Old Mar 31, 2010, 07:22 AM
Daniel Wee is offline
Find More Posts by Daniel Wee
Joined Aug 2005
bracky72,
For the moment, ArduIMU seems like a good candidate. My only concerns lie with the vibration sensitivity of the gyros and how the DCM works as compared to a Kalman filter. Of course, being that this is thus far untested in flight, I hesitate to recommend it yet unless you are keen on experimenting. The price of the IMU seems reasonable. A better IMU is likely to cost considerably more. The one I was working on used the ADXRS610 gyros, which are over USD60 each (and you need two of those) so that will certainly cost more than the ArduIMU.
Mind you, you will need to do a bit of work to get the ArduIMU working with the DragonOSD+. I have modified the code a bit for this to work so you will need to flash the IMU with the said modified firmware. This is done using the same serial-TTL converter that you use to update the firmware of the DragonOSD+, although the pinouts aren't quite the same. Nevertheless, it should be relatively easy to do.
I am now arranging to have the IMU tested in flight to see how well it handles coordinated turns and such. I am also looking to see how else to optimize the IMU performance for our application.
Daniel
Daniel Wee is offline Find More Posts by Daniel Wee
Old Mar 31, 2010, 07:34 AM
jimbob00 is offline
Find More Posts by jimbob00
Joined Aug 2009
excellent news to hear progress on the imu
unfortunately, don't have an arduimu either atm
(yeah my post isnt all that helpful i know, just sharing the joy!)
jimbob00 is offline Find More Posts by jimbob00
Old Mar 31, 2010, 07:44 AM
Joined Aug 2005
Well, the ArduIMU is actually the cheapest IMU with attitude output on the market right now so it's hard to do much better than that price-wise. I know it has been used with some success but once you have an AHRS system, you will see things that some stabilization systems don't see. In any case, as long as it works, I think I'm going to be happy.
Daniel
Old Mar 31, 2010, 11:18 AM
Joined Aug 2005
tty044,
I think I might have found the reason for the GPS issues you're facing. As it turns out, the MTK firmware seems to have been upgraded a bit over time and there exists several different command specifications. I am in the process of trying to sort this out and will have a firmware to fix it shortly.
If you happen to read this - please try to contact me either via PM or e-mail so that we can set up a Skype call and I can let you try out the purported solution to the problem.
Daniel
Old Mar 31, 2010, 12:11 PM
tty044 is offline
Find More Posts by tty044
tty044's Avatar
Joined Aug 2008
Originally Posted by Daniel Wee begin_of_the_skype_highlighting     end_of_the_sky pe_highlighting View Post
Do you have any other GPS to try? I will try to see why it is acting up.
Can you post a photo of your setup. You mentioned that you were using the GlobalTop GPS module - is this the pre-assembled board or are you using the module directly. If so, have you connected anything to the "enable" line of the module?
Daniel
Originally Posted by Daniel Wee View Post
tty044,
Daniel
Daniel,
Thank you for your excellent support.
It is good to hear that there would be something that could be improved by firmware. I have MTK that was added to Remzibi's OSD. It is module only and I didnt attach anything to "enable" line in module.
Regards
Michal
tty044 is offline Find More Posts by tty044
Old Mar 31, 2010, 12:13 PM
Joined Aug 2005
tty044,
I PM'ed you with my Skype address. Are you able to test the firmware now? I will try to upload it to the support site - if you can, please try it out (4.7) and let me know if it solves your problem with the module. Thanks.
Daniel
Old Mar 31, 2010, 01:21 PM
JettPilot is online now
Find More Posts by JettPilot
JettPilot's Avatar
Miami
Joined Apr 2005
Here is a video of the flight testing of the new Dragon OSD !!! This shows the new altitude ladder, although classic Dragon mode is available for those that like less clutter. Also shown is the Autopilot / RTH Return to home function, which worked incredibly well even in 50 KPH winds. The plane was getting thrown all over the place, you can hear the wind gusts hit the plane, but the Dragon OSD and its autopilot worked flawlessly. The GPS used is a LocoSys 20031.
Dont even bother to click on this video here, the quality will be HORRIBLE and you wont be able to read the OSD Click on the title at the top of the video which takes you to YouTube and you can watch it in HD
FPV Plane FPV (9 min 21 sec)
JettPilot is online now Find More Posts by JettPilot
Site Sponsor
Old Mar 31, 2010, 01:48 PM
tty044 is offline
tty044's Avatar
Joined Aug 2008
For the users of MTK from Remzibi OSD - it would be necessary to download firmware 4.7 or newer to use this GPS. Now with new firmware it is working great!
Thank you Daniel for immediate response!
Michal
Old Mar 31, 2010, 02:23 PM
Funjet2008 is offline
Find More Posts by Funjet2008
plus vite plus loins
Funjet2008's Avatar
Canada, QC, Trois-Rivières
Joined Jun 2008
deleted
Funjet2008 is offline Find More Posts by Funjet2008
Old Mar 31, 2010, 02:30 PM
renatoa is online now
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
Michal
Seems to feel like the early development on remzibi thread atmoshere
renatoa is online now Find More Posts by renatoa
Old Mar 31, 2010, 03:07 PM
Martin Y is offline
Find More Posts by Martin Y
400' ..... NOT
Martin Y's Avatar
Canada
Joined Jan 2009
http://www.youtube.com/watch?v=ayNNzvphOic
Sorry but the intro's a bit much.
Martin Y is offline Find More Posts by Martin Y
Old Mar 31, 2010, 03:47 PM
Funjet2008's Avatar
Joined Jun 2008
i will make a full test (video) of DOSD+ next week
Daniel, with Compass Module with Tilt Compensation - HMC6343, do I need reflash DOSD+?
Old Mar 31, 2010, 05:02 PM
Joined Aug 2005
No Funjet. That should work without issues as all the firmware versions support it. Your module looks a little different from mine though. I hope it works the same. However, it's probably a good idea to update to the latest version (4.7) for other improvements.
Daniel
Old Mar 31, 2010, 06:02 PM
gobigkahuna is offline
Find More Posts by gobigkahuna
United States, CA, San Diego
Joined Nov 2008
Daniel - The docs for the HMC6343 are a bit sparse so I'm trying to figure out how it should be wired to the DOSD+. Could you look at the schematic and tell me what I'm missing? Thanks!
Edit - I just need to confirm that if I connect the "3V3" pin to the compass's "VCC" pin I won't burn anything up and it'll work.
gobigkahuna is offline Find More Posts by gobigkahuna
Old Mar 31, 2010, 06:09 PM
JettPilot's Avatar
Miami
Joined Apr 2005
I thought the intro was the best part of the video. With marketing like that, John will probably be selling OSD's to people that dont even fly FPV
The only problem is that after I watch the intro, its hard to do anything in the rest of the video that lives up to the funjets intro
Site Sponsor
Discussion Dragon OSD Level Flight FPV Talk 22 Dec 31, 2013 08:08 PM
For Sale New Intelligent Flight Dragon OSD bfischer Aircraft - General - Miscellaneous (FS/W) 7 Jul 19, 2010 11:56 AM
Discussion FS Ready to fly Intelligent Flight Dragon OSD bfischer FPV Talk 0 Mar 03, 2010 05:57 AM
Discussion RV OSD or Dragon OSD djdaveq FPV Talk 1 Feb 06, 2009 12:18 AM
Discussion RV OSD and Dragon OSD - so near to being Really good! magnetman FPV Talk 8 Nov 11, 2008 05:13 AM
