Old Nov 09, 2012, 01:55 PM
Carlos230023 is offline
Find More Posts by Carlos230023
um.. yeah, I can make that fly
Carlos230023's Avatar
United Kingdom, Milton Keynes
Joined Jun 2007
Originally Posted by marcin.gala View Post
So it starts like this.
DL RX PPM+RSSi ===to DOSD "not on picture"
camera video input ===to DOSD "not on picture"
VTX video out ===from DOSD "not on picture"
Audio out===from DOSD NOT USED ,going through teleflyOSD to VTX "not on picture"
Picture connections:.
GPS ===directly on picture + teleflyOSD -soldered to GPS cables.
current sensor ===as in DOSD manual
DOSD ===powered by 5V BEC "two lipo setup-separate for video gear"
I2C DOSD SDA SCL===goes to SDA SCL +/- Xlator ===then translated to RX/ground goes to FY30A as ground/UART
+ on FY30A separate red wire === power for FY30A === BEC 5V
NOW !
PWM's 1/2/3/4 signals form DOSD goes to FY30A RUD/ELE/AIL/+/- inputs "no throttle used by FY30A"
then FY30A outputs for servos RUD/ELE/AIL "no throttle" -prefere to setup DOSD to use throttle or leave it with "failsafe settings"
Is FY30A switch signal wire goes straight to DL RX ??
Can I use 5V on PWM's in DOSD to power FY30A ??
or is actually powered through AILERON wires from PWM 1 AIL with signal/+/- wire ??
Nice to see my cases in action :P. I may do one that incorporates a section on the side for the xlator
CJ
Carlos230023 is offline Find More Posts by Carlos230023
Old Nov 09, 2012, 02:26 PM
Koo is offline
Koo
Find More Posts by Koo
Koo
A semi-advanced FPV newbie
Koo's Avatar
United States, OH, Oxford
Joined Mar 2012
I really need help, I think I messed up big time. I connected Video/Audio input/output to Current sonsor pins and then power to the Video/Audio input/output pins.
So basically I had the red cable from my 3s battery connected to ground, and then ground was connected to video in.
I got no smoke and since no led came on, I literally disconnected the battery in 1/5 second.
This was the first time I ever tried powering this OSD on and I bought it from another member here at RCG. I actually triple checked everything but oh well. So my question is, what is the damage and how can it be fixed?
Koo is offline Find More Posts by Koo
Old Nov 09, 2012, 03:08 PM
squishy654 is offline
Find More Posts by squishy654
squishy654's Avatar
United States, CA, Sacramento
Joined Jun 2010
I seem to have an inductor pop off and I was wondering if anyone can help me find a new one...here is a picture of the part that came off and my board, it's marked with a "150" and popped off my DSOD in the lower left hand corner...
squishy654 is offline Find More Posts by squishy654
Old Nov 09, 2012, 04:51 PM
Vantasstic is online now
Find More Posts by Vantasstic
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
How do you know anything is wrong? Did you connect things back up properly and test? You may have no damage if there was no ground path back to the battery...so test and see and let us know.
Vantasstic is online now Find More Posts by Vantasstic
Old Nov 09, 2012, 04:52 PM
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Check with JMSTech on repairs. It's a relatively simple job if you get the right inductor.
Old Nov 09, 2012, 05:12 PM
squishy654's Avatar
Joined Jun 2010
Oh I know, but what inductor, no one can tell me. I will gladly buy one right now and replace it myself as dragonlink support has suggested in the other thread, but he failed to answer my question as to what inductor this is, so I am now trying here.
What inductor do I need? what are the specs?
Old Nov 09, 2012, 05:15 PM
squishy654's Avatar
Joined Jun 2010
well I pm'ed him we'll see if he helps, I hate to bug him about this...
Old Nov 09, 2012, 05:51 PM
CheckSum is offline
Find More Posts by CheckSum
CheckSum's Avatar
Joined Jan 2011
Does Daniel have any plans on incorporating an IMU native to the Dragon OSD board?
CheckSum is offline Find More Posts by CheckSum
Old Nov 09, 2012, 05:54 PM
Koo is offline
Koo
Koo
Koo's Avatar
Joined Mar 2012
Going to do this in a second. Should there be a LED flashing if power is connected to the board? When I connected the power to the (correct ) pins, I can't see anything happening.
Old Nov 09, 2012, 06:29 PM
Koo is offline
Koo
Koo
Koo's Avatar
Joined Mar 2012
IT WORKS! I'm so happy right now, though I fried $100 I have to say that the customer service from Dragon Labs is unbelievable. They responded to my first email within an hour and my second one in 15 minutes.
The person who I was talking with told me that he would see what would happen when he did the same mistake I did. When I'm buying a UHF system, its going to be dragonlink because these guys are awesome
Old Nov 09, 2012, 08:38 PM
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Glad to hear no damage done. Now DON'T do this with the current sensor pin connections. If you connect those in the wrong orientation you WILL be frying your DOSD. And there is no LED status lights on the DOSD.
Old Nov 09, 2012, 09:30 PM
iskess is offline
Find More Posts by iskess
FPV in Hawaii
iskess's Avatar
United States, HI, Kailua
Joined Feb 2012
Daniel who?
iskess is offline Find More Posts by iskess
Old Nov 09, 2012, 10:14 PM
CheckSum is offline
CheckSum's Avatar
Joined Jan 2011
Originally Posted by iskess View Post
Daniel who?
I though it was Daniel Wee who mad Dragon Link, OSD, ect...
Anyways, any word on an IMU incorporated into the OSD?
-Thanks
Old Nov 09, 2012, 10:33 PM
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
-Thanks
Iskess was mess'n with us.
Don't expect any Dragon IMU...for now at least. There's a couple of folks who where working on developing a 3rd party IMU for the DOSD, but I haven't heard of any status or if the project is still under production. The FY-30 and Xlater is the best option out there for now.
Old Nov 10, 2012, 12:22 AM
chris1seto is offline
Find More Posts by chris1seto
Dragon Link/Labs Engineer
chris1seto's Avatar
Chesterfield, MO
Joined Nov 2010
Originally Posted by Flybynight2 View Post
Van, (sorry) was not to you.
I was talking about Dragon Labs support Web site.
Crash, I don't know Chris.
yes I everything is set correct, I have checked it all several times.
PS Posted schematic.
And I have been working on it today in 40 weather, My fingers are frozen.
JIm
Can you try grounding the Xlator to the BEC?
chris1seto is offline Find More Posts by chris1seto
Discussion Dragon OSD Level Flight FPV Talk 22 Dec 31, 2013 08:08 PM
For Sale New Intelligent Flight Dragon OSD bfischer Aircraft - General - Miscellaneous (FS/W) 7 Jul 19, 2010 11:56 AM
Discussion FS Ready to fly Intelligent Flight Dragon OSD bfischer FPV Talk 0 Mar 03, 2010 05:57 AM
Discussion RV OSD or Dragon OSD djdaveq FPV Talk 1 Feb 06, 2009 12:18 AM
Discussion RV OSD and Dragon OSD - so near to being Really good! magnetman FPV Talk 8 Nov 11, 2008 05:13 AM
