Old Apr 01, 2010, 01:08 AM
barok is offline
Find More Posts by barok
barok's Avatar
Joined Apr 2006
Originally Posted by Daniel Wee View Post
barok,
Can you describe your connects, preferably with a clear photograph. In particular, how is the DOSD+ powered. Be sure that the camera ground is connected to the DOSD+ ground and is also connected to the video transmitter ground (or the RCA ground if you are using it). All the grounds of all the devices needs to be connected.
Daniel
it is power by a 2s lipo, pin ground and pin 4-16v yes i understand the video wire cam in and video out..basically one wire that passes through the DOSD+ and yes it is grounded in the cam. and vtx connection.
took a pic..
barok is offline Find More Posts by barok
Old Apr 01, 2010, 01:16 AM
Daniel Wee is offline
Find More Posts by Daniel Wee
Joined Aug 2005
Can you try it without the PPM cable connected and see if the problem persists? I'm just wondering if something might be affecting the video sync detection.
Daniel
Daniel Wee is offline Find More Posts by Daniel Wee
Old Apr 01, 2010, 01:28 AM
barok is offline
barok's Avatar
Joined Apr 2006
with PPM wire remove, no nothing shows at all.. even the battery info at the corner..
going to bed.. its 3am here..
i'll check 3morrow for your suggestion..
thanks daniel, john..
Old Apr 01, 2010, 01:35 AM
David22 is offline
Find More Posts by David22
North vancouver, B.C. Canada
Joined Apr 2008
this is NOT EZ or simple
like it should be
man I hate when things like this are NOT plug and play
problems problems problems?
David22 is offline Find More Posts by David22
Reply With Quote  (Disabled)
Old Apr 01, 2010, 02:09 AM
JMSTECH is offline
Find More Posts by JMSTECH
JMSTECH's Avatar
Canada, BC, Duncan
Joined Dec 2006
No problem Barok, we'll work with you until you get it working! It's not 3 a.m. here yet so best get busy working on other stuff.
JMSTECH is offline Find More Posts by JMSTECH
Old Apr 01, 2010, 02:48 AM
renatoa is online now
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
Just got mine from the customs ! Whohooo... can't wait weekend to test !
renatoa is online now Find More Posts by renatoa
Old Apr 01, 2010, 03:23 AM
CrashingDutchman is offline
Find More Posts by CrashingDutchman
CrashingDutchman's Avatar
The Netherlands, Utrecht, Amersfoort
like it should be
This is a thread for intelligent people and people that are not afraid to learn something. Please find a thread that suits you better.
CrashingDutchman is offline Find More Posts by CrashingDutchman
Old Apr 01, 2010, 06:11 AM
Joined Aug 2005
barok,
You need to take out the power and put it back after your remove the PPM line. Could you try that - start the OSD without the PPM line connected and see if the problem persists.
Daniel
Old Apr 01, 2010, 07:41 AM
RolandS888 is offline
Find More Posts by RolandS888
Outta Sight
Australia, WA, Joondalup
Joined Jul 2008
Hi Daniel & John, great little piece of technology, well done to the both of you.
I powered it all up tonight, and everything is working fine I am happy to say.
One question, OSD mode 3 diagnostics is slightly off screen even though safe-zone X and Y are moved across. You have probably already fixed this in a firmware update.
Also, just a suggestion, what are the chances of getting the GPS co-ordinates to display in different selectable ways, eg DMS or DMS.s rather than just decimal degrees.
Another firmware update in the future perhaps.
It might be a strange request, but we have reasons for wanting DMS.s and have to convert D.d to DMS.s before we can use the numbers.
What do you think.
Thanks again, she's a beauty.
RolandS888 is offline Find More Posts by RolandS888
Old Apr 01, 2010, 07:48 AM
Joined Aug 2005
RolandS888,
That's a good suggestion - let me see about adding that it into the next firmware revision. As for the diagnostic screen, I didn't really put in the safezone management because it was something I didn't think people would use much. Let me take a look at that. Glad that you're liking the thing. Can't wait to see more pictures posted.
Regards,
Daniel Wee
Old Apr 01, 2010, 07:59 AM
David22 is offline
Joined Apr 2008
Sorry even though it is a great osd maybe the best for its size it however does not seem to fit the pnp requirement
Old Apr 01, 2010, 08:00 AM
Outta Sight
Joined Jul 2008
I dont mean to push you Daniel, but I (like everyone else probably) would love to see some accessory modules for the DOSD+.
Whats the first on the list, and whats the time line?
Sorry if this has already been asked previously.
Keep up the great work
Cheers,
Roland
Old Apr 01, 2010, 09:13 AM
Joined Aug 2005
Roland,
Actually you can already buy the accessories from Sparkfun (some of them at least). Not sure which ones you are thinking about but if you look at the following link, you will find that I have included links to where you can buy various accessories. The only two you cannot buy (yet) are the air speed and one of the two supported barometric sensor modules. They are awfully easy to make though (only about 3 or 4 components each module.) There is another barometric module you can buy from DIYDRONES which I have included support for but have not been able to test being that they were out of stock when I was ordering stuff.
Currently available modules:-
1. GPS - (various) MTK, U-blox, Venus, SiRF
2. SFE magnetic compass (tilt-compensated) - includes accelerometers
3. DIYDRONES ArduIMU+ V2 (needs custom firmware from me)
4. IF temperature sensors
5. SFE current sensor (needs a small modification)
6. Flytron current sensor (recommending the new design to be released soon over older Allegro sensor)
7. DIYDRONES barometric sensor (for altitude) - includes temperature sensor
DIY sensors
1. Airspeed sensor
2. Barometric sensor (much cheaper than DIYDRONES) - includes temperature sensor
http://forum.tsebi.com/viewtopic.php?f=7&t=63
In the meantime, I have added your suggestion for the DMS displays. The latest firmware, which you can download from the support site, supports the older decimal display, as well as DMS.s and DM.mmm which you can select from the menu.
Daniel
Old Apr 01, 2010, 09:26 AM
JMSTECH is offline
JMSTECH's Avatar
Canada, BC, Duncan
Joined Dec 2006
Renato.... WHOO HOO! Man... I was eager for you to get that soon!
For those who downlaoded the 4.7 firmware (to which ttl044 worked with Daniel to further improve the firmware).. another one has been added later on that day ... 4.8. The firmware keeps getting new stuff added on to do more and accepts more. Keep the positive input flowing guys so everyone can enjoy this even more!!! Thanks!
John
Old Apr 01, 2010, 09:28 AM
galaxiex is offline
Find More Posts by galaxiex
my karma ranover my dogma
galaxiex's Avatar
Edmonton,Canada Eh
Joined Jun 2007
Excellent stuff going on here! I'm keeping an eye on all this.
galaxiex is offline Find More Posts by galaxiex
Discussion Dragon OSD Level Flight FPV Talk 22 Dec 31, 2013 08:08 PM
For Sale New Intelligent Flight Dragon OSD bfischer Aircraft - General - Miscellaneous (FS/W) 7 Jul 19, 2010 11:56 AM
Discussion FS Ready to fly Intelligent Flight Dragon OSD bfischer FPV Talk 0 Mar 03, 2010 05:57 AM
Discussion RV OSD or Dragon OSD djdaveq FPV Talk 1 Feb 06, 2009 12:18 AM
Discussion RV OSD and Dragon OSD - so near to being Really good! magnetman FPV Talk 8 Nov 11, 2008 05:13 AM
