Old Feb 10, 2013, 07:04 PM
Mike Freas is offline
Find More Posts by Mike Freas
KK4NOP
Mike Freas's Avatar
United States, MD, Lusby
Joined Aug 2005
Originally Posted by blueprint View Post
Nice congrats! Im using the penguin as well with dragonlink and dragonosd.
Cool. I'd live to see some pictures. Mine is full of wires now with the OSD installed. Things get complicated quick.
Mike Freas is offline Find More Posts by Mike Freas
Old Feb 10, 2013, 07:08 PM
blueprint is offline
Find More Posts by blueprint
FPV Pilot
blueprint's Avatar
Joined Sep 2007
Good thing the penguin has tons of space.
I have an fy30 with dragonosd on top of 2 gopros and a pan/tilt fpv camera so u can imagine the rat nest in my penguin!
blueprint is offline Find More Posts by blueprint
Old Feb 10, 2013, 08:35 PM
Vantasstic is offline
Find More Posts by Vantasstic
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Thought about that but it is set correctly on Multiplex as I'm flying with a HiTech A9.
I just my radio type to 'Other'. That way the DOSD never tries to readjust my settings.
Vantasstic is offline Find More Posts by Vantasstic
Old Feb 10, 2013, 11:24 PM
skellator is offline
Find More Posts by skellator
9W2DLR
Malaysia, Pahang, Temerloh
Joined Nov 2011
did first flight with the OSD on my BeeEvo, didnt turn out as expected which end up with landing crashing to tree monster, broke a servo horn luckly i bring spare and manage to fix it on the field
need some fine tuning to get it right, when RTH enabled plane make a steep bank to the left and rocking the my wing way to much, plus my fpv ride was scary (first time fpv with the wing) stall speed was at 40kph! cruise speed at 60-70kph with 60% throttle it scare the s**t out off me at downwind it goes wooping 107kph
plus the wing a bit heavy does not glide well, need a few adjustment with the plane and osd, for OSD where should I start for tuning the RTH? where to limit the throw used by RTH? as normal flying condition i only need 25% of the control in my radio with dual rate 20/25% so i need to limit the throw being used by OSD let said 15%?, charging my battery at the moment to calibrate the sensor as 1837mAh used at 10.5v for 4200mAh is way off
skellator is offline Find More Posts by skellator
Old Feb 11, 2013, 04:43 AM
metalbender4by is offline
Find More Posts by metalbender4by
hey whats burning?
metalbender4by's Avatar
United States, FL, Vero Beach
Joined Oct 2007
How many cells/volts can the current sensor handle?
metalbender4by is offline Find More Posts by metalbender4by
Old Feb 11, 2013, 06:44 AM
MikeTheCrash is online now
Find More Posts by MikeTheCrash
Just clumsy. Oh, forgetful too
MikeTheCrash's Avatar
undefined
Joined Jun 2008
I am building a 6s 120A EDF and Daniel told John to tell me the 90A current sensor would handle it! I had bought a 200A hall effect sensor by the time I got my answer so I am using it anyway just in case.
MikeTheCrash is online now Find More Posts by MikeTheCrash
Old Feb 11, 2013, 09:13 AM
Flybynight2 is offline
Find More Posts by Flybynight2
Will it ever Fly?
Flybynight2's Avatar
United States, AZ, Beaver Dam
Joined Nov 2011
Darn, already have mine.
RMRC has DOSD on sale for $139 now.
Flybynight2 is offline Find More Posts by Flybynight2
Old Feb 11, 2013, 10:15 AM
FPV Pilot
blueprint's Avatar
Joined Sep 2007
anybody try the Feiyu Tech FY-DOS? It has some interesting features. I plan on using it without GPS since the DragonOSD has GPS. It has a heading hold and altitude feature that has me intrigued. Something that the FY30 does not have.
Has anybody used the FY-DOS with DragonOSD? The FY30 for me has worked great but it does not offer a heading hold.
Old Feb 11, 2013, 04:34 PM
hey whats burning?
Joined Oct 2007
Thats great info. Thanks.
Old Feb 11, 2013, 04:59 PM
KK4NOP
Mike Freas's Avatar
Joined Aug 2005
Is it possible to pull mission files using the DOSD+config tool? This is currently the program I'm using as I can not get the other working. Reviewed the directions but don't really understand how to do it.
Old Feb 11, 2013, 05:43 PM
viper522 is offline
Find More Posts by viper522
United States, FL, Palm Beach
Joined Jan 2011
Like a lunatic, I killed the solder pad on my dosd GPS module's pcb. It's where the white wire would solder to. Can I just solder to the rv1 leg instead? Would be tricky but I think I have the tools to do it. Or anywhere else on the GPS module pcb? Mine is a locosys mc1513 1205c 1590r-a.
viper522 is offline Find More Posts by viper522
Old Feb 11, 2013, 07:36 PM
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
I don't believe the DOSD Config program downloads GPS track files. It also doesn't display the newer features added in DOSD after the program was last updated. Both programs were created by talented DOSD users so updates are subject to how often they update. That's why I use PC Commander. It is the most current with the DOSD firmware.
Old Feb 11, 2013, 07:39 PM
KK4NOP
Mike Freas's Avatar
Joined Aug 2005
Ok. I will have to try and get the other program working then.
Old Feb 11, 2013, 07:47 PM
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
You can do a log data dump via a terminal program (Hyper Terminal, Terra Terminal, etc). The instructions are in the manual and you'll have to do some formatting of the raw data. Way easier if you can get PCC running though.
Old Feb 11, 2013, 08:06 PM
KK4NOP
Mike Freas's Avatar
Joined Aug 2005
I don't konw about the PC Commander. Really wish I could get it to work.
I have Windows 7. Downloaded the most updated version of the software, extracted all the files and installed them. When I click the program all I get is a dialog box that says "DOSD+ PC Commander has quit working."
At this point I'm willing to pay a bit for some help if someone was willing to do a net meeting with me and figure it out.
PM to discuss.
Discussion Dragon OSD Level Flight FPV Talk 22 Dec 31, 2013 08:08 PM
For Sale New Intelligent Flight Dragon OSD bfischer Aircraft - General - Miscellaneous (FS/W) 7 Jul 19, 2010 11:56 AM
Discussion FS Ready to fly Intelligent Flight Dragon OSD bfischer FPV Talk 0 Mar 03, 2010 05:57 AM
Discussion RV OSD or Dragon OSD djdaveq FPV Talk 1 Feb 06, 2009 12:18 AM
Discussion RV OSD and Dragon OSD - so near to being Really good! magnetman FPV Talk 8 Nov 11, 2008 05:13 AM
