for this setup. The lawmate tx's have a small knob on them that adjusted this also for me. Mark original location before changing though.
Mess with dark and light with camera, make sure it stays what looks best throughout changes. I didn't solder them on, I shoved them into the plugs, one camera was tricky enough that I ran a cable soldered on separately for resistor plug-ins.
Tankogen is offline Find More Posts by Tankogen
Old Nov 13, 2010, 11:38 PM
FPV flyer
Virgis21's Avatar
Kaunas, Lithuania
Joined Oct 2007
spicoli82,
Vantasstic has wrote this before yours post
Tankogen,
Do you have a picture of that knob in Lawmate video tx? Thanks
Virgis
Virgis21 is offline Find More Posts by Virgis21
Old Nov 14, 2010, 12:01 AM
IamLegend's Avatar
Valencia, CA
Joined Aug 2005
Originally Posted by Virgis21 View Post
spicoli82,
Virgis
LOL! He must be looking over my shoulder!
I do have one last issue (so it seems)... Everything works as far as being able to turn on the OSD menu via transmitter, navigate the menu via transmitter, change menu settings via transmitter... But for some reason, my servos aren't moving anymore on the DOSD+V2 board. Any suggestions?
Old Nov 14, 2010, 12:06 AM
FPV flyer
Virgis21's Avatar
Kaunas, Lithuania
Joined Oct 2007
spicoli82,
Check if servos channels are assigned properly(in DOSD+ menu) to the channels on yours radio.
Virgis
Old Nov 14, 2010, 12:09 AM
Tankogen's Avatar
USA, AZ
Joined Jun 2010
Adjustment knobs on 1.2ghz lawmates.
I have not worked with 1watt one, but I am very confident this is it. A data sheet maaaybe might confirm.not sure.But on the 500mw one I am more sure.It was a while back I was testing. Just be sensitive, slightest move and mark of turn. Glad I can help. Thanks
Old Nov 14, 2010, 12:16 AM
Joined Aug 2010
thanks Van for your help.
yvesOttawa is offline Find More Posts by yvesOttawa
Old Nov 14, 2010, 01:04 AM
IamLegend's Avatar
Valencia, CA
Joined Aug 2005
I'm still not getting any movement on my rudder or elevator servos. I'm not sure what's going on. Everything is connected correctly as far as rx to ppm encoder to DOSD to servos. Do I have to have GPS home set to move the servos? I don't think so. Is there something wrong with the DOSD board? I'm able to navigate the OSD menu with the AILERON channel and the ELEVATOR channel... That sounds like the way I'm supposed to be able to navigate, right?
Old Nov 14, 2010, 02:57 AM
Joined Aug 2005
spicoli82,
In menu mode - aileron and elevator are not passed through. In normal mode you should be able to move stuff.
Daniel
Daniel Wee is offline Find More Posts by Daniel Wee
Discussion Dragon OSD Level Flight Video Piloting (FPV/RPV) 20 Apr 17, 2011 12:12 PM
For Sale New Intelligent Flight Dragon OSD bfischer Aircraft - Electric - Miscellaneous (FS/W) 7 Jul 19, 2010 11:56 AM
Discussion FS Ready to fly Intelligent Flight Dragon OSD bfischer Video Piloting (FPV/RPV) 0 Mar 03, 2010 05:57 AM
Discussion RV OSD or Dragon OSD djdaveq Video Piloting (FPV/RPV) 1 Feb 06, 2009 12:18 AM
Discussion RV OSD and Dragon OSD - so near to being Really good! magnetman Video Piloting (FPV/RPV) 8 Nov 11, 2008 05:13 AM
