Old Feb 25, 2013, 08:37 PM
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Originally Posted by flyhigh300 View Post
Hello all,
I have my first DOSD install .. with a little reading and research the install went ok,
No major hang ups..
But one thing that is not clear to me is RTH mode vs AP mode ?
I have my mode switch set up . ( 3 position switch)
1. OSD on ( **AP disabled**) will Flash
2. OSD on ( "AP disabled" - Stops Flashing)
3. Menu System
Now how does one enable RTH ? :-) haha.. probably something I'm over looking, but it does not pop out at me.
Yes. Okay, really AP mode is AutoPilot. Guess what RTH is? Yep, Auto Pilot. And how about flying waypoints? Yep, also Auto Pilot.
So how do you select between RTH and Waypoints when switching into AP mode? That's all in the Waypoint setting. When your Waypoint (in the menu) is set to "0" then AP IS RTH mode. When Waypoint is set to anything other than "0" then AP is Waypoint mode.
The Waypoint number is the waypoint you want to fly to. Let's say you load a WP mission with 10 waypoints. You can tell the DOSD what waypoint you want to fly to. By setting the Waypoint to "1" and engage AP the plane will fly to waypoint #1, the fly the remaining is sequence and RTH after the last waypoint. If you set the waypoint to #6, the AP will skip WPs 1-5, go directly to WP 6, complete the remaining waypoints the RTH. So while in flight you can jump directly from one waypoint to the next. The AP will just fly the remaining points in sequence. Hope that makes sense.
So what happens if you're in a WP mission and loose Tx contact? Nothing. You're already in AP mode, so the DOSD flies the mission and RTH's after the last waypoint. Just remember to leave the Waypoint to 0 all the time, except when you want to fly a mission. That way the DOSD will always RTH when AP is engaged.
As far os your "AP Disable" messages...that's the correct display when you don't have GPS lock. DOSD requires GPS to fly in AP mode. Your 'home' position is wherever GPS lock is acquired. You CAN fly without GPS lock, but if the GPS locks while you're in flight, wherever that spot is has now become your 'home' position...so don't fly until you have GPS lock if you want your plane to RTH.
Vantasstic is offline Find More Posts by Vantasstic
Old Feb 25, 2013, 08:57 PM
Eastcoast78's Avatar
Can A da....Ehh!!
Joined May 2010
awesome run down Van, I almost got my bixler together! just glueing the fuse together as we speak. Got a question...
I'm going to install the baro, i was seeing a few days ago about the best place to install etc, like out of the direct sun, in clean airflow etc. My friend who is a pilot was just over for a visit and we were discussing how i should install it. I was thinking on the side of the fuse just before the nose curves, but i don't want debre getting on it as she is a belly lander. Plus the snow would not help!
So is it ok to jsut hot glue it to the fuse? should it be embed with just the sensor flush with the fuse.
I am about to do some searching of photos.
Eastcoast78 is offline Find More Posts by Eastcoast78
Old Feb 25, 2013, 09:06 PM
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Any airflow over the baro will cause inaccurate readings. Place the baro in a piece of open cell foam (so it can sense the air pressure without airflow over it) and place in somewhere in the fuse were it's out of the way and out of direct air flow.
Old Feb 25, 2013, 09:17 PM
Can A da....Ehh!!
Joined May 2010
ohh wow!! man i need to get a new pair of glass's... lmao
Thanks Van
Old Feb 25, 2013, 10:19 PM
Joined Nov 2010
Van,
Thanks..
But now it looks like my GPS is down..
Before I would get ( squares, when it was trying to get GPS lock)
it has stop doing that.. now.. could I have changed anything to disable it.. ?
flyhigh300 is offline Find More Posts by flyhigh300
Old Feb 25, 2013, 11:10 PM
Joined Nov 2010
So .. I'm finding out that firs time take a long time .. ?
only difference I see is that I did not see an attempt for it to lock in.
but connecting it to DOSD PC Commander shows GPS is ok.
So its sitting out side now for a bit ...
Stay tuned..
Old Feb 26, 2013, 01:15 AM
Can A da....Ehh!!
Joined May 2010
when i find it hard to lock on inside...grab a big piece of aluminium foil. I grabbed a tin lid form a cookie container tonight and lock on inside in a basement with in a few mins. and its over cast with a bit of snow ;-0)
Old Feb 26, 2013, 11:16 AM
Rick
hammer833's Avatar
Winnipeg, Manitoba, Canada
Joined Apr 2007
What do you do with the tinfoil? Wear it as a hat to stop the Alien mind probes?
Seriously though what do you do with the tinfoil?
Rick
hammer833 is offline Find More Posts by hammer833
Old Feb 26, 2013, 11:54 AM
Joined Oct 2012
Rick
Hello Rick
As I understand the tinfoils works as an antenna that pick up the signal from the satellites and gets the GPS locked faster.
Here is a video from Chanyote66, making some upgrades to the GPS
FPV GPS upgrades (14 min 50 sec)
I will do that, before intalling it on the fuselage
Cheers,
Juan
Juanp is offline Find More Posts by Juanp
Old Feb 26, 2013, 12:05 PM
Rick
hammer833's Avatar
Joined Apr 2007
Originally Posted by Juanp View Post
Hello Rick
http://www.youtube.com/watch?v=HU44W7lBZuM
Cheers,
Juan
Ok I get it now.
Thanks Juan
Old Feb 26, 2013, 01:59 PM
Every day Im FPV'n
chanyote66's Avatar
United States, TN, Oak Ridge
Joined Dec 2011
yes and no...
Think of the foil or metal as the Dish of a satellite. The "dish reflects the signal into the LMB that sends the signal to your TV box. The same thing happens with the Reflector plate, be it aluminum, tin, copper, and even gold if your ball'n... The GPS signals that pass the Module are reflected to give the gps antenna a second chance to get the data. you dont want a parabolic design like a actual satellite dish because it will focus the beam and actually reduce the performance by limiting the view of the sky...
Chris
chanyote66 is online now Find More Posts by chanyote66
Old Feb 26, 2013, 02:14 PM
KK4NOP
Mike Freas's Avatar
United States, VA, Virginia Beach
Joined Aug 2005
I believe you can change a setting to tell the aircraft what to do when it reaches the assigned WP. Loiter, Hold, or RTH. So in your example the aircraft would go and visit WP 6 then RTH if the "visit" setting was selected.
Mike Freas is offline Find More Posts by Mike Freas
Latest blog entry: Pan/Tilt servo mods
Old Feb 26, 2013, 03:47 PM
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
You are correct. You can select circle, loiter, next, visit, etc for each waypoint hit. Some of the actions don't make much sense to me though, like circle or visit. Why create a waypoint mission where the plane will sit and indefinetly circle a WP once it gets there? And why just 'visit' and RTH a waypoint? I guess there's times where these make sense...like you want to load multiple waypoints in a single mission with the idea of not flying a 'full mission', but more for being able to select an individual WP and have it do it's thing. I've only played with WPs as a full mission where it does one point after the other. Mostly I just fly myself to wherever I want to go, engage AP to RTH back and just enjoy the view home as the DOSD flies the plane.
Old Feb 26, 2013, 03:50 PM
Rotary
blueprint's Avatar
Joined Sep 2007
i setup a circle waypoint that way i can just leave it on auto pilot and pan/tilt the area i applied my waypoint too. i don't often do it but it's just about the only reason i do use it.
blueprint is offline Find More Posts by blueprint
Old Feb 26, 2013, 03:56 PM
Rotary
blueprint's Avatar
Joined Sep 2007
DragonOSD is just awesome!
C47 at the Wash. (16 min 1 sec)
Discussion Dragon OSD Level Flight Video Piloting (FPV/RPV) 20 Apr 17, 2011 12:12 PM
For Sale New Intelligent Flight Dragon OSD bfischer Aircraft - Electric - Miscellaneous (FS/W) 7 Jul 19, 2010 11:56 AM
Discussion FS Ready to fly Intelligent Flight Dragon OSD bfischer Video Piloting (FPV/RPV) 0 Mar 03, 2010 05:57 AM
Discussion RV OSD or Dragon OSD djdaveq Video Piloting (FPV/RPV) 1 Feb 06, 2009 12:18 AM
Discussion RV OSD and Dragon OSD - so near to being Really good! magnetman Video Piloting (FPV/RPV) 8 Nov 11, 2008 05:13 AM
