Old Feb 08, 2013, 11:49 AM
Mike Freas is offline
Find More Posts by Mike Freas
KK4NOP
Mike Freas's Avatar
United States, MD, Lusby
Joined Aug 2005
Originally Posted by MikeTheCrash View Post
the wires going onto the CS board are soldered the wrong way around! If you look at the legend on the board you will see labels GND and V2.
Where did you get the CS or did you resolder it
If DOSD is still working then perhaps you may have burnt the track between J1 and the current sensor but that will be easy to bypass - or if powering from the power pins you don't need it anyway. I think you said you had continuity between these points anyway? DOSD is pretty robust, and I don't see why running current backwards throuigh the CS could have damaged it. Hopefully all is well!
Purchased NIB from a fellow RCG member.
Dagnabit! I didn't even see that. Well, I still have continuity between the CS input and J1 so hopefully the board is still good. I'll resolder the CS and check it out. Regardless I have a new one coming and they are cheep.
Thank you so much!!!!!
Mike Freas is offline Find More Posts by Mike Freas
Old Feb 08, 2013, 12:18 PM
PenJo is offline
Find More Posts by PenJo
Joined Sep 2010
Question: DOSD output to PPM encoder?
Hi guys,
do you think that this PPM encoder can encode 4 DOSD outputs and other 4 pwm channels connected directly from receiver to usable 8 channel PPM sum
stream?
http://store.diydrones.com/product_p/br-ppme.htm
And why i need it? I wat to connect board loaded with openaero firmware with DOSD and 1) avoid jittering due to DOSD output timing and 2) save some
wires compared with my actual wiring 3) im curious if this can work
Pen
PenJo is offline Find More Posts by PenJo
Old Feb 08, 2013, 12:59 PM
chanyote66 is offline
Find More Posts by chanyote66
Mobius Cables... I got em'
chanyote66's Avatar
United States, TN, Oak Ridge
Joined Dec 2011
your CS is soldered backwards - the GND should be black, voltage red and current monitor white wires.
Originally Posted by PenJo View Post
Hi guys,
stream?
Pen
yup
Iv ran KK2.1 (openaero) KK2.0(openaero2) and testing the NAZE32 (Openaero32) now...
Chris
chanyote66 is offline Find More Posts by chanyote66
Old Feb 08, 2013, 02:34 PM
Vantasstic is offline
Find More Posts by Vantasstic
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Well the others beat me to it...see what a picture can do over a video? As soldered you would of had reverse polarity from the CS to the DOSD. This can cause problems, hopefully not.
Vantasstic is offline Find More Posts by Vantasstic
Old Feb 08, 2013, 09:17 PM
vork22 is offline
Find More Posts by vork22
a wild pilot
vork22's Avatar
Joined Mar 2011
Only 4 channels available on Dragon OSD?
Hello, sorry if this is an obvious question but I recently started flying a quadcopter using an Open Pilot CC3D with a Dragon UHF and I was researching getting the Dragon OSD. I like that it has RTH, but it appears that if I want to use that feature, I would plug the Dragon UHF PPM into the Dragon OSD but then there are only 4 PWM outputs for my flight controller. What happens to my other channels, am I just limited to 4 if I use the Dragon OSD?
vork22 is offline Find More Posts by vork22
Old Feb 08, 2013, 09:57 PM
Eastcoast78 is offline
Find More Posts by Eastcoast78
Dixie Normious
Eastcoast78's Avatar
Can A da....Ehh!!
Joined May 2010
I don't think RTH well work for a Muti-Rotor
Eastcoast78 is offline Find More Posts by Eastcoast78
Old Feb 08, 2013, 10:02 PM
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Eastcoast is correct. The DOSD can only be used for OSD purposes (no AutoPilot/RTH capabilities) on helicopters and multirotors. The DOSD works perfectly for AP functions on fixed wing.
Old Feb 08, 2013, 10:14 PM
vork22 is offline
a wild pilot
vork22's Avatar
Joined Mar 2011
Ah I see, still worth getting though. I guess I'll just have to fly home myself :]
Thanks!
Old Feb 08, 2013, 10:22 PM
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Thanks!
There are controllers available with RTH capability. I don't know of any multirotor controller that also has built in OSD capability. I used a DJI Naza as a controller and used DOSD as my OSD source. It worked great. The Naza had the RTH capability and the DOSD game me volts, amp, altitude, distance, speed, direction home, etc.
Old Feb 09, 2013, 03:16 AM
Carlos230023 is offline
Find More Posts by Carlos230023
um.. yeah, I can make that fly
Carlos230023's Avatar
United Kingdom, Milton Keynes
Joined Jun 2007
The hoverfly pro has a built in OSD. Fantastic system. But quite expensive. Especially when you get the GPS addon board for RTH and more OSD features. I had the whole system but recently sold it as I'm going into duelcopters which are one of few configurations they don't support.
CJ
Carlos230023 is offline Find More Posts by Carlos230023
Old Feb 09, 2013, 03:55 AM
skellator is online now
Find More Posts by skellator
9W2DLR
Malaysia, Pahang, Temerloh
Joined Nov 2011
if you willing to read and experiment apm2.5 also a good controller for multirotor, it have rth waypoint alk those sort of thing, it have osd add-on too, but well back to dosd rewiring everything on my beevolution flying wing, elevon mox need to be cleared from radio?
plus need to figure out the servo direction thingy for elevon setup, almost there maybe will be testing it i a few days
skellator is online now Find More Posts by skellator
Old Feb 09, 2013, 11:31 AM
KK4NOP
Mike Freas's Avatar
Joined Aug 2005
Up until midnight last night and back at it this morning....
Seems I have everything hooked up and working. Current sensor output (servoc connector) was soldered backward and a easy fix. I also found the V trace burned on the board from the battery + side to the 12v wire going to the osd so I fixed that also. Saprisingly the current sensor works after all that BS. I'll still replace it when the new one arrives.
I believe there is a bug in the programing that may have serious effects when I do finally get to the AP capability.
For the life of me I could not get the rudder to NOT be mixed with the throttle. My radio Tx channel settings are as follows.
Ch 1 AILE (J1 or right stick)
Ch 2 Elev (J2 or right stick)
Ch 3 Thro (J3 or left stick)
Ch 4 Rudd (J4 or left stick)
Ch 5 AIL2 (J1 or right stick)
CH 6 (Right slider for pan)
CH 7 (switch E for flight mode)
The only connections on my DL Rx are PPM, Ch 3 for throttle, RSSI, and ch 6 for pan.
The DOSD+config has the following channel assignments.
CTRL channel 7
Aile channel 1
Elev channel 2
Rudder channel 4
Thro channel 3
Aile2 channel 5
Pan channel 6
Output channels are assigned as follows
1 elev
2 Rudd
3 ail 1
4 ail 2
In this exact configuration my rudder mixes with the throttle and will not work independently. If I change output 2 to "throttle" the rudder and throttle work perfect. The question is will the OSD control the rudder as the throttle when it's trying to fly back?
Or more likely I've missed something yet again?
Old Feb 09, 2013, 11:40 AM
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
CJ
Don't forget the HF is a large controller. I've seen a few. HUGE compared to other controllers I've seen. Did they support fixed wing, waypoints, etc?
Old Feb 09, 2013, 11:47 AM
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
CTRL channel 7
Aile channel 1
Elev channel 2
Rudder channel 4
Thro channel 3
Aile2 channel 5
Pan channel 6
1 elev
2 Rudd
3 ail 1
4 ail 2
I've never seen the DOSD mix in rudder with throttle. There is a setting in the DOSD for rudder mix. Mode 0=No Rudder mix w/aileron, Mode 1=Rudder mix with aileron, Mode 2=Rudder mix with aileron in the opposite direction. Try finding and turning off the Rudder Mix and see what happens. Note: Rudder Mix ONLY works when in AP mode. It does not 'mix' rudder with aileron in normal mode. I'd be more inclined to think it's either an input channel assignment error or some sort of mixing from your Tx. You can try creating a whole new model in a different memory location and see if you can eliminate the unwanted mixing.
Old Feb 09, 2013, 11:50 AM
KK4NOP
Mike Freas's Avatar
Joined Aug 2005
I can try those things. Reset to a new model when I started this little project. I did a servo test swith the model sitting in the house and the controlls are moving to turn it to the right but the elevator is going full down?
At least the OSD itself is working so that is good. Need to clean up the mess of wires in the airplane now and confirm it still works.
Discussion Dragon OSD Level Flight FPV Talk 22 Dec 31, 2013 09:08 PM
For Sale New Intelligent Flight Dragon OSD bfischer Aircraft - General - Miscellaneous (FS/W) 7 Jul 19, 2010 12:56 PM
Discussion FS Ready to fly Intelligent Flight Dragon OSD bfischer FPV Talk 0 Mar 03, 2010 06:57 AM
Discussion RV OSD or Dragon OSD djdaveq FPV Talk 1 Feb 06, 2009 01:18 AM
Discussion RV OSD and Dragon OSD - so near to being Really good! magnetman FPV Talk 8 Nov 11, 2008 06:13 AM
