Old Feb 21, 2013, 07:01 PM
metalbender4by is offline
Find More Posts by metalbender4by
hey whats burning?
metalbender4by's Avatar
United States, FL, Vero Beach
Joined Oct 2007
Originally Posted by Vantasstic View Post
Never heard of SNOW peas!?
Yea and winter wheat...
metalbender4by is offline Find More Posts by metalbender4by
Old Feb 22, 2013, 11:40 AM
Rexnoobs247 is offline
Find More Posts by Rexnoobs247
FPV FTW!!
United States, MI, Grand Rapids
Joined Oct 2011
Ok ok, but Dragon Tracks! Me want Dragon Tracks!!!
Rexnoobs247 is offline Find More Posts by Rexnoobs247
Old Feb 22, 2013, 11:56 AM
Buffythesaint is offline
Find More Posts by Buffythesaint
Joined Feb 2005
Me too. Virgis popped in once a while back but no word yet. I'd like to have it for this summer. Need a DT's thread, if it ever gets released.
Buffythesaint is offline Find More Posts by Buffythesaint
Old Feb 22, 2013, 09:58 PM
DodgeRC is offline
Find More Posts by DodgeRC
Cable ties & ductape
DodgeRC's Avatar
United Kingdom, Wilmslow
Joined May 2011
Any FrSky users; I'm looking at getting the option to use the DOSD menu, but the manual says I need a PPM signal to access and navigate the menu, my Receiver is the V8FR-II.
Also I have connected to the PC it as it states in the manual using a "USB 2.0 TO RS232 Converter UART TTL Serial" it registers it as being on COM3, but fails to connect in PC Commander
Anyone have any ideas?!
DodgeRC is offline Find More Posts by DodgeRC
Old Feb 22, 2013, 10:39 PM
Yabba is offline
Find More Posts by Yabba
Gravity - It's the law
Yabba's Avatar
USA, CO, Denver
Joined Jul 2008
The DOSD needs to be powered if you haven't already. It doesn't get any power thru the USB port
Yabba
Yabba is offline Find More Posts by Yabba
Old Feb 23, 2013, 05:45 AM
DodgeRC is offline
DodgeRC's Avatar
Joined May 2011
Yabba
Cheers Yabba, however I've had it set-up so it shows on the my fpv monitor, and then plug it in, yet still nothing. It says connection failed. I have connected the 'Gnd, Txd & Rxd'
Old Feb 23, 2013, 09:22 AM
DodgeRC is offline
DodgeRC's Avatar
Joined May 2011
Ok, my fault, I was unaware that the DOSD needed Vtx and Flight battery connected in order to connect to the PC.
Old Feb 23, 2013, 10:06 AM
skellator is offline
Find More Posts by skellator
9W2DLR
Malaysia, Pahang, Temerloh
Joined Nov 2011
you don't need vtx connected, you just need to power it in someway like removing jumper and power it via a small 3s lipo pack like doing 2 batt setup
skellator is offline Find More Posts by skellator
Old Feb 23, 2013, 01:04 PM
DodgeRC is offline
DodgeRC's Avatar
Joined May 2011
Sorry that was what I meant, needed 2 lots of batteries connected before it showed up on the PC, =]
Old Feb 23, 2013, 06:59 PM
DodgeRC is offline
DodgeRC's Avatar
Joined May 2011
Can anyone shed some light on PPM?
Im using the FrSky V8FR-II w/ the DJT Module in the 9x.
Can I use this to operate the DOSD menu?
Old Feb 23, 2013, 07:54 PM
MikeTheCrash is offline
Find More Posts by MikeTheCrash
Just clumsy. Oh, forgetful too
MikeTheCrash's Avatar
undefined
Joined Jun 2008
Hi Dodge I just had a quick look at the manual for your Rx and there's no mention of PPM output, though I think (no experience here) you can get different firmware versions so maybe there is a fix out there.
if you don't find a fix for it, there's always the PPM encoder http://www.dragonlabseu.bigcartel.co...ct/ppm-encoder
m.
PS go to sleep!!
MikeTheCrash is offline Find More Posts by MikeTheCrash
Old Feb 23, 2013, 07:58 PM
9W2DLR
Joined Nov 2011
that rx doea not have ppm, my personal favorite is d4fr-II there is another 7 channel rx for frsky that have ppm cant remember the model best to check frsky website for new products
Old Feb 23, 2013, 09:38 PM
DodgeRC is offline
DodgeRC's Avatar
Joined May 2011
Cheers Skell =]
I've seen the D8R-II PLUS which can be re-flashed to output CPPM,
It's a rightt pain as i've had no issues with Frsky =]
m.
PS go to sleep!!
Cheers Mike, didn't want to nag you haha =P
I'll check the receiver mentioned above and if that doesn't work, ill try the encoder! Setting up for the basics was nice and easy, for anything more it aint half complicated! haha
Dodge
( I will when this DOSD is sorted =P )
Old Feb 24, 2013, 06:47 AM
allfiredup is offline
Find More Posts by allfiredup
Joined Mar 2012
When adjusting my gain knob, should i be seeing the value of auto-stab change in the menu or is it all done in the background?
I can see the value changing in the diagnositc screen ok.
edit - its ok I found it, thanks to Van, again.
You'd have to go in to the menu to adjust the max stab setting. Your gain slider/knob varies between zero and whatever max you have set. Try setting the gain to something like 10 with a half way slider position and try again. If you're flying in smooth air you may not notice much difference. If you're in windy/bumpy conditions the gain difference will probably show up more. For me, I don't really use it.
allfiredup is offline Find More Posts by allfiredup
Old Feb 24, 2013, 07:16 AM
Pixturethis is offline
Find More Posts by Pixturethis
Pixturethis's Avatar
Wichita
Joined Dec 2008
Anyone know if thee is away to move the characters in a little bit from the edges of the screen ?
Only on my headplays can I see the very edge of the screen, but on the monitor I fly with I'm missing about half of the characters.
Marc
Pixturethis is offline Find More Posts by Pixturethis
Discussion Dragon OSD Level Flight FPV Talk 22 Dec 31, 2013 09:08 PM
For Sale New Intelligent Flight Dragon OSD bfischer Aircraft - General - Miscellaneous (FS/W) 7 Jul 19, 2010 12:56 PM
Discussion FS Ready to fly Intelligent Flight Dragon OSD bfischer FPV Talk 0 Mar 03, 2010 06:57 AM
Discussion RV OSD or Dragon OSD djdaveq FPV Talk 1 Feb 06, 2009 01:18 AM
Discussion RV OSD and Dragon OSD - so near to being Really good! magnetman FPV Talk 8 Nov 11, 2008 06:13 AM
