Old Nov 08, 2010, 09:14 PM
scrtsqrl is offline
Find More Posts by scrtsqrl
Just trying to get a nut.
scrtsqrl's Avatar
United States, VA, McLean
Joined Oct 2006
Originally Posted by MikeTheCrash View Post
yup!
Done.
It WORKS!
THANKS!
scrtsqrl is offline Find More Posts by scrtsqrl
Old Nov 08, 2010, 10:04 PM
Daniel Wee is offline
Find More Posts by Daniel Wee
Joined Aug 2005
Mr westie,
Do let me know if the calibration adjustment for the airspeed sensor works.
Daniel
Daniel Wee is offline Find More Posts by Daniel Wee
Old Nov 09, 2010, 11:54 AM
thekubiaks is online now
Find More Posts by thekubiaks
Joined Aug 2010
I need a little help please
I am so close to being operational I can't stand it. I have a Twinstar2 with DOSD+ V2 (firmware 15.0) and everything working great, video is strong and looks good, DL link is strong, and I went to great lengths to prevent noise by using torroids and twisted cables.
The problem is, my HiTec HS-82 servos are all chattering. I originally thought that since my Futaba 9CAP and DragonLink had the dummy antenna on it, that the signal to the receiver was weak and noise was overpowering the receiver. I put on the DL transmitter antenna, got a 100% RSSI and am still getting moderate, continuous chatter on all servos. I don't even know how to troubleshoot this. I have an oscilloscope but the pulses look clean and square. One other minor issue is my audio that piggybacks with the video is full of static. (I have the DPCAV mic).
Any help would be appreciated.
thekubiaks is online now Find More Posts by thekubiaks
Old Nov 09, 2010, 12:06 PM
trappy is offline
Find More Posts by trappy
trappy's Avatar
Austria
Joined Feb 2007
thekubiaks: try turning off the UHF transmitter to see if the chatter stops. Some servos are known to chatter in close proximity to UHF transmitters. if that's not the case, then it's probably your video transmitter.
trappy is offline Find More Posts by trappy
Old Nov 09, 2010, 12:16 PM
mark hitchman is offline
Find More Posts by mark hitchman
Zephyr 66" Blunt
mark hitchman's Avatar
New Zealand
Joined Sep 2009
I had a fly last night and was not happy with how smooth the plane flew, 3km and back it was twitching a lot, thought it could be wind up higher. I flew around home testing autopilot and still had twitching even though it was dead calm, after 30 minutes flying I landed and picked up the plane to carry it back to the shed and noticed the control surfaces twitching. This is only my third flight with this setup so I thought it must be the vtx, unplugged it and still twitching, unplugged camera, still twitching. I thought maybe it is gps stabilization but that should have no effect without +2km/hr ground speed. I will continue testing, let me know if you find anything.
Mark
mark hitchman is offline Find More Posts by mark hitchman
Old Nov 09, 2010, 12:33 PM
badlands is offline
Find More Posts by badlands
When in doubt, throttle out...
badlands's Avatar
Joined Mar 2010
Mark - does your twitching stop when u go into the OSD menu?
Ive had twitching from day one - its very minor & not related to vtx etc.
To me it looks like minor AP corrections but i get it with stabilization & AP off.
It stops if i go into the OSD menu proving it isnt a vtx problem.
Might be the same issue?
I kinda live with it.
badlands is offline Find More Posts by badlands
Old Nov 09, 2010, 12:56 PM
kempo is offline
Find More Posts by kempo
kempo's Avatar
Romania, IS, Iasi
Joined Nov 2008
Mark
Mark the twitching is like here:
http://www.rcgroups.com/forums/showp...postcount=4357 ?
kempo is offline Find More Posts by kempo
Old Nov 09, 2010, 01:37 PM
Zephyr 66" Blunt
New Zealand
Joined Sep 2009
Originally Posted by kempo View Post
It does it all the time, even in the menu, I will try it with gps stabilization off next time I set up. I observed the plane while I was flying overhead and I was in the menu, it twitched a few times and then I knew it was not the wind.
Mark
Old Nov 09, 2010, 01:38 PM
magnetman is offline
Find More Posts by magnetman
Fly the Discombooberator!
magnetman's Avatar
Joined Nov 2003
Originally Posted by Daniel Wee View Post
Mr westie,
Daniel
Daniel,
if the airspeed sensor is fitted, does the DOSD default to that rather than GPS speed to control the throttle in AP mode??
Richard
magnetman is offline Find More Posts by magnetman
Old Nov 09, 2010, 01:44 PM
Joined Aug 2005
magnetman,
I think so - I'll have to check. If it doesn't it's quite simple to make it use the airspeed..
Daniel
Old Nov 09, 2010, 02:11 PM
magnetman's Avatar
Joined Nov 2003
magnetman,
Daniel
Great thanks!
Old Nov 09, 2010, 03:01 PM
Cralis is offline
Find More Posts by Cralis
I love FPV!
Cralis's Avatar
Eastern side of Australia
Joined Jan 2007
Mark
I have always had servo chatter. I notice that when I do a firmware update, the servos go silent during the update. As soon as the update completes, they start chattering again.
Cralis is offline Find More Posts by Cralis
Old Nov 09, 2010, 03:06 PM
magnetman's Avatar
Joined Nov 2003
I have never seen that on my setup, the only time I have seen it is when doing the servo direction test. I'm on 35MHz JR radio, but my 2.4 VTX is right on the tail end if that helps??
Are you using an unfiltered switching BEC?? could be that
Old Nov 09, 2010, 03:18 PM
vertcnc is offline
Find More Posts by vertcnc
Illinois, USA
Joined Aug 2009
On my DOSD v1 plane I have not noticed chattering, But on the plane with DOSD v2, during the direction test I get severe chattering where you can't really tell which way they are moving during the test.
I haven't noticed otherwise but will do some further testing.
DL both planes if it matters.
vertcnc is offline Find More Posts by vertcnc
Old Nov 09, 2010, 03:25 PM
Joined Aug 2010
Trappy, I tried turning off the UHF transmitter as well as the Video transmitter and disconnecting the GPS module, still getting chatter. About the only thing left is the BEC that I got from HobbyKing. It is supposedly an RFI shielded BEC with 10 - 15A capability. On the oscilloscope, the BEC had a pronounced sawtooth pattern but looked clean of extraneous RFI. I think I'll try a 5V battery pack in place of the BEC to see if that eliminates the chatter.
Who makes the cleanest BEC?? Thanks for the replies.
Discussion Dragon OSD Level Flight FPV Talk 22 Dec 31, 2013 08:08 PM
For Sale New Intelligent Flight Dragon OSD bfischer Aircraft - General - Miscellaneous (FS/W) 7 Jul 19, 2010 11:56 AM
Discussion FS Ready to fly Intelligent Flight Dragon OSD bfischer FPV Talk 0 Mar 03, 2010 05:57 AM
Discussion RV OSD or Dragon OSD djdaveq FPV Talk 1 Feb 06, 2009 12:18 AM
Discussion RV OSD and Dragon OSD - so near to being Really good! magnetman FPV Talk 8 Nov 11, 2008 05:13 AM
