Joined Jun 2011
I would also like to here about details on this as well. Wouldn't the DL fail safe save you if your DOSD dropped out? The DL fail-safe overrides the osd's FS?
What i mean by saving you!! is at least put you into what ever orientation your FS'd your system? say a slight downward spiral glide power off!? |
I believe most in-air resets will be caused by loose connections not a software glitch. Ensure your voltage stays high enough even when flexing all your servos and running your motor. Cold weather causes LiPos to lower voltage.
Check all your sires, connections and solder joints... breaks in GPS or i2c data an cause DOSD to stall. Quote:
No matter what equipment you have on board there's going to be at least one source that will 'kill' the system. You'd need to invest a whole lot more $$$$$ for redundancies to redundancies...and even those can fail. The best way to ensure you don't crash your plane is to never take it out of the house.
Latest blog entry: Transplanting a Spektrum Dx4E Rf Deck...
I was very upset when I crashed my EZ because of DOSD rebooting. It is still in its carrying box with everything untouched. I must find some time to make a small investigation.
All I can say is that I had been flying almost half an year with separate video battery (including DOSD) and I had zero issues. After this setup I wanted to simplify thing powering everithing from the engine battery. So I put the jumper on DOSD board to get power from current sensor. I had 7-8 flight in differrent days with this new setup and no issue. The day with the crash was a little bit warmer that the other days so the Lipo was fine. I'll be back with more details (if any) after I investigate my wiring and check for possible poor connections. |
Fir the data on the DOSD I have found that Fatshark Predators work nice. The Vuzix provide a good image but take some modifications to work with FPV (needs better sunshades)
Dont go cheaper though... I have tested some cheap ebay goggles and the DOSD data could not be read, I had to use a large font on a remzibi OSD to make anything legible with the cheaper goggles... Chris |
Joined Oct 2012
Juan |
I also have a set of Vuzix 920 Wraps. Never tried them with the sun glass shades. I'd agree with Chris....yuck, phewy....BUT pop them out of the shades and velcro them in a pair of deep ski goggles and SUPER COMFORTABLE, much better picture than my Preds ever had, adjustable focus for each eye. I MUCH PREFER my Vuzix over the Preds...and they cost less too. The newer Fatshark style (sorry, forget the name) has adjustable IPD's for narrower/wider eye spacing...which is nice to have. They still use the rubber eye cups though. I'll stick with my Vuzix, thank you. Do a search for Vuzix on RCG...there's a thread with some info/pictures. I've tried many, many goggles...with Vuzix being my top preference. Heck, I even preferred (and kept) my MyVu video glasses over the Fatshark Predators. |
Joined Oct 2012
. I'll be careful when choosing the glasses
Here is described what I also did : http://www.fpvmanuals.com/2012/05/08...ki-mask-build/ Cedric |
Joined Oct 2012
![]() Juan |
| Thread Tools | |
| Discussion Dragon OSD | Level Flight | Video Piloting (FPV/RPV) | 20 | Apr 17, 2011 12:12 PM |
| For Sale New Intelligent Flight Dragon OSD | bfischer | Aircraft - Electric - Miscellaneous (FS/W) | 7 | Jul 19, 2010 11:56 AM |
| Discussion FS Ready to fly Intelligent Flight Dragon OSD | bfischer | Video Piloting (FPV/RPV) | 0 | Mar 03, 2010 05:57 AM |
| Discussion RV OSD or Dragon OSD | djdaveq | Video Piloting (FPV/RPV) | 1 | Feb 06, 2009 12:18 AM |
| Discussion RV OSD and Dragon OSD - so near to being Really good! | magnetman | Video Piloting (FPV/RPV) | 8 | Nov 11, 2008 05:13 AM |
