Old Jul 06, 2010, 02:17 AM
Daniel Wee is offline
Find More Posts by Daniel Wee
Joined Aug 2005
kempo & mark,
Here's something that I've been wondering about - what will happen if the plane was upside down when the stabilizer or autopilot was active. This will be a bit tricky to test and you will need good altitude but it would be interesting, I think.
Daniel
Daniel Wee is offline Find More Posts by Daniel Wee
Old Jul 06, 2010, 04:08 AM
JMSTECH is offline
Find More Posts by JMSTECH
JMSTECH's Avatar
Canada, BC, Duncan
Joined Dec 2006
and no boys... no beers before the test flight or I'll I send one of my girls to slap your hands.
JMSTECH is offline Find More Posts by JMSTECH
Old Jul 06, 2010, 04:22 AM
kempo is offline
Find More Posts by kempo
kempo's Avatar
Romania, IS, Iasi
Joined Nov 2008
Originally Posted by Daniel Wee View Post
kempo & mark,
Daniel
It sounds like a crash .
I should reverse the plane and after that activate the autopilot or while the autopilot is active to reverse the plane manually ?
Please place your bets:it will work or it will kiss mother earth ?
For sure this it's not going to work simply because with the plane reversed the autopilot will steer to the wrong direction(plane reversed) and then we will see death spiral with the plane reversed(best case scenario).
Edited: MAYBE it will work with gps stabilisation.
kempo is offline Find More Posts by kempo
Old Jul 06, 2010, 05:17 AM
badlands is offline
Find More Posts by badlands
When in doubt, throttle out...
badlands's Avatar
Joined Mar 2010
I might give it a try next time - my DOSD+ AP flys my plane better than i do so im sure it can handle an inverted flight.
badlands is offline Find More Posts by badlands
Old Jul 06, 2010, 11:49 AM
kempo is offline
kempo's Avatar
Romania, IS, Iasi
Joined Nov 2008
kempo,
Hmmm... I'm not sure. I fixed a couple of circling bugs in 10.4 but they are not related to your issue. Any chance you can test it again to see if this is repeatable. Ie. test it in VISIT mode first, make sure it works. Then in CIRCLE mode. Then VISIT again. If it's repeatable, I'll be able to fix it.
Daniel
Daniel, today I've tested for over 45 minutes. The problem didn't appear. I've chnged (in flight) between WP-visit to WP-circle and then to WP-visit,WP-circle WP-visit WP-circle many many times without any problem , the plane is returning home.
Maybe yesterday the battery was too weak (I must connect a current sensor-this way the tests should be more relevant)and the plane hasn't enough force to turn around. (the weaker is the battery , the less impact has the command surfaces over the flight).
I can say after several hours of playing with dosd+ that a succesful RTH is about weather conditions,trottle, turning(rotstep/aprot/rotlimit). If you have enough power on your battery there are no problems RTH work almost in any condition.
Old Jul 06, 2010, 12:01 PM
MikeTheCrash is offline
Find More Posts by MikeTheCrash
Just clumsy. Oh, forgetful too
MikeTheCrash's Avatar
undefined
Joined Jun 2008
what do "visit" and "next" do? thanks
MikeTheCrash is offline Find More Posts by MikeTheCrash
Old Jul 06, 2010, 12:10 PM
RacerX208 is offline
Find More Posts by RacerX208
RacerX208's Avatar
Joined Apr 2004
Visit - upon reaching the waypoint when set to visit the aircraft should return home.
Next - upon reaching the waypoint when set to "next" the aircraft shoud proceed to the next waypoint.
RacerX208 is offline Find More Posts by RacerX208
Old Jul 06, 2010, 12:14 PM
undefined
Joined Jun 2008
Thanks RacerX208. So do you activate waypoint navigation by switching on autopilot or by selecting "next" for the first in the list?
thanks!
Old Jul 06, 2010, 05:58 PM
Cralis is offline
Find More Posts by Cralis
I love FPV!
Cralis's Avatar
Eastern side of Australia
Joined Jan 2007
Guys, 0.1.7 Beta of the OSD+ PC Commander is now available.
http://www.forum.tsebi.com/viewtopic...3&p=1019#p1019
A vew small fixes, but the thing I am using is the RSS to see what's up with the firmware updates. If there's a new version, click the blue title lable, and yoiu're taken direct to the download.
Cralis is offline Find More Posts by Cralis
Old Jul 06, 2010, 06:45 PM
AussieHoppy is online now
Find More Posts by AussieHoppy
what goes up, must come down..
AussieHoppy's Avatar
Joined May 2010
you are a busy lil' bee, Craig!
AussieHoppy is online now Find More Posts by AussieHoppy
Old Jul 07, 2010, 10:23 AM
JMSTECH is offline
JMSTECH's Avatar
Canada, BC, Duncan
Joined Dec 2006
To those who are planning to email/PM me in regards to Dragon Lab products/customer support over the weekend, I will be away with family therefore will not be available to reply.
John
Old Jul 07, 2010, 06:03 PM
kyle7119 is offline
Find More Posts by kyle7119
United States, IA, Cedar Rapids
Joined Aug 2009
How configurable is the DragonOSD screen? Could I make it display the altitude with only the numbers instead of it being displayed in that little box? Also, can I move the text to anywhere on the screen?
kyle7119 is offline Find More Posts by kyle7119
Old Jul 07, 2010, 06:09 PM
badlands is offline
badlands's Avatar
Joined Mar 2010
Yes you can remove the altitude ladder.
You can also move the text but it sort of moves as a whole, so you are able to position the whole screen not individual text items.
Old Jul 07, 2010, 08:14 PM
Joined Aug 2005
kyle7119,
You can turn off most of the displayed items if you don't want them. You also have other screen display options that you can use. You cannot arbitrarily move them around though.
Daniel
Old Jul 07, 2010, 08:15 PM
Cralis is offline
I love FPV!
Cralis's Avatar
Joined Jan 2007
Guys, there was an issue with 0.1.7B of the PC Commander, and versions of the firmware prior to 10.5. This has been resolved. 0.1.8B is now available, and it would be best to get if, whether or not you're on the latest firmware. But if you're on an older firmware, and running 0.1.7B, you will get errors.
Sorry about that guys. My mistake. My wife has a whip out now to punish me.
Discussion Dragon OSD Level Flight FPV Talk 22 Dec 31, 2013 09:08 PM
For Sale New Intelligent Flight Dragon OSD bfischer Aircraft - General - Miscellaneous (FS/W) 7 Jul 19, 2010 12:56 PM
Discussion FS Ready to fly Intelligent Flight Dragon OSD bfischer FPV Talk 0 Mar 03, 2010 06:57 AM
Discussion RV OSD or Dragon OSD djdaveq FPV Talk 1 Feb 06, 2009 01:18 AM
Discussion RV OSD and Dragon OSD - so near to being Really good! magnetman FPV Talk 8 Nov 11, 2008 06:13 AM
