Me to. I got on ebay, search Hobbywing 5A, picked the least expensive with shipping, and ordered. Here's the one I got: http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWNX:IT . Shipping is almost as much as the BEC itself, but it came much quicker than I had thought it would.
Latest blog entry: Transplanting a Spektrum Dx4E Rf Deck...
Joined Aug 2005
On the GPS 0-degree issue, I have just confirmed that it is not a firmware issue. I tried with three different GPS module, put them on the roof of my car and drove 6 circles (3 in each direction) with each. In all of them, there is no choking/stalling of the heading update when passing through 0-degrees from either directions. Based on this, I can say that the firmware is working correctly. This leaves some GPS modules as being the problem.
The modules I tested were a Venus 10Hz module, LS20033 5Hz, and LS20031 5Hz. You can repeat the test in the same way I did - using OSD mode 3 (diagnostic screen) and the latest firmware, and giving it a shot. Daniel |
It would be cool if you could zero the IMU's pitch and roll with DOSD+ then I could put it anywhere, but I'm going to struggle to find somewhere flat for it in my funjet! |
Hi Daniel, Yeah I tried getting the two port version but they are only made to order and thus very expensive. The part number for that one is HSCMRRN001PD2A3 if anyone else wants to try..Hence my reason for putting this one in a box. If you ordered 30 of them it may be worthwhile... even then the price for a single unit is the same as the single port version from Mouser (where I got mine). The case will be padded with cotton wool to damp out excessive fluctuations
I am going to be fairly upset if it does, especially because my wife would have purchased it for me for Christmas!!! I asked Daniel at least 3 times to just give me a a general idea if it was this quarter, next quarter, etc. but he never responded. I just purchased cercomtechnologies GS diversity controller earlier this week for my GS. I would still use a diversity controller behind a tracker with omni for close in and backup, so I am sure I will still pick up the DGS eventually after it is available. You got to love the way Daniel is fully testing everything out and fixing most of the bugs before release!!!
Was it this Venus module??? http://www.mr-lee-catcam.de/pe_cc_i6.htm |
Joined Aug 2005
magnetman,
Unfortunately that particular one, the SUP500F is exceptionally bad for me. I am using a different one with an active antenna. That combination works exceptionally well - giving me 9 satellites within seconds usually. I added my own supercap to keep the memory intact between power cycles. The board I use:- http://www.sparkfun.com/commerce/pro...oducts_id=9133 Needs an active antenna, something like this:- http://www.sparkfun.com/commerce/pro...roducts_id=464 The one you linked (not really recommended):- http://www.sparkfun.com/commerce/pro...oducts_id=9758 Daniel |
| Thread Tools | |
| Discussion Dragon OSD | Level Flight | Video Piloting (FPV/RPV) | 20 | Apr 17, 2011 12:12 PM |
| For Sale New Intelligent Flight Dragon OSD | bfischer | Aircraft - Electric - Miscellaneous (FS/W) | 7 | Jul 19, 2010 11:56 AM |
| Discussion FS Ready to fly Intelligent Flight Dragon OSD | bfischer | Video Piloting (FPV/RPV) | 0 | Mar 03, 2010 05:57 AM |
| Discussion RV OSD or Dragon OSD | djdaveq | Video Piloting (FPV/RPV) | 1 | Feb 06, 2009 12:18 AM |
| Discussion RV OSD and Dragon OSD - so near to being Really good! | magnetman | Video Piloting (FPV/RPV) | 8 | Nov 11, 2008 05:13 AM |
