Old Feb 13, 2013, 04:36 PM
Mike Freas is offline
Find More Posts by Mike Freas
KK4NOP
Mike Freas's Avatar
United States, MD, Lusby
Joined Aug 2005
Verified I have proper control movements for testing the AP this weekend. Weather looks like poo here in VA for Sat and Sun so I will wait until Monday to give her a test.
Mike Freas is offline Find More Posts by Mike Freas
Old Feb 13, 2013, 06:09 PM
blueprint is offline
Find More Posts by blueprint
FPV Pilot
blueprint's Avatar
Joined Sep 2007
Just tested the FY-DOS and i'd have to say it performed very well. Heading hold worked as advertised.
blueprint is offline Find More Posts by blueprint
Old Feb 13, 2013, 06:50 PM
MikeTheCrash is offline
Find More Posts by MikeTheCrash
Just clumsy. Oh, forgetful too
MikeTheCrash's Avatar
undefined
Joined Jun 2008
Did you use it for AHI?
MikeTheCrash is offline Find More Posts by MikeTheCrash
Old Feb 13, 2013, 06:55 PM
FPV Pilot
blueprint's Avatar
Joined Sep 2007
AHI?
I tested it with the GPS and it loitered/circled and returned to home fine. What i wanted to test was the heading hold and altitude hold. It worked fine and held the course. Very neat feature that the FY30 does not have.
The only downside to the FY-DOS is the fact that you need a computer to make changes in it's settings such as gain etc.
Pretty happy and the strange thing is it's cheaper than the FY30.... not so sure why.
Old Feb 13, 2013, 10:34 PM
erkq is offline
Find More Posts by erkq
United States, CA, Sebastopol
Joined Dec 2010
AHI?
Artificial Horizon Indicator
erkq is offline Find More Posts by erkq
Old Feb 14, 2013, 01:23 AM
FPV Pilot
blueprint's Avatar
Joined Sep 2007
Nope. Not a fan of it honestly as it gets in the way. I fly with way points and often toggle in the menu to access/change settings. The RVOSDV5 has a nice layout with its AHI however.
Tried it with my fy30 and did not like it.
Old Feb 14, 2013, 05:57 PM
jasper7821 is offline
Find More Posts by jasper7821
United States, AZ, Tucson
Joined Mar 2008
Question about the external barometer on the Dragon OSD
Lately my external barometer has been giving all kinds of weird readings thorough the flight. Like mid flight I'll be at 200ft then all of a sudden it will go to 0 and land at -200ft and other different things. And at th eend of a flight it will say max altitude was 4,000ft when I only went a few hundred and I'm at 2k MSL
If I remove it I'll still get altitude in the display from the GPS right?
FPV test almost 3,000ft out (3 min 32 sec)
jasper7821 is offline Find More Posts by jasper7821
Old Feb 14, 2013, 06:05 PM
metalbender4by is offline
Find More Posts by metalbender4by
hey whats burning?
metalbender4by's Avatar
United States, FL, Vero Beach
Joined Oct 2007
http://youtu.be/0Fd19qNyzW8
Yes the GPS will provide the altitude.
You might be having a problem with the barometer due to the air flow through the plane. Try wrapping a small pieces of foam around the barometer and put in a spot with the least amount of air flow. They can be sensitive to moving air.
metalbender4by is offline Find More Posts by metalbender4by
Old Feb 14, 2013, 06:51 PM
Joined Mar 2008
Ok, thanks. I'll try that.
I had it mounted inside my quad frame, then I put it out onto the bottom on the quad to see if it made it better. obviously it did not make it better. I'll see how putting it in foam does thank you very much.
Old Feb 15, 2013, 12:46 AM
skellator is offline
Find More Posts by skellator
9W2DLR
Malaysia, Pahang, Temerloh
Joined Nov 2011
i fine the text a bit small to me is there anyway to make the text bigger?
skellator is offline Find More Posts by skellator
Old Feb 15, 2013, 03:00 AM
FPV Pilot
blueprint's Avatar
Joined Sep 2007
i love you DragonOSD. Paired with the FY-DOS or FY30 it's an unbelievable OSD.
Penguin FPV (15 min 36 sec)
Old Feb 15, 2013, 08:24 AM
Vantasstic is offline
Find More Posts by Vantasstic
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
No.
Vantasstic is offline Find More Posts by Vantasstic
Old Feb 15, 2013, 10:12 AM
erkq is offline
Joined Dec 2010
Yes. Use a bigger monitor. No help with goggles though.
Old Feb 15, 2013, 10:47 AM
9W2DLR
Joined Nov 2011
I don't use monitor, only goggle no choice then have to chew with what I have
Old Feb 15, 2013, 10:49 AM
Buffythesaint is offline
Find More Posts by Buffythesaint
Joined Feb 2005
Some baro sensors are sensitive to light. Make sure it doesn't get direct sunlight.
Buffythesaint is offline Find More Posts by Buffythesaint
Discussion Dragon OSD Level Flight FPV Talk 22 Dec 31, 2013 08:08 PM
For Sale New Intelligent Flight Dragon OSD bfischer Aircraft - General - Miscellaneous (FS/W) 7 Jul 19, 2010 11:56 AM
Discussion FS Ready to fly Intelligent Flight Dragon OSD bfischer FPV Talk 0 Mar 03, 2010 05:57 AM
Discussion RV OSD or Dragon OSD djdaveq FPV Talk 1 Feb 06, 2009 12:18 AM
Discussion RV OSD and Dragon OSD - so near to being Really good! magnetman FPV Talk 8 Nov 11, 2008 05:13 AM
