Old Jan 27, 2013, 03:56 PM
Carlos230023 is offline
Find More Posts by Carlos230023
um.. yeah, I can make that fly
Carlos230023's Avatar
United Kingdom, Milton Keynes
Joined Jun 2007
1.65f is an enormous amount of power to store. I would go for 1000uf at the most, brownouts only tend to happen for nanoseconds. If it lasts longer than that I think you have bigger problems :P
CJ
Carlos230023 is offline Find More Posts by Carlos230023
Old Jan 27, 2013, 04:10 PM
chanyote66 is offline
Find More Posts by chanyote66
Mobius Cables... I got em'
chanyote66's Avatar
United States, TN, Oak Ridge
Joined Dec 2011
CJ
yes, the super caps are only 1g each for .33f but their output is low, this combined with the two 1000uf provides rock solid power
so now i just need similar setups for the OSD...
chanyote66 is offline Find More Posts by chanyote66
Old Jan 27, 2013, 04:13 PM
chanyote66's Avatar
Joined Dec 2011
Originally Posted by GLADUS63 View Post
I would just say that the more things you add, the more weakness points / cause of trouble you add.
If just a cap become shorted, it's all the system that would be out of order...
Cedric
so far all of the capacitors are directly soldered to the equipment, epoxied on and then shrink-wrapped. the chance of a short is lower than the chance of a brownout.
Chris
Old Jan 27, 2013, 11:06 PM
GLADUS63 is offline
Find More Posts by GLADUS63
GLADUS63's Avatar
France, Limousin, Limoges
Joined Jul 2009
Chris
So let us now how it goes.
I have changed mine for going in my penguin, and when configuring it (changing value of OSD) using video, I have some reboot, but may be it's normal...
Cedric
GLADUS63 is offline Find More Posts by GLADUS63
Old Jan 28, 2013, 08:12 AM
chanyote66's Avatar
Joined Dec 2011
Cedric
I haven't seen reboots but I have seen twitching servos and glitches in video. Probably from the CPU focusing on writing data to memory.
Chris
Old Jan 29, 2013, 02:24 AM
hippojia is offline
Find More Posts by hippojia
is XLator support FY- DoS ?
look like FY-DoS IMU more stable..
hippojia is offline Find More Posts by hippojia
Old Jan 29, 2013, 04:15 AM
Mehari is offline
Find More Posts by Mehari
Joined Aug 2008
I have a DLUHF/DOSD setup on my Easystar II controlled from an Er9x. The camera pan/tilt servos are operated by pots on the Er9x using two channels of the DL receiver.
While there is very occasional chatter in the rudder/elevator/aileron servos, the chatter in the pan and tilt servos is constant and sufficient to be a nuisance in the video image.
Is this an Er9x issue or is something else triggering the noise such as the BEC powering the receiver?
Any suggestions?
Mehari is offline Find More Posts by Mehari
Old Jan 29, 2013, 04:40 AM
futurebreeze is offline
Find More Posts by futurebreeze
FPV addicted
futurebreeze's Avatar
Romania, Bucharest
Joined Jul 2010
I solved such a servo noise by adding a ferrite ring on the PPM cable coming from the RX (I have FrSky). The issue was removed instantly.
futurebreeze is offline Find More Posts by futurebreeze
Old Jan 29, 2013, 07:11 AM
Vantasstic is offline
Find More Posts by Vantasstic
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Any suggestions?
What servos and video freq are you using? I had servo chatter issues with cheap (HXT-9G) servos and 900MHz VTX. I replaced them with higher quality servos (Spektrum/HS-55 type) and the chatter disappeared.
Vantasstic is offline Find More Posts by Vantasstic
Old Jan 29, 2013, 07:12 AM
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Dunno... I use the XLator with the FY-30 just fine. Never heard of the FY-DoS.
Old Jan 29, 2013, 10:55 AM
flyandi is offline
Find More Posts by flyandi
United States, CA, Aliso Viejo
Joined Aug 2009
FY-DOS is a full autopilot system .. not just an IMU ..
So probably doesn't make sense anyway to connect them to each other since DragonOSD has it's own autopilot.
flyandi is offline Find More Posts by flyandi
Old Jan 29, 2013, 01:51 PM
Koo is offline
Koo
Find More Posts by Koo
Koo
A semi-advanced FPV newbie
Koo's Avatar
United States, OH, Oxford
Joined Mar 2012
Just curious, what FrSky receiver do you have and how do you get PPM from FrSky?
Koo is offline Find More Posts by Koo
Old Jan 29, 2013, 02:29 PM
Mehari is offline
Joined Aug 2008
I have Hitec HS65's on the pan/tilt and MPX Nano-S's for surface control. I have tried swapping around with other servos (Spektrum and INO HG-D202HB's) but the chatter does not change.
The chatter is there without the VTX connected.
Before I split the fuselage again to try a ferrite ring on the PPM line, any other thoughts?
Old Jan 29, 2013, 02:43 PM
Joined Jun 2007
Braid your servo leads and ESC leads. And your PPM one for that matter. It might reduce the cable length a bit but it helps massively with em interference.
CJ
Old Jan 29, 2013, 02:57 PM
chanyote66's Avatar
Joined Dec 2011
all of the new telemetry ones have CPPM... works great even the little 4ch one has CPPM and RSSI output!
Chris
Discussion Dragon OSD Level Flight FPV Talk 22 Dec 31, 2013 08:08 PM
For Sale New Intelligent Flight Dragon OSD bfischer Aircraft - General - Miscellaneous (FS/W) 7 Jul 19, 2010 11:56 AM
Discussion FS Ready to fly Intelligent Flight Dragon OSD bfischer FPV Talk 0 Mar 03, 2010 05:57 AM
Discussion RV OSD or Dragon OSD djdaveq FPV Talk 1 Feb 06, 2009 12:18 AM
Discussion RV OSD and Dragon OSD - so near to being Really good! magnetman FPV Talk 8 Nov 11, 2008 05:13 AM
